Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Sat Jun 24, 2006 8:21 am Post subject: |
Karl wrote: |
2) the two wires that come out of the FI harness right past the bend by the air filter go NOwhere on a USA bus. They would have gone it a high altitude switch on a European bus. |
I coulda sworn that was the timing sensor for the VW diagnostic tester that goes to the inductance pick-up that is pressed into the crankcase right half just behind the flywheel.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
Duncwarw Samba Member
Posted: Sat Jun 24, 2006 7:15 am Post subject: |
Why not just replace the isolator. It has an advantage over the relay as the batteries are "isolated". _________________ “To find yourself, think for yourself”
Socrates, 470 BC - 399 BC |
twinfalls Samba Member
Joined: November 21, 2003 Posts: 2133 Location: France
Posted: Sat Jun 24, 2006 6:00 am Post subject: |
Quote: |
If I am reading my wiring diagram right, it goes to the D+ terminal on the alternator. Where on the alternator is this located? |
On a 1974 Westy it taps D+ at the regulator. I hope you have an external regulator.
Wiring: See germansupplyscott post, from:
http://www.thesamba.com/vw/forum/viewtopic.php?t=173265&highlight=aux+battery+relay _________________ Stock 1974 US Westy, AW-A 1800cc dual carbs. Twin Falls is my favorite site on the Churchill river in Manitoba.
Boots Samba Member
Posted: Sat Jun 24, 2006 5:51 am Post subject: |
Thanks Karl. A lot of things in my bus were just randomly connected (the oil pressure wire went to the tach connection on the coil). It's good to know I can forget about those two.
I think I have the first question figured out. The red wire was cut just inside the shrink wrap, so I just hooked back into it.
Dave |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Wed Jun 21, 2006 6:43 pm Post subject: |
Boots Samba Member
Posted: Wed Jun 21, 2006 5:14 pm Post subject: Two semi-urgent wiring questions |
Ok,
I am trying to get my bus ready for a big trip in about a week, and have two wiring questions for anyone out there.
First the vehicle is a 77 Riviera FI 2.0L
1) I am trying to replace my original isolator with a relay, since the diodes are shot. The isolator is a 4 prong. Each battery has one, there is one for the alternator, and one connected to the red wire from the regulator. To wire in the relay, I just need to connect the two battery cables, and wire in the blue idiot light wire. The alternator wire goes back to the primary battery. (Correct me if I am wrong on this). My question is where does the red wire connect to? If I am reading my wiring diagram right, it goes to the D+ terminal on the alternator. Where on the alternator is this located?
2) Ok second question. While poking around trying to fix the first question, I noticed I have two unconnected wires from my FI control unit. There is the big thick insulated group that runs to the injectors, a single wire running to the ignition coil, and then two that just end. Where on earth do they go to?
Thanks for any help you can provide.
Dave |
