Trevor P Samba Member
Joined: January 21, 2004 Posts: 902 Location: Saskatoon, SK, Canada
Posted: Thu Aug 14, 2025 9:26 pm Post subject: VW stamp for printing press? |
I just picked up this VW stamp which I was told was believed to have been used by our local news paper for the printing press. I know nothing about newspaper printing but what I do know is that its made of lead and encased in a wood block. If anyone might be able to confirm or deny this Id be willing to listen.
_________________ 53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy
finster Samba Member
Joined: May 26, 2012 Posts: 10607 Location: not far from the madding crowd
Posted: Fri Aug 15, 2025 3:00 am Post subject: Re: VW stamp for printing press? |
pretty sure that even a small local newspaper would be using hot metal typesetting machines if not a phototypesetting set-up. these didn't use wooden blocks (as far as I know). I'm wondering if the logo has been cut out of a larger plate and attached to the block for use as a 'rubber' style stamp...if the print shop also did general printing work this could be used to stamp the label on a batch of sales leaflets for a local dealer. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2557 Location: Australia
Posted: Sat Aug 16, 2025 4:47 pm Post subject: Re: VW stamp for printing press? |
| finster wrote: |
| pretty sure that even a small local newspaper would be using hot metal typesetting machines if not a phototypesetting set-up. these didn't use wooden blocks (as far as I know). I'm wondering if the logo has been cut out of a larger plate and attached to the block for use as a 'rubber' style stamp...if the print shop also did general printing work this could be used to stamp the label on a batch of sales leaflets for a local dealer. |
Early VW newspaper printing blocks.....all mounted on wood. This is normal.
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
