RicMcK  Samba Member
Posted: Mon Nov 10, 2025 9:09 am Post subject: Vanistan Seat Tilt Kit install? |
I'm looking for advice on installing a Vanistan Seat tilt kit in a 89 westy. I'm looking for advice from anyone who has done this modification and any photos you might have.
I'm scared about getting out the angle grinder and cutting things out as it is a one way street.
I want to do this modification to access the space under the to add charge controller ... and or LiFe battery electronics. I will put this on the left seat (I know I will need to slide the seat off to be able to tilt the swivel up). _________________ Rick McK
Seattle
89 Westfalia-2.2L WBX "VINNY"
2006 TDI Jetta
1936 Ford Pick up
70 tin top, 700k mi when sold in 91
58 split window bug - (first car) long gone. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4635 Location: ABQ NM USA.... Except when not
Posted: Mon Nov 10, 2025 9:11 am Post subject: Re: Vanistan Seat Tilt Kit install? |
I've done this install on a passenger seat.
Have you asked the vendor? if so, what did Chris say? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
jlrftype7 Samba Member
Posted: Mon Nov 10, 2025 9:34 am Post subject: Re: Vanistan Seat Tilt Kit install? |
Has anyone posted a YouTube Video on doing the kit yet? I haven't searched for you, was just wondering out loud.  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10901 Location: Western WA
Posted: Mon Nov 10, 2025 12:02 pm Post subject: Re: Vanistan Seat Tilt Kit install? |
| RicMcK wrote: |
Not true. Cuts can be re-welded. Especially under the seat. Nobody is going to judge you for what they cannot see under the seat.
Except I will likely receive judgement because I was perhaps a little too enamored with my mod. I made my (passenger) seat tip sideways and have since come to realize that tipping forward is (likely) better. So I’m gonna cut that sideways stuff off and redesign for forward. Then I’m gonna find out if I like it better.
| RicMcK wrote: |
| I want to do this modification to access the space under the to add charge controller ... and or LiFe battery electronics. I will put this on the left seat (I know I will need to slide the seat off to be able to tilt the swivel up). |
I recommend that you cut the swivel off, then make it simply “bolt on”.
With easy access to the bolts.
I suspect unbolting could be easier than sliding the seat off the track.
There’s something to be said for doing the same mod on the passenger side too. _________________
....KTMs, GasGas, SPOT mtb |
Rorke Samba Member
Joined: August 04, 2016 Posts: 289 Location: Traverse City, MI
Posted: Wed Nov 12, 2025 4:58 pm Post subject: Re: Vanistan Seat Tilt Kit install? |
I installed one on the passenger side.
It was possibly the most unnecessarily challenging projects I have experienced.
I emailed rewritten directions that I thought might help future installers. My edits were not well received or even discussed. I even offered to make a video of the proper install being done on my driver’s side.
I think the genuinely constructive criticism hit on a bad day. But i also got a bit frustrated and said fuck this.
Sorry I deleted my notes. They are probably in an old email or maybe on facebook vanagon technical depository group.
I do like having the space because I moved my start battery elsewhere. Then I metered that space with the under seat storage. It is the only solution I ever found for a huge cast iron pan.
Good luck. Reach out if you still need a hand. (Lots of guys have helped me plenty and I owe) |
RicMcK  Samba Member
Posted: Wed Nov 12, 2025 5:33 pm Post subject: Re: Vanistan Seat Tilt Kit install? |
So From what I understand this is were I should cut the pedestal (white lines). does this look correct? The extra holes in the pedestal are to see and mount my BlueSeas battery isolator/switch.
Seattle
2006 TDI Jetta
1936 Ford Pick up
Rorke Samba Member
Posted: Fri Nov 14, 2025 2:01 pm Post subject: Re: Vanistan Seat Tilt Kit install? |
Rick,
Those lines are correct.
Here are tips.
You must grind as close to the track tabs as possible, even if you shave a little
off the inside of each tab, that is better than leaving too much extra on the van.
I used a grinder. I wish that I used a tool with a finer kerf. Not sure that term is the right one. But I wish I removed less material with the cut itself.
Ultimately, the base that you are removing must be cut to be as WIDE as possible. If it is cut too narrow, then when you mount the hinges, you will need to add spacers to the hinges that connect the mount to the base.
I did not know this, so I started to straighten my sides (removing even more material) then I said…maybe I should fit this first, then uninstall to clean up and paint. Good thing I did that.
You can see in the photos that I cut the base too narrow because I figured it was a rough cut. The directions were not clear as to why or where the cut should be.
If this helps you, I will be all stoked up.
RicMcK  Samba Member
Posted: Fri Nov 14, 2025 6:44 pm Post subject: Re: Vanistan Seat Tilt Kit install? |
ROKE. THANK YOU for the Great advice, including the videos and photos. I'm planning on using the thinnest cut off blade I can find to cut the welds out. I see the importance of trying to keep the base plate as wide as possible. And it's great to know the washer- spacers thing worked, in case it is too narrow.
Thanks a bunch _________________ Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
Sodo Samba Member
Posted: Fri Nov 14, 2025 11:47 pm Post subject: Re: Vanistan Seat Tilt Kit install? |
Don't shoot sparks at carpet.
Each spark will melt several thread loops and you will make a bald-spot instantly.
I used videos from GoWesty website how to cut out the swivel. _________________
16CVs Samba Member
Joined: February 22, 2004 Posts: 4305 Location: Redwood City, California
Posted: Sat Nov 15, 2025 11:25 am Post subject: Re: Vanistan Seat Tilt Kit install? |
I was at Go Westy years ago buying sone parts for my Westy conversion and one of the items was a base for a seat rotater. They actually had a plywood shield built that drops in place while they use a cutoff wheel to syoo sparks from hitting the carpet and glass. _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
RicMcK  Samba Member
Posted: Sat Nov 15, 2025 11:57 am Post subject: Re: Vanistan Seat Tilt Kit install? |
Thanks for the heads up about the sparks. I will do my best to cover up the carpets before I at it. _________________ Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
Rorke Samba Member
Posted: Sun Nov 16, 2025 7:32 am Post subject: Re: Vanistan Seat Tilt Kit install? |
I set up some cardboard boxes and damp towels. All around. Cover everything in site so it's not a concern and you can concentrate.
I skipped some basics about grinding like spark protection. But since this might get searched years from now by a beginner, here are other pointers.
Wear safety glasses. If the wheel dismantles, fragments travel faster than any Vanagon ever has. Gloves with wrist coverage is a good call for this reason too.
It's a good idea to keep the guard on. Although, it is a pain at times. I don't even know where mine is.
Use the proper wheel for the job.
Ideally, cut so the wheel pulls along the cut.
Let the wheel spin up before cutting. Pull away from the steelbefore slowing down.
Cut for 5-10 seconds, then cool for 2-3 seconds. Use light pressure. It's not a handsaw.
Two hands are better than one. Even though the tools are light, it can kick. |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2236 Location: Bulli Klinik, Colorado Springs
Posted: Sun Nov 16, 2025 7:58 am Post subject: Re: Vanistan Seat Tilt Kit install? |
Don't forget to cover the glass as well. _________________ PM me about quality metal-work on your vehicle.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Mon Nov 17, 2025 10:51 am Post subject: Re: Vanistan Seat Tilt Kit install? |
| 16CVs wrote: |
| I was at Go Westy years ago buying sone parts for my Westy conversion and one of the items was a base for a seat rotater. They actually had a plywood shield built that drops in place while they use a cutoff wheel to syoo sparks from hitting the carpet and glass. |
I've seen that Plywood shield in their Video for working with the Seat Base/Swivel system...  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 615 Location: Chicago, IL
Posted: Mon Nov 17, 2025 11:19 am Post subject: Re: Vanistan Seat Tilt Kit install? |
| Rorke wrote: |
All good advice, but I'd add to use a face shield if you have one. your eyes are not the only think you'll want to protect from those sparks. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
RicMcK  Samba Member
Posted: Mon Nov 17, 2025 2:12 pm Post subject: Re: Vanistan Seat Tilt Kit install? |
Thanks for all the advice, it's bee super helpful.
It was a success
I taped off the carpet around the Pedestal
Made a cardboard box to fit as best I could
Used the thinnest cutoff wheel I could find
Went SLOW
It wasn't perfect, but good enough The left hinge is not as straight as I would like it, but it seems to work fine.
Now I need to clean everything up, paint, final assembly, wringing upgrades (Blue Seas 120A breaker, and new cable), 12V relay for fridge setup.
Next, will be lengthening (deeper) the battery box.
Seattle
2006 TDI Jetta
1936 Ford Pick up
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19129 Location: Retired South Florida
Posted: Tue Nov 18, 2025 4:22 am Post subject: Re: Vanistan Seat Tilt Kit install? |
| RicMcK wrote: |
It was a success
Went SLOW
I don’t remember the driver’s swivel in our 82 camper being so welded in. Because I was removing my swivel, it was very important not to damage the factory seat tracks. I’m remembering maybe 4 stitch welds near each corner. Maybe it was changed in production. |
Kdj Samba Member
Joined: January 28, 2017 Posts: 341 Location: Naptown
Posted: Tue Nov 18, 2025 8:00 am Post subject: Re: Vanistan Seat Tilt Kit install? |
| Post some pictures when you get seat installed. Interested in how far it will tilt forward before hitting steering wheel. That will be a great use of space. |
Rorke Samba Member
Posted: Wed Nov 19, 2025 9:19 am Post subject: Re: Vanistan Seat Tilt Kit install? |
Rick,
Very nice job.
It your seat swiveling smoothly?
Mine has clearance issues. So I have to really force-tilt the seat to clear.
I feel like I have many hours to go on this install. All of which could have been avoided with improvements to the instructions and a slight modification to the product. Overall, it is clever and functional. Surely, anyone could do a very nice job on their third install. Haha. |
Posted: Wed Nov 19, 2025 10:09 am Post subject: Re: Vanistan Seat Tilt Kit install? |
Is it my eye? The parts don’t appear square to each other. Also, is this mod DOT approved? In an accident it is important the seat doesn’t detach. The restraint system depends on the seat being secure. |
