Garage air conditioning, who's done it? Pictures?
tom62
tom62 is offline
PostPosted: Tue Jul 18, 2006 11:48 am    Post subject: Reply with quote
I have a 22x 20 metal shop out back with a 16 ft garage door
I put 2 inch double density styrofoam panels in the walls and ceiling 100ft of florecent lights a 200 amp service and a 2 ton split system a/c system that i bought used I mounted the air handler on the wall set the condencer unit out back and ran copper tubing tom it
it also has telephone, dish network satelite tv , stereo,and a small frig.
If I had a john and a computer out there I could live in my "doghouse" if needed Very Happy
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Tue Jul 18, 2006 9:03 am    Post subject: Reply with quote
Wait until October, the crackheads will be selling their window A/Cs for next to nothing on Craigslist. Pick one up then.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Jul 17, 2006 10:19 pm    Post subject: Reply with quote
notchback wrote:
wcfvw69 wrote:
flatfour wrote:
Mine has a central air vent in the garage. It is great, it is 100 degrees outside and 68-70 degrees inside. Cool
I hate you!!! Very Happy
To be honest I am thinking the same thing. Get a quote or two to install central air in it. Its already insulated top, side, etc and sheet rocked. I have looked at Lowes, Home Depot for portable a/c units and they look weak for $500.
My latest strategy is to buy a good window unit for $200 that will cool the entire garage and mount it inside hooking a duct up to it for the hot air to go outside. There are already vents cut out in the wall. I can't frame a hole due to lovely HOA rules (not that I would do that anyway).
NO, I don't live in my garage...LOL
Other solutions, ideas out there??
I have one of those in my living room. 10,000 BTU and it does an OK job. My garage on the other hand, has an Avenvger Portable Cooling System, the CAP 30 model.
http://www.coldair.net/body_avenger.html
30,000 BTU's of cooling power. It only cost me $75 at an auction. It came from a state office building and was hardly used. Keeps my work area down to 75 or so. That's with an uninsulated ceiling. It vents out through a window. I can pull the vent out and close the window at night.
Notch- THAT'S WHAT I NEED! I wonder what they cost new? $75 at auction, I am so jealous... Thanks for this post!
George, right now it's monsoon season here and brutally humid (for Arizona). The swamp cooler does not work at all right now. Agree with your thoughts about fumes but I could easily go outside to spray. Very Happy
The Samba member since 2004.
plasticman1432
plasticman1432 is offline
PostPosted: Mon Jul 17, 2006 9:49 pm    Post subject: Reply with quote
Mine too, although it's more like 75 in mine. Cool
Organized people are just too lazy to look for stuff
'68 Meyers Manx: M1689D815E
http://public.fotki.com/VWDave/
GeorgeL
GeorgeL is offline
PostPosted: Mon Jul 17, 2006 9:34 pm    Post subject: Re: Garage air conditioning, who's done it? Pictures? Reply with quote
wcfvw69 wrote:
I am curious as to what means people have gone through to keep their garage's tolerable in the summer to work in. Living in Arizona my garage is a toasty 95 degrees through the summer and a small swamp cooler isn't cutting the mustard.
Post up what solutions you have done to make your garage livable during the summer with pictures if you have them. Very Happy
Thanks!
In Arizona you have low humidity, so what you really need is a bigger swamp cooler. Get a 4000CFM side draft cooler with a 1/2 HP motor and mount it in a window. With 15% humidity, you can get as much as 30F temperature drop. That'll keep your garage nice and cool.
Remember, you have to have airflow across the space for a swamp cooler to work well. You need to open a door or window on the opposite side of the space from the cooler. Those portable ones that sit in the middle of the work area don't work well because they don't draw fresh air.
You really don't want your garage to be tight enough for effective air conditioning, since you don't want to recirculate all those nasty fumes that you create with gasoline, carb cleaner, etc. Better to flow the air through the space and keep it fresh.
I'm in SoCal, which isn't quite as good for swamp coolers, but I still use one exclusively. Right now we have a rather high 59% humidity and the swamp cooler is still making a 10F drop and putting out 68 degee air.
I have central air, but I seldom run it. It sucks too much electricity.
George
notchback
Insensitive Jerk
notchback is offline
PostPosted: Mon Jul 17, 2006 9:15 pm    Post subject: Reply with quote
zeen wrote:
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point.
FU#3
vwdmc16
vwdmc16 is offline
PostPosted: Mon Jul 17, 2006 8:49 pm    Post subject: Reply with quote
you lucky Bastards Sad
I REALLY need A/C too but a sufficent A/C unit would cost over $400. maybe for my next house
"Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Jul 17, 2006 7:28 pm    Post subject: Reply with quote
coW
coW is offline
PostPosted: Mon Jul 17, 2006 6:36 pm    Post subject: Reply with quote
Wow.. AC in a garage - that would be great!
Today was 99, high humidity.
I am curious now too: who has one, then?
Major Woody
Samba Enigma
PostPosted: Mon Jul 17, 2006 3:59 pm    Post subject: Reply with quote
The back of the garage at our old house used to face the garden, which was not really visible from the backyard. So we cut a hole in the garage, framed it like a window, and permanently mounted a window-style A/C unit. We left it in year round and it was never a problem. Just put the pegboard up right around it. Kept the garage nice and cool. Be sure to insulate, or it will never get comfortable in there. That garage had heat, too.
No A/C in the new garage.
flatfour
flatfour is offline
PostPosted: Mon Jul 17, 2006 3:53 pm    Post subject: Reply with quote
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Jul 16, 2006 9:27 am    Post subject: Garage air conditioning, who's done it? Pictures? Reply with quote
Thanks!
