Saco
kingdookie
kingdookie is offline
PostPosted: Fri Nov 07, 2025 10:07 am    Post subject: Saco Reply with quote
Hi All,
I'm looking for an affordable disk brake kit for my split. After doing the research here I decided to go with the Saco kit. Unfortunately their site is not working properly and the number seems to be disconnected. OOB I assume.
Does anyone have experience with another budget kit? My brakes are terrible!
chrisflstf
chrisflstf is offline
PostPosted: Fri Nov 07, 2025 10:27 am    Post subject: Re: Saco Reply with quote
Here you go. Best brake kits. No third world country parts. Easy install
https://type-emotorsports.com/collections/type-2-b...-brake-kit
sub-hatchtim
sub-hatchtim is offline
PostPosted: Fri Nov 07, 2025 11:24 am    Post subject: Re: Saco Reply with quote
I believe saco is no more
Go type e, no proprietary wear items
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Nov 07, 2025 12:02 pm    Post subject: Re: Saco Reply with quote
More about it here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...6f40be7bff
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
SolarPoweredPickles
SolarPoweredPickles is offline
PostPosted: Sun Nov 09, 2025 4:32 pm    Post subject: Re: Saco Reply with quote
Another vote on Type-E, I have them on all 4's. Buy once cry once they say!
I had front disc Saco on my previous bus some years ago (2014) And they were returned due to several issues that were missed lack of quality control. I can't recall what the issue was with Saco but remember them being pretty poor quality and could not even finish the install, machining issues if I remember correctly, not something you want in brakes.
Vintage problems require vintage excuses.
matthew henricks
matthew henricks is offline
PostPosted: Mon Nov 10, 2025 11:13 am    Post subject: Re: Saco Reply with quote
Not sure you mentioned what year your bus is. I think that also limits your options. (I did my research about 5 years ago)
I have kits on both my 59 and 65. Both great upgrades. I personally wanted wide-5 rims and I did not want to change my wheel offset. If you care about these then i found the options where limited.
If you do not care about these then there were more options that did not tie you into vendor specific wear parts.
I am using EMPI for the 59 and So Cal Imports for the 65. Both "affordable" and easy to install.
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
crofty
Judas of the North
crofty is offline
PostPosted: Mon Nov 10, 2025 2:01 pm    Post subject: Re: Saco Reply with quote
Sunsong is chinese and Timken manufactures bearings in the USA, Mexico and China.
HamburgerBrad wrote:
chrisflstf
PostPosted: Mon Nov 10, 2025 6:42 pm    Post subject: Re: Saco Reply with quote
Ask somebody who has a saco disk brake kit where are they going to get a rotor or caliper now? Laughing
Type e kits you can get replacement parts from napa, amazon, rockauto, autozone, oreillys, etc. Gm made millions of those rotors, calipers
NUTSFORBUSES
NUTSFORBUSES is offline
PostPosted: Tue Nov 18, 2025 4:46 pm    Post subject: Re: Saco Reply with quote
Yeah, Saco is gone.
I still run their front Disc's and they are great. Still have extra pads in a box.
Good stoppers, but you can't get them.
They actually made them, and the calipers. Pretty trick looking stuff.
If I ever need new one's (DOUBT IT) I'll have to go another direction
I do have the China versions in the rear though/IRS.
SACO was High Performance sand stuff, and the Bus stuff was built just like the racing brakes.
I just don't drive the Bus enough to wear them out.
I don't think all that GM stuff is made here, but the SACO was all American Made, and Zero issues fitting them like some brakes I've done. SACO have bleeders at all 4 pots
kaiser kills kids.com
