my_vw_sucks Samba Member
Posted: Fri Aug 15, 2025 11:53 am Post subject: Blown head gasket or something else? |
Well, I noticed a bunch of coolant on the ground at the back of the van this morning. I had just returned from Tahoe to the Bay Area and figured something had given up on the drive home. Coolant looked to be leaking from the overflow tank. I figured it was cracked. I opened the coolant cap behind the license plate door and clean coolant just dumped out. It was full to the brim. I opened the cap on the expansion tank and it too was full to the brim. Almost appeared to be pressurized with coolant pouring out the top.
My first thought was maybe blown head-gasket pressurizing the cooling system. But coolant is very, very clean. Checked the oil and that too is clean. No signs of milkshake. There was no drivability issues while driving. Power seemed fine and temps were normal.
The motor is a Gowesty 2.3L that the PO installed about 50k miles ago. While I’ve owned and worked on VWs all my life I haven’t had a WBX in about 30 years. So I’m unsure how a blown head gasket or other problem like this would present itself. Any recommendations on how I should go about diagnosing this or ideas on what it might be? Any help is greatly appreciated. |
Posted: Fri Aug 15, 2025 12:04 pm Post subject: Re: Blown head gasket or something else? |
| I’m starting with a head gasket leak tester to see if there is combustion gasses in the coolant. I don’t have high hopes. We’ll see tomorrow when Amazon shows up. |
E1 Samba Member
Joined: January 21, 2013 Posts: 8803 Location: Westfalia, Earth
Posted: Fri Aug 15, 2025 12:14 pm Post subject: Re: Blown head gasket or something else? |
Did it get hot?
If not and you have a stock expansion tank (the large one) with a blue cap, change the cap. They routinely fail, recommend the Blau or Meyle brands and no others.
Don’t freak just yet, this has happened to us several times, and it’s never been a head gasket. It takes some time for coolant to cool enough to produce a vacuum that reclaims coolant.
If the expansion tanks stays full when cool, after overfilling the overflow, either you now have air in the system that precludes vacuum draw and/or the cap isn’t opening to draw it back in, either. _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4707 Location: United States, Iowa
Posted: Fri Aug 15, 2025 12:21 pm Post subject: Re: Blown head gasket or something else? |
Just wondering, but any chance you checked to see if there was air in the radiator? I know this might seem to be a strange question, but if the pressure tank and the overflow tank were full, where is the air that would build up if there were an exhaust leak?
Next, what was the last coolant fill, and the procedure you used?
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
space Samba Member
Posted: Fri Aug 15, 2025 12:57 pm Post subject: Re: Blown head gasket or something else? |
Similar happened to my van
It ended up being the pressure tank
Replaced w an gw aluminum problem solved! _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
Posted: Fri Aug 15, 2025 1:20 pm Post subject: Re: Blown head gasket or something else? |
The cooling system and all engine components were at ambient temperature when I checked their levels. I opened the bleed valve and no gas hiss. Kept the valve open and brought the van up to op temp. No coolant came out of the bleed valve but the fan did cycle numerous times.
My plan is test the cooling system for gas when I get the kit tomorrow. If no gas present I'll go ahead and replace the expansion cap as suggested and take the opportunity to flush and bleed the system. I'm a bit dubious to the cap being bad but happy to be wrong, as the expansion tank is also full. I'd figure it would be empty. But maybe it just gulped air on the cap fail and backed up the system.
I've never done a bleed on the system, as the PO just had the coolant replaced a little under two years ago right before I bought it. If I get as far as replacing the cap I'll be doing some research on bleeding techniques. I did just watch a video of a guy using a PVC pipe/bong to fill the expansion tank that looked fairly straightforward. I'm open to suggestions. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5941 Location: Bemidji, MN
Posted: Fri Aug 15, 2025 1:33 pm Post subject: Re: Blown head gasket or something else? |
| my_vw_sucks wrote: |
| Kept the valve open and brought the van up to op temp. No coolant came out of the bleed valve but the fan did cycle numerous times. |
right. you need to begin with a cold engine, CLOSE the radiator bleeder, start motor and warm up until you feel pressure in the hoses, THEN crack the radiator bleed screw open in order to use the built-up pressure to force air out. _________________ -dan
www.thefixitworkshop.com |
E1 Samba Member
Posted: Fri Aug 15, 2025 1:38 pm Post subject: Re: Blown head gasket or something else? |
If it’s a cap bleeding off somewhere below the 14.5 psi/1 bar, the tank indeed will be full when hot — or so it was whenever ours have failed.
You may have air trapped, before or now. Try bringing to temp at idle, and run all the heaters.
Did you bleed the rad at full temp, and with the nose raised? There might be lots in there now, or somewhere else, for a variety of possible reasons. _________________ If ever twice as rich, we’re gettin’ a double-wide
jlrftype7 Samba Member
Posted: Fri Aug 15, 2025 1:49 pm Post subject: Re: Blown head gasket or something else? |
There are threads, and pictures, of people getting their Vanagon at a kind of steep angle to help bleed air out of the Coolant system.
And then there's the Libby Bong method as well.
Once you get actual coolant out of the Radiator Bleed hole, then worry about testing for Combustion Gas getting into your Coolant System from a possible failing Fire Ring Seal. That's our version of a failed Head Gasket as far as comparing to a more normal gasket set-up on other vehicles.
If you have a fire ring failing, you'll often lose output from the Front Heater Core as combustion air /pressure gets into the coolant system.
If you didn't seem to have pressure that relieved when you took your pressure cap off, all of this might be more normal, and cheaper, things like others have posted about. Failed Blue Cap, tank issue, system not bled of air in too many months.
So, fingers crossed and start with the simple stuff first. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Fri Aug 15, 2025 2:13 pm Post subject: Re: Blown head gasket or something else? |
| Thank you all for the very helpful suggestions and community! I've ordered a Blau expansion cap. I'll go ahead and flush and bleed the system when it arrives. All of the comments really have me hopeful that it's a bad cap. |
Chootrain470 Samba Member
Joined: March 01, 2023 Posts: 209 Location: Simi Valley, CA
Posted: Fri Aug 15, 2025 2:27 pm Post subject: Re: Blown head gasket or something else? |
| I had a combustion leak about two years ago. The symptoms were my coolant would shoot out of the overflow tank after a drive like soda pop. I also would have a small puddle of coolant after parking for a while. Needless to say, I had low coolant issues too. I ended up needing to do a cylinder head replacement. |
Posted: Fri Aug 15, 2025 2:34 pm Post subject: Re: Blown head gasket or something else? |
| Chootrain470 wrote: |
And now less hopeful. This is exactly what is happening. I'm going to try the cap and keep my fingers crossed. |
E1 Samba Member
Posted: Fri Aug 15, 2025 2:39 pm Post subject: Re: Blown head gasket or something else? |
Chootrain, did you notice any air bubbling into your overflow once the gasket went bad?
Asking for a friend…
A failed blue cap will also jet out the overflow vent on top. I was in your exact shoes in worry, it was just a blue cap — and my first post here.
Fingers crossed bigly, odds are it’s a lesser cause like some others mentioned.
The longer and hotter the drive, the more the coolant pressure and coolant out a bad cap.
A shorter or cooler or less-stressful of a drive might cause everything from no rise to a lesser rise not quite overflowing.
Pressure-testing the system would be a good move, too. _________________ If ever twice as rich, we’re gettin’ a double-wide
Posted: Fri Aug 15, 2025 3:07 pm Post subject: Re: Blown head gasket or something else? |
| E1 wrote: |
Pressure-testing the system would be a good move, too. |
It's been a while so my memory might not be right, but yes I believe it was bubbling. Very similar to a shaken soda can. |
E1 Samba Member
Posted: Fri Aug 15, 2025 3:10 pm Post subject: Re: Blown head gasket or something else? |
Thanks for that.  _________________ If ever twice as rich, we’re gettin’ a double-wide
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 615 Location: Chicago, IL
Posted: Fri Aug 15, 2025 3:35 pm Post subject: Re: Blown head gasket or something else? |
Simple test on the blue cap. I have never done this as by the time I became aware of this video I already moved on to an aluminum expansion tank, but seems pretty simple.
_________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
E1 Samba Member
Posted: Fri Aug 15, 2025 4:04 pm Post subject: Re: Blown head gasket or something else? |
I filmed that, of a Bestie. _________________ If ever twice as rich, we’re gettin’ a double-wide
Posted: Fri Aug 15, 2025 4:58 pm Post subject: Re: Blown head gasket or something else? |
| E1 wrote: |
| I filmed that, of a Bestie. |
Love it! Makes me laugh every time. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
E1 Samba Member
Posted: Fri Aug 15, 2025 5:12 pm Post subject: Re: Blown head gasket or something else? |
Haha, Thanks, Ian’s a wonderful guy and clearly a Master of Ad Lib.
Makes us still laugh, too… the bulging eyes were not in the script.
All I did was hold my iPhone.
Certainly not an Engineering method, but has proven workable to finding our bad blue caps since. I think we shot it in early 2017. _________________ If ever twice as rich, we’re gettin’ a double-wide
Posted: Sat Aug 16, 2025 1:22 pm Post subject: Re: Blown head gasket or something else? |
| Crooked Designer wrote: |
Ran the test and have a dying trumpet and can easily drink a coke through the cap (no closed b-hole on this one). Back to being optimistic. That new cap needs to hurry up. |
