djporsche Samba Member
Posted: Tue May 01, 2007 10:31 am Post subject: |
R.Rabbit wrote: |
talk to Luis with the white 64 (he's an Aircooler in San Antone) - I just sent him about 3 PMs referencing this exact thing with options |
Yeah I’m going to help Louis, Thanks |
vwfye Samba Member
Posted: Tue May 01, 2007 10:23 am Post subject: |
i have a notchback that is that way, but with t1 rear brakes (PO mod) and there are some issues he didn't address.
1) if you run short axles with the bug rear brakes you need a brake bias valve installed!!! i found out the hard way when the fronts locked up on a wet roadway. t3 rear brakes are BIGGER, so the bug brakes unbalance the car's ability to stop under control.
2) the brake lines for the bug rear end are shaped different, so you will need a tubing bender to reroute them.
remember, this is only for if you do a bug axle/tranny swap w/ bug brakes. _________________ 64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK" |
R.Rabbit Samba Member
Posted: Tue May 01, 2007 9:58 am Post subject: |
talk to Luis with the white 64 (he's an Aircooler in San Antone) - I just sent him about 3 PMs referencing this exact thing with options _________________ Opportunity may knock only once, but temptation eff' leans on the doorbell!
SBS #5
'54 RHD Swedish 3-fold
'60 L345 Doppelkabine |
69sqbck Samba Member
Joined: August 12, 2004 Posts: 311 Location: Savannah, GA
Posted: Tue May 01, 2007 5:55 am Post subject: Axles |
Check this link:
http://hoodride.com/phpBB2/viewtopic.php?p=128023&highlight=#128023 _________________ Don't think of yourself as an ugly person, think of yourself as a good looking Monkey!!!!!
1968 Ghia Vert
1969 Type 3 Squareback
1969 Type 3 Fastback
(o)\|/(o) Sole Designs, VW Restorations, Savannah, GA |
Posted: Tue May 01, 2007 4:30 am Post subject: switching the type 3 axels to type 1 |
Trying to find info on switching the type 3 axels to type 1, I've be looking all night still no luck. All I need is a link or 2. Thanks |
