2.0 compression
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Aug 22, 2002 8:50 pm    Post subject: 2.0 compression Reply with quote
No prob...
Hope it turns out good for you... if it is a "fresh" rebuild it should be up there...
westy78
westy78 is offline
PostPosted: Wed Aug 21, 2002 4:23 pm    Post subject: 2.0 compression Reply with quote
Thanks Keifer, thats what I was looking for.
keifernet
PostPosted: Wed Aug 21, 2002 6:53 am    Post subject: 2.0 compression Reply with quote
125+ would be good, look for consistencey in all 4 cyls. check it slightly warm and with the coil HT lead off and the throttle OPEN.....
chillz1
chillz1 is offline
PostPosted: Tue Aug 20, 2002 7:55 pm    Post subject: 2.0 compression Reply with quote
Anything under 90psi is too little. The lowest clinder should also be within 10% of the highest. Ex. If the higest cylinder is 100psi, then the lowest should be 90psi.
westy78
westy78 is offline
PostPosted: Tue Aug 20, 2002 7:45 pm    Post subject: 2.0 compression Reply with quote
Thanks for the info. Do you know what a fresh 2 litre would have for compression? Im just trying to get a comparison to see how tired the motor is.
westy78
westy78 is offline
PostPosted: Tue Aug 20, 2002 7:44 pm    Post subject: 2.0 compression Reply with quote
I have searched all over but can not find the correct cylinder compression that a 2000cc motor should have. I may be buying an 81 Westy and would like to know. Anyone have the answer?
Thanks
JC
