T4 J tubes?
melville
melville is offline
PostPosted: Fri Mar 28, 2008 9:18 am    Post subject: Reply with quote
dansvans wrote:
what is it about 411/412 boxes that are different? no fins? rusted out? what?
No fins. Saves you the trouble of torching off the aluminum heat sink.
2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan
Blaubus
Blaubus is offline
PostPosted: Fri Mar 28, 2008 9:10 am    Post subject: Reply with quote
Collie
Collie is offline
PostPosted: Fri Mar 28, 2008 5:31 am    Post subject: Reply with quote
To eliminate the heater boxes on a type4 engine is easy.....
Find a set of 411 or 412 heater boxes and you have instant J-tubes that fit perfectly......
I have been running these for years on my '77 2.0
XXX/Rx/RnR
XXX/Rx/RnR is offline
PostPosted: Fri Mar 28, 2008 3:03 am    Post subject: Reply with quote
On my 78, I made flanges & welded a pipe in. Lite 4-2-1 with the S&S header I have. Everything to do with cabin heat on my bus has been removed, Y-tube, flapers, ducts. Stock is too much weight!
tommytoots
tommytoots is offline
PostPosted: Thu Mar 27, 2008 1:37 pm    Post subject: Reply with quote
http://www.europeanmotorworks.com/pvw/204-100/type-4-exhaust/72-78+Bus+Heater+Box+Repl.+Pr.
Will these work because i'm thinking of doing away with my heat exchangers aswell..
Tom
It is impossible to travel faster than the speed of light, and certainly not desirable, as one's hat keeps blowing off.
DaKine
DaKine is offline
PostPosted: Wed Nov 07, 2007 10:29 am    Post subject: Reply with quote
I bought a pair from 'EUROPEAN MOTORWORKS' 13224 Prairie Ave, Hawthorne, CA 90250 (310-644-8038) back in '03 (they call 'em heater box elimination pipes). They bolt up to the head just like the pic that is posted. They have a local guy fab them up...cost me $165 for the pair (raw). They fit and work good. Dunno if they have a web site...
65Notch
65Notch is offline
PostPosted: Wed Nov 07, 2007 7:29 am    Post subject: J tubes Reply with quote
http://www.laperformance.co.uk/ or http://www.turbothomas.com/
Hope this helps
nodrenim
nodrenim is offline
PostPosted: Fri Oct 19, 2007 5:12 pm    Post subject: Reply with quote
You might want to check out a 911 or 914 Porche exhaust system for a set of header type manifolds. They are really neat and should work just great for your needs. Good Luck!
Patrick199
Patrick199 is offline
PostPosted: Fri Oct 19, 2007 12:07 pm    Post subject: Reply with quote
Does anyone have a crappy set of 75-78 heater boxes they would be willing to cut the flanges off of and sell them to me?
I have a crappy set of heater boxes but the flanges are pretty crappy too.
Doesn't German Supply sell flanges?
gmag69
Type2 Nutcase
gmag69 is offline
PostPosted: Fri Oct 19, 2007 4:37 am    Post subject: Reply with quote
autiger78 wrote:
Hey Gmag, I'll trade you my crappy boxes for your decent ones Laughing
I'd probably think about it if I wasn't going to keep them. I haven't checked them all over but the heatexchangers look good from what I've seen of them anyways. If I make the tubes I'll probably clean them up and put them in my parts stash for later use.
Check out my Westy resto. thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=230285
autiger78
autiger78 is offline
PostPosted: Thu Oct 18, 2007 7:54 pm    Post subject: Reply with quote
Wanted - Dormobile Roof Parts!
gmag69
Type2 Nutcase
gmag69 is offline
PostPosted: Thu Oct 18, 2007 6:22 pm    Post subject: Reply with quote
What I was thinking of doing was just making a pipe with flanges on it to go between the elbow that I already have there and the muffler. I need to redo the gaskets from the end of the header back anyways so I could do it then.
Does anyone have a crappy set of 75-78 heater boxes they would be willing to cut the flanges off of and sell them to me? My heaterboxes are in decent shape and I don't wanna cut them up as I may put the stock heating system back in someday if I get ambitious enough to replace the Y pipe.
Duncwarw
Duncwarw is offline
PostPosted: Thu Oct 18, 2007 4:18 pm    Post subject: Reply with quote
They're apparently available in the UK.
“To find yourself, think for yourself”
Socrates, 470 BC - 399 BC
LeeE
LeeE is offline
PostPosted: Thu Oct 18, 2007 1:16 pm    Post subject: Reply with quote
I've had this photo for a while, but I have no idea who makes them
1978 Westfalia stock 2.0 FI
Welcome to the Okeedokee Swamp
Patrick199
PostPosted: Thu Oct 18, 2007 12:47 pm    Post subject: Reply with quote
I would like to do the same thing because my heater doesn't work and it never will. I've never seen J-tubes for a type 4 either. Someone makes them for a Type 1, just like everything else. Those Type 1 guys are lucky.
I suppose if a guy was a good welder he could make some, or modify the type 1 j-tubes. I think it's just a matter of having the correct flanges,but there is probably more to it than I realize.
gmag69
Type2 Nutcase
gmag69 is offline
PostPosted: Thu Oct 18, 2007 1:03 am    Post subject: T4 J tubes? Reply with quote
I've been looking around and haven't seen where anyone makes J tubes for T4 engines. Does anyone make these? I've been thinking of doing away with my heaterboxes cause my Y pipe that goes over rear tranny mount x member is rotted out on the Westy and it is a pita to get out and replace.Also my flapper boxes are all rotted out too so they would need replaced also. I'm thinking about installing a propane or gas heater and ducting it into the stock system at a later time anyways. I don't drive my bus in the winter so I really wouldn't need heat anyways.
I would like to get some feedback on this so any comments are welcome.
By the way my engine is a 78 T4 F.I. with the stock heater boxes.
Geno Very Happy
