dbeeby Samba Member
Posted: Fri Nov 28, 2025 4:22 pm Post subject: Lower Ball Joints - help please? |
Hello folks.
I'm trying to do the upper and lower ball joints on my 2003 EV. I have the correct tools to do the upper ball joints. I tried to use this PITTSBURGH 3/4 in. Ball Joint Separator but the tool snapped. So I rented a C-Clamp style ball joint tool from the local auto parts store, but I can't figure out how it can work on the lower 'joints.
I've removed the splined bolts. All I have to do is "press" the old ball joint out.
I have a jack, the C-Clamp tools, a propane torch, and a jack. Anybody have advice for me about how to press out this lower ball joint?
Thank you! |
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 985 Location: France
Posted: Fri Nov 28, 2025 4:30 pm Post subject: Re: Lower Ball Joints - help please? |
| If it's rusted in there, try some heat followed by cold water to break the bond.. |
dbeeby Samba Member
Posted: Fri Nov 28, 2025 5:20 pm Post subject: Re: Lower Ball Joints - help please? |
| Nitramrebrab72 wrote: |
Oh it's rusted in there @Nitramrebrab72. I'll return the clamp press and see if they have a pickle fork and then I'll try the heat + cold. Thanks for the advice. |
dbeeby Samba Member
Posted: Fri Nov 28, 2025 7:45 pm Post subject: Re: Lower Ball Joints - help please? |
I give up for the night. I put as much pressure as I could on the lower ball joint with a jack under the loosened bolt, gave it about 10 minutes of propane, and hammered the pickle fork (OEM 20720) as far as it would go (see pic below). It just will. not. pop. I might have to replace the control arms to finish this repair! Any other advice?
Saturn Samba Member
Joined: April 06, 2019 Posts: 265 Location: San Francisco
Posted: Fri Nov 28, 2025 11:28 pm Post subject: Re: Lower Ball Joints - help please? |
| dbeeby wrote: |
| I give up for the night. I put as much pressure as I could on the lower ball joint with a jack under the loosened bolt, gave it about 10 minutes of propane, and hammered the pickle fork (OEM 20720) as far as it would go (see pic below). It just will. not. pop. I might have to replace the control arms to finish this repair! Any other advice? |
5-some years ago I did the ball joints on my 1995 EVC and I also used a pickle fork as part of the removal of the ball joints. (https://www.thesamba.com/vw/forum/viewtopic.php?p=9650195#9650195)
One thing to note about pickle forks is there are multiple sized forks. I have a "smaller" fork which I use for tie rods and the "larger" one I used on the ball joints. With the larger one, the forks are wider apart and it has taller profile. Wondering if you are using the smaller type which is not clearing the mounting shaft or not providing enough leverage to push up the base of the ball joint. Something else to try is striking the shoulder surrounding the lower ball joint with two hammers/sledges at the same time, a 180 degrees apart. I have done that approach with tie rods before when not having a pickle fork available.
trunnion Samba Member
Joined: January 08, 2024 Posts: 80 Location: SF Bay Area, California
Posted: Sat Nov 29, 2025 8:57 am Post subject: Re: Lower Ball Joints - help please? |
| Air hammer pickle fork and a propane torch got it done for me. Pair it with as big of an air hammer as you can afford. I had to blast it for about 5 minutes before it finally came apart. |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 510 Location: Asheville, North Carolina
dbeeby Samba Member
Posted: Yesterday 10:12 am Post subject: Re: Lower Ball Joints - help please? |
Thanks for all of the advice folks. I took it to a local shop so that they can free it with their proper air hammer.
I also have a question about the upper balljoints' control arm on this thread. If anyone has feedback it'd be much appreciated: https://www.thesamba.com/vw/forum/viewtopic.php?p=10459956#10459956 |
dbeeby Samba Member
Posted: Yesterday 10:18 am Post subject: Re: Lower Ball Joints - help please? |
Shoot, @EuroTec, I wish I'd seen your post last week before I took it to the shop (I failed to refresh). I did try with the Harbor Freight version of this tool, but it just snapped. Is the ReluxGo tool 100x better than the HF one? |
Posted: Yesterday 10:57 am Post subject: Re: Lower Ball Joints - help please? |
If the wishbone nuts come loose easily , remove the wishbone and put it on a hydraulic press,
T3 ball joint threaded press could of been useful. |
