Which aftermarket Early Bay Tachometer is better? |
Smiths |
100% |
[ 3 ] |
ISP |
0% |
[ 0 ] |
Other |
0% |
[ 0 ] |
Total Votes : 3 |
ratherb-buggin Samba Member
Joined: January 30, 2005 Posts: 992 Location: Shawnee, KS
Posted: Sun Aug 03, 2025 6:10 pm Post subject: ISP or Smiths Early Bay Aftermarket Dash Tachometer |
Looking into a dash tach for my 68. I've seen the ISP and Smiths versions. It looks like Just Kampers also maybe sells the Smiths. Does anyone have knowledge if one is better than the other?
If you're running one please tell us which one you're running and your feedback on it.
ISP
Smiths |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13525 Location: West Coast, USA
Posted: Sun Aug 03, 2025 8:14 pm Post subject: Re: ISP or Smiths Early Bay Aftermarket Dash Tachometer |
I run the Smiths because I like 1-2-3-4 not 10-20-30-40.
Diodes are almost always mandatory for either.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2739 Location: Ocean Beach - San Diego
Posted: Sun Aug 03, 2025 8:22 pm Post subject: Re: ISP or Smiths Early Bay Aftermarket Dash Tachometer |
And we use a standard VDO 2 inch tac and bored out the blanking plate to mount it. Much less elegant, but functional. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42745 Location: at the beach
Posted: Sun Aug 03, 2025 8:23 pm Post subject: Re: ISP or Smiths Early Bay Aftermarket Dash Tachometer |
vdo with busboys adapter plate _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2982 Location: San Diego, CA
Posted: Sun Aug 03, 2025 8:52 pm Post subject: Re: ISP or Smiths Early Bay Aftermarket Dash Tachometer |
I have been running a Smiths for about 20K miles. The only issue I have is that sometimes when I shut off the bus the tach stays at 1,000. I switch to the ignition to the accessory position and the needle swings all the way to the right and back down to zero.
I don't like the double digits and the ISP logo on that unit. Also, the tach in the ISP ad is stuck at 250. |
Posted: Sun Aug 03, 2025 8:55 pm Post subject: Re: ISP or Smiths Early Bay Aftermarket Dash Tachometer |
SGKent wrote: |
vdo with busboys adapter plate |
BusBoys hasn’t been around since the Obama administration…
For the price of VDO plus adapter with shippings, you can have one that looks like VW put it there.
I think both are significantly brighter than stock. I used a ceramic resistor inline to mine tach’s backlight so it glows and dims along with the speedometer, but I can’t remember the wattage for the life of me.
In full disclosure, mine was one of the early or prototype Smiths that has a different movement. Less jerky and always rests at zero when the key is off. Do the ISP tachs stay at idle speed after shutdown like the newer Smiths?
www.airschooled.com
Posted: Mon Aug 04, 2025 4:15 am Post subject: Re: ISP or Smiths Early Bay Aftermarket Dash Tachometer |
I expected some feedback on both but there is definitely more to each than I thought. Thank you so much for the good feedback, and tips so far.
I have an under the dash mount tach now and I'm tired of leaning to the side to see it.
How is the movement on the modern Smiths? Is the movement when you rev smooth? |
Posted: Mon Aug 04, 2025 6:51 pm Post subject: Re: ISP or Smiths Early Bay Aftermarket Dash Tachometer |
My Smiths unit tracks smoothly. I have a Shockwave distributor and didn't install a diode. I used piggy back style connectors so I didn't need to cut or splice any wires.
