Vanagon AC Engine Options
catch_me
catch_me is offline
PostPosted: Thu Aug 07, 2025 9:12 am    Post subject: Vanagon AC Engine Options Reply with quote
I am a newer owner of a pretty much all original 1983 Vanagon that is a 2.0 liter air cooled version. That being said it has now 126,000+ miles on a the original engine after our 2500 mile trip we just took in the Upper Peninsula of Michigan.
I am just curious as we had a lot of fun and now are totally bit by the Vanagon traveling bug, and I like the idea of keeping it air cooled rather than going with a swap, what would be the recommended engine specs for a rebuild? I am hoping to keep the OEM fuel injection as that seems to be working fine, but would not mind boring it out to get a little more power (not sure what a max displacement is still reliable in the vanagons), and know that would require new heads as well.
I know there are thread out there on this but some are quite old and looking for currently what and who would people suggest for parts and building of this project.
jlrftype7
jlrftype7 is offline
PostPosted: Thu Aug 07, 2025 9:24 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
If you're not burning or consuming oil, you're half the way there to not doing anything.... Wink Wink
Find out what you have to begin with before planning to rebuild or upgrade:
With a Compression Check, you can get an idea of the health of the engine.
If you see readings close to 100 psi, or a fair amount of difference between cylinders in those compression readings, you start to prepare for engine rebuild or swap time, or dive further into the engine in case its a valve sealing issue and not a ring issue.
If you're all relatively even in your cyl readings, and above 100 psi at like 120 or better, then it's oil pressure measuring if you want to go the next step.
Hot Oil pressure is what you're looking for, at idle and at higher engine RPMs.
For more power, contact one of the engine builders here on Samba or ones listed. Be prepared to be shocked at what it costs to go bigger, or even just a really nice stock rebuild with an eye towards reliability versus more power.
Quality Type 4 engine parts are not cheap compared to Type 1 upright air cooled engine parts, but you get a different animal with the Type 4 engine-better suited to life in a Bus for the long haul.
Randy's Air Cooled down in Comfort Texas, posts in the Classifieds for engines, turn key and other options. There are others
‘84 Tin Top - Hilga....Auto
catch_me
catch_me is offline
PostPosted: Thu Aug 07, 2025 9:40 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
Well it is leaking and/or burning oil. Leaves a pretty good puddle when stopped at times, so currently trying to figure that out as it looks like the oil pressure sender may be leaking a bit and the general seal leaks of an old engine, but trying to find the big ones.
I have no problem rebuilding my own engine over time, more curious if it is worth going the full blown LN Engineering kit, or if there are other options that get you there for a van that still will only being doing around 4000 miles a year at most.
?Waldo?
?Waldo? is offline
PostPosted: Thu Aug 07, 2025 10:05 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
jlrftype7 wrote:
If you're all relatively even in your cyl readings, and above 100 psi at like 120 or better...
The air-cooled engines had a nominal compression pressure of 87-131 psi at sea level. The wear limit is 73 psi (again at sea level). If at altitude, those numbers need to be adjusted downward relative to the lower air pressure. In other words, at 7,000' of elevation, the wear limit of compression is 59 psi! At 7,000' of elevation 60 psi is within spec provided there is not more than 44 psi difference between cylinders!
Even at sea level a compression pressure of 75 psi is within spec provided there is not more than 44 psi difference between cylinders!
Even with all new parts and everything being correct, 90 psi is perfectly acceptable.
Nitramrebrab72
Nitramrebrab72 is offline
PostPosted: Thu Aug 07, 2025 11:01 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
I have a 2.0L Air cooled and drive 12,000miles a year and have been for many years, as regards the oil leaks the usually come from the push rod tubes. They can be changed in situ . The most important advice is to use the green Viton rings not the red silicone ones they both have the same ratings on paper but in reality Viton last 2 to 5 times longer both can resist to 450f and Viton slightly more, the problem with the red silicone ones is they degrade every hot cold cycle Viton does not. The Viton seals should last at least 10 years, silicone 1 to 3 years.
The inner pushrod O-ring (black) ones will last 3 to 5 years so it would be advisable to source a viton for the inner side too. The constructor fitted black and they are good to the block max temps but only just, (not cylinder head temps though)so they are the right ones to save money but will let you down earlier than the viton.
The other leaks come from the rocker cover gaskets, replace and fit with gasket sealant if not they will start to leak within a year. At the same time take advantage to re-adjust the hydraulic tappets, they should be done every 50k to 60k miles.
Remember to remove the lower air shroud and give it a good power wash up there before starting the o ring replacement job if not muck will get into the engine if you are not careful.
As regards the sender leak , it will be the sender it's self leaking ,just replace it,(with the best quality you can find).
Once you have done these three common leaks and you have a nice clean engine to check for leaks go for a drive and check for flywheel and pulley main seal leaks.
If there are minimal or none which is likely then all is done, it may leak from being unused but if you drive it it will start to reseal. Fresh engine oils have swelling agents to keep them taking up the slack from frictional wear, and if it leaks it will cover the outer side of the seal and will swell more than usual and should self seal within a few thousand miles of adding new engine oil. As swelling agent evaporates old engine can be the culprit but it will take driving a few thousand miles with fresh oil to.really know. Synthetic oils have less swelling agents as they have less friction and the seal wears slower so a none synthetic oil change would be a plus for your fresh oil change after replacing the o rings and maybe the next before going to a synthetic oil if preferred. If still leaking after 5k but is slowly reducing be patient, if it is still the same you find un-acceptable then add a minimum amount of swelling agent that should do it but go easy as over swelling will wear out the seal earlier than an ever so slightly leaking seal.
catch_me
catch_me is offline
PostPosted: Thu Aug 07, 2025 5:04 pm    Post subject: Re: Vanagon AC Engine Options Reply with quote
Did a compression check tonight and was pleasantly surprised!
Cylinder 1: 105 PSI
Cylinder 2: 120 PSI
Cylinder 3: 102-105 PSI (not a great reading due to poor sealing of the gauge as this was the first measured but good enough I wasn't going to play with it more)
Cylinder 4: 120 PSI
I did not expect them to be near that high considering the mileage and the engine had never been touched other than some wiring for the ignition I can see was replaced.
But that means now I need to find the significant oil leak then, which as has been mentioned and I am pretty sure it is as well likely will be the push rod tubes. Also it seemed as though the PCV breather/tower had some oil coming out like it may have been plugged so I tried to do some cleaning of that with degreaser to hopefully make a difference with that as well.
?Waldo?
?Waldo? is offline
PostPosted: Thu Aug 07, 2025 5:39 pm    Post subject: Re: Vanagon AC Engine Options Reply with quote
Those compression pressures are fine.
Out of curiosity, you did the test with the engine warmed up? All spark plugs removed? Throttle wide open? Cranked each cylinder until the gauge stopped moving up?
catch_me
catch_me is offline
PostPosted: Thu Aug 07, 2025 5:48 pm    Post subject: Re: Vanagon AC Engine Options Reply with quote
Did it with the engine cold, all plugs were removed, and throttle was closed. Each cylinder was cranked till the gauge stopped moving.
I was not really planning on doing a compression test but was pulling the new plugs to see what the burn looked like and decided "while I'm in there" quick do one just to see what they roughly are.
?Waldo?
?Waldo? is offline
PostPosted: Thu Aug 07, 2025 10:58 pm    Post subject: Re: Vanagon AC Engine Options Reply with quote
Those numbers will typically go up some when warmed up and with the throttle open. The lifters being pumped up can also make a big difference sometimes. Regardless, the numbers are fine.
Nitramrebrab72
PostPosted: Fri Aug 08, 2025 1:26 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
Cylinder 1: 105 PSI
Cylinder 2: 120 PSI
Cylinder 4: 120 PSI
If oil changes are done regularly with a high quality oil they will do 250,000 to 350,000 miles depending on the type of driving and loading between engine rebuilds.
As long as oil is fresh and between levels and you don't overheat her. Remember the more miles a car has, the less wear material is available on bearings cams etc so to keep her running the extra length the answer is frequent oil changes maybe more so than the workshop manual says. It's a lot easier and economic to do a couple of extra oil changes to gain an extra 50,000 miles than an earlier rebuild. I have seen a mentality with older higher mileage vehicles of neglecting the oil changes for some reason when the total opposite is required on them . A cylinder head temperature gauge and oil temperature gauge are great for keeping an eye on the engine to avoid over straining her and should show anything abnormal occurring from a sudden increase in temperature allowing you to shut down before any serious damage.
I am happy when both are at the 220f mark or less, some might say a bit more is acceptable which is true but the engine might not last quite as long also.
You have great compression the oil leaks can be easily fixed, just one thing to look out for is debris in the cooling system especially as oil will probably have been sent around the cooling fins and oil cooler with debris sticking to the oil .
Compressed air sent from below up through the oil cooler fins with a vacuum hose in the near by spark plug tinware hole is advisable to keep proper oil cooling, then a full degreasing and rinse. If you still are not getting lower enough oil temperatures then verifying the oil cooler pressure relief might be in order.
As for the rest of the cooling professional degreaser sprayed in through the tin wear spark plug holes , washed off and then let to dry followed by compressed air blown from below with 2 vacuum cleaners one on each spark plug tin wear holes doing one side then the next would be advisable due to the mileage and leaked oil that will be gunged up there impairing good cooling.
MarkWard
MarkWard is offline
PostPosted: Fri Aug 08, 2025 3:56 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
The nicest Vanagon I ever drove was an 80 air cooled that had been fitted with a Porsche 911 3.0 and the 5 speed transmission. What a hoot. If I had an air cooled van and wanted power and reliability, I’d start saving for that setup.
The above is accurate advice. We were doing pushrod seals while the vans were under warranty back in the day. Pretty straightforward job once you’ve done it.
catch_me
catch_me is offline
PostPosted: Fri Aug 08, 2025 6:55 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
Thanks for all the advice, looks like the next steps will be try to curb the oil leaks that are likely the common ones from years of sitting and just degradation, and then clean things up really good to get the cooling as efficient as possible!
?Waldo?
?Waldo? is offline
PostPosted: Fri Aug 08, 2025 7:15 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
Some of them went/go that far. Many (most?) will drop a valve seat before long before that.
I like that picture of the top of the oil cooler. I have seen buildup of crap in the cylinder fins also. The top of the cylinders is a nice place for a rodent to build a nest if the van sits.
GoEverywhere
GoEverywhere is offline
PostPosted: Fri Aug 08, 2025 8:18 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
It isn't WILDLY expensive to build something like a 2056cc, but for any real performance gains you'll have to ditch the stock EFI. It really can't deal with a camshaft with any overlap at all, which unfortunately are going to be the ones that give you performance.
I had a big bore 2200cc Type-4 in my rig for quite a while that was around 150HP. It moved the van nicely and was a very good upgrade from stock. It wasn't wildly expensive with me doing all the work to build it, and all in all was a great way to stay aircooled... Ultimately though I switched to a Subie engine and its MILES better. But if you want to stay aircooled there's certainly options!
Nitramrebrab72
PostPosted: Fri Aug 08, 2025 8:24 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
The 3.0 liter 911SC is an ideal one not too overpowered so it won't overheat pushing the heavier bus around. I believe it has the strengthened bottom end, bearings and case reinforcements ideal for a heavy bus, as it was to be used for both the 911SC and the 930 turbo.
If not you are looking at a handful of extra horses on the 2.0L with a few costly tweaks. It's not really worth it . The Porsche 914/4 2.0L ( similar engine) has 100bhp but not that much more torque, and that engine would over heat in a heavy bus , and reliability would drop..
Making sure your bus is not loaded up with weight, fresh low friction engine oil and new spark plugs (the NGK Iridiums make a slight difference ,good plug leads and rotor cap and on the nail timing and the correct tire pressure based on load and efficient tyre models (quality eco ones make 2 to 3% difference also the narrower 185's) will help, new air filter, and fuel injectors that have a neat correct spray pattern.
You could even fit plexiglass windows and a light weight race battery, it would be more cost effective for increased performance and relieve load off the engine and save a bit on fuel.
catch_me
catch_me is offline
PostPosted: Fri Aug 08, 2025 9:32 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
Is there any way to get to the oil cooler with the engine in? I know the tin needs to come off, and looking close it looks as though there may be a significant leak coming from there, as the pushrod tubes look pretty dry but around the oil cooler is very full of oil. The previous owner did have A/C added over there, and the belt imploded at some point which may be part of the issue as well. Probably will look at it with a borascope today to get a better view up in the region.
Wildthings
Wildthings is offline
PostPosted: Fri Aug 08, 2025 9:57 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
Set your timing at 28° BTDC @3800+ rpms, hose(s) removed from the vacuum canister on the distributor and plugged and the digital idle stabilizer bypassed (if so equipped). The book timing specs works only when everything in the fuel and ignition system is factory new, while the spec given above accounts for parts that are worn a bit and that may not even be the correct part number.
100-200 miles before your next oil change add 4-8 oz of MMO (Marvel Mystery Oil) to your crankcase to clean things up a little, and then run a relatively thin synthetic oil (like a 5w30, 5w40 or 10w40) to keep the engine as clean inside as possible and to help the lifters pump up. You only want to see 10 psi per 1000 rpms on a VW aircooled engine, as higher oil pressure will cause significant oil to bypass the oil cooler. FWIW, I have always run my Type 4 engines a quart over the mark and gotten nice long life out of my engines.
Check your oil pressure switch for oil leaks particularly ones that appear to be coming from the oil cooler and oil filter area. The oil pressure switch is hidden under the cooling tin and thus hard to see well.
If you ever have the engine removed to do clutch work or other, then would be a good time to do front and rear crankseals and peen around the oil galley plugs and replace other seals and gaskets that are hard to access when the engine is installed and fully dressed.
MarkWard
MarkWard is offline
PostPosted: Fri Aug 08, 2025 10:15 am    Post subject: Re: Vanagon AC Engine Options Reply with quote
Is there any way to get to the oil cooler with the engine in? I know the tin needs to come off, and looking close it looks as though there may be a significant leak coming from there, as the pushrod tubes look pretty dry but around the oil cooler is very full of oil. The previous owner did have A/C added over there, and the belt imploded at some point which may be part of the issue as well. Probably will look at it again with a borascope today to get a better view up in the region.
I might recommend pulling the engine. Get it in a stand, strip it down to the long block. Then degrease, pressure wash, and reseal. You can access the cooler, but it’s not the easiest installed.
Nitramrebrab72
PostPosted: Fri Aug 08, 2025 2:13 pm    Post subject: Re: Vanagon AC Engine Options Reply with quote
Your advice on a similar post solved my problem on oil temps that and putting the stock gearbox back instead of the lower ratio one but mainly the thinner oil.
Nitramrebrab72
PostPosted: Fri Aug 08, 2025 2:17 pm    Post subject: Re: Vanagon AC Engine Options Reply with quote
