87 Syncro - Running Rich
Serendipity87
Serendipity87 is offline
PostPosted: Mon Jul 28, 2025 10:15 am    Post subject: 87 Syncro - Running Rich Reply with quote
and one more issue to deal with...Smile
My van has a GenV Jetta Engine 2.0L recently "went limp", underpowered, out of nowhere seemingly.
I found I had two codes:
P2138: throttle/pedal position sensor
P0172: running rich
Fixed the pedal position sensor and it has not gone limp again. Seems to be running fine.
But the running rich code persists.
Changed the spark plugs, wires look ok. Muffler/oxygen sensor were pretty recently replaced. I don't have any dash lights currently.
What else do you suggest I check?
1987 Syncro Camper Van/Country Homes Camper Poptop
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Jul 28, 2025 10:25 am    Post subject: Re: 87 Syncro - Running Rich Reply with quote
What motor are you running?
dhaavers
dhaavers is offline
PostPosted: Mon Jul 28, 2025 11:46 am    Post subject: Re: 87 Syncro - Running Rich Reply with quote
From his other thread:
GenV 2.1L Jetta Engine
Yeah, good to know specifics.
Wink
- Dave
"The WonderVan"
Serendipity87
PostPosted: Mon Jul 28, 2025 1:17 pm    Post subject: Re: 87 Syncro - Running Rich Reply with quote
I edited original post to include the Engine - 2.0L GenV Jetta.
Phishman068
Phishman068 is offline
PostPosted: Mon Jul 28, 2025 1:26 pm    Post subject: Re: 87 Syncro - Running Rich Reply with quote
Do you mean a Foreign Auto Supply Gen 5 2.0 Liter conversion?
That's an engine swap, and will have very specific issues that would likely best be answered by Foreign Auto Supply (The company making and supporting that engine, out of Maine).
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
Serendipity87
PostPosted: Mon Jul 28, 2025 4:13 pm    Post subject: Re: 87 Syncro - Running Rich Reply with quote
Yes you're correct, 2.0 (original engine was 2.1). It is an engine swap. I had reached out to my mechanic here in Seattle who did the conversion, but hadn't heard back yet today...hadn't thought to reach out to FAS, thanks. Good idea.
hardway
hardway is offline
PostPosted: Tue Jul 29, 2025 5:58 pm    Post subject: Re: 87 Syncro - Running Rich Reply with quote
The fault codes you have listed are generic OBD II faults. Your engine is a VAG unit. The ECU actually thinks in VAG specific codes. The OBD II faults are mandated as an overlay by federal law on this side of the pond.
The VAG specific fault code tend to be more specific than the generic fault codes. It would be useful to have access to the VAG fault codes and definitions.
But I would be looking at the throttle control system. Is it a full drive by wire system or an earlier hybrid system? Probably the former. Where is the throttle pedal sensor?
