Question for the CV Joint Gurus - Help Identify Failure Mode
caseyl
caseyl is offline
PostPosted: Wed Jul 23, 2025 3:15 pm    Post subject: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
Hey Samba People!
I have a good question for all the CV joint guru's out there.
What causes this failure? I can't seem to figure this out.
I have had this occur a few times on my Syncro Vanagon, which I assumed was my fault for some reason because I do the assembly.
But this time it happened on my Q5, on an axle I replaced as an assembly. This is a new GKN assembly from FCP euro. Seems to have lasted about a year.
When I have taken a similarly failed joint apart from my vanagon, I was surprised to see the star balls and cage intact. I initially thought I exploded the joint, but that doesn't seem to be the case.
MarkWard
MarkWard is offline
PostPosted: Wed Jul 23, 2025 5:50 pm    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
On the Racecar I’d run no small clamps. I believe it has to do with temp differential. Expansion and contraction. One try is to slip a small section of wd40 straw between the boot and the shaft to allow for equalization. When the boots were of good quality the small clamp wasn’t really required. Recently I had 4 Lobro cv boots split on the seam starting at the small end.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 23, 2025 11:39 pm    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
Either you stripped the spines , broke the axle ir shattered the cage.
Most likely a broken cage.
Shit parts, that's why.
MarkWard
MarkWard is offline
PostPosted: Thu Jul 24, 2025 5:13 am    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
I should have added I’m not a Guru. Is the problem the boot or did the joint fail? Are you driving some altitude changes?
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Jul 24, 2025 5:39 pm    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
The CV is broken, look at the boot, it twisted, by about 90* judging by the mold seam, while the ends haven't budged. I had the same on my Syncro, can't believe I got home and boot was still good Laughing
dobryan
dobryan is offline
PostPosted: Thu Jul 24, 2025 6:29 pm    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
Johnny had that happen at Syncro Solstice. Broke the cage.
Dave O
The Western Syncro build
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 30, 2025 10:19 am    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
There's a famous picture a good decade ago at the crazy steep hill at Hollister, of a Syncro that broke the front outer cage and subsequentally rolled on its side.
Sodo
Sodo is offline
PostPosted: Wed Jul 30, 2025 12:31 pm    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
Yeah that gives me the Willies wrt relying upon granny on a steep slope. I just don’t have a lot of faith in the strength of the drivetrain. One CV failure and you’re now a 2WD inserted into a dangerous situation.
I’m not a CV guru either but I have been denigrated for statements aligning me with “clocking deniers”. Rolling Eyes
Thats a curious failure!
The star can rotate only after the 6th ball has fallen out. I have a hard time believing it would rotate just 1/6 turn.
And where are the balls - on the inside?
I don’t see stripping the spline. They’re real strong. Possibly the spline pulled out & reinserted? Surprised
....KTMs, GasGas, SPOT mtb
MarkWard
MarkWard is offline
PostPosted: Wed Jul 30, 2025 1:38 pm    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
It’s hard to imagine the outer cv failing in the above photo and not destroy the boot completely with a free wheeling shaft. The original poster hasn’t been back, so we are guessing at this point.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 30, 2025 11:11 pm    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
I shattered a 16"cv cage as well, the boot held up til I got home, no twist. I couldn't believe it. I did decouple though, so it was only passive anyway, open diff too.
SyncroTrev
SyncroTrev is offline
PostPosted: Thu Jul 31, 2025 10:15 am    Post subject: Re: Question for the CV Joint Gurus - Help Identify Failure Mode Reply with quote
I am by no means a CV guru either.... but I do service mine often. (Syncro with TDI ALH swap running 930 cvs everywhere but the front outers, those are the 16" Burly upgrades.)
To answer the original question.... why do they break:
1) Cheap parts. Try and buy the nicest you can.
2) Vehicle mods that increase horse power / torque. (if you're running more power than stock and are still running stock CV's it can be a weak spot.
3) Driving certain ways that are known to be hard on CV's. Applying lots of power with the wheels turned as sharp as possible for example. Or spinning wheels on ice then catching dry pavement with lots of power down.
4) Also lift kits... the extreme angle will wear them out faster.
Judging by your picture... you look stock with no lift. So likely just bad luck with cheap parts. Or maybe you have a teenager your letting drive the car... they could break a military tank those kids... haha
1989 Vanagon Syncro
Adventurewagen Hightop
Westy Cab Interior
1.9 TDI ALH
Bend, OR
