atrujillo1991 Samba Member
Posted: Wed Jan 14, 2009 9:58 am Post subject: |
I take back EVERYTHING i said about not rubbing up front 2 inner clicks down. The car was resting completly on the bump stops
THey were removed and now the beast rolls like a pig again and the front RUBS like whoa. A little more than one turn of the wheel (out os 2-ish turns from center to lock) will make it rub. The front right is at 22" 1/3 inches and the front right is at something like 22". I need to index the car UP all around. in order to keep it daily drivable. It's DRIVEABLE as is now just parking's a beeach.
The rear is down one outer and I'm not rubbing at all. the car is a tad lower in the rear and the right is about 1/4 of an inch higher than the left (because of the front being a tad off I'm assuming?)
I'm going to make some tuning adjustments and hopefully bring the car up about an inch. _________________ '72 OG Square
'87 Montana Green GTI- EX 3.0L
'92 GTI- 16vABAt 450+WHP
'96 Celebration Jetta- 16vABA |
izac Samba Member
Joined: October 20, 2008 Posts: 93 Location: Brisbane, Australia
Posted: Thu Jan 08, 2009 7:33 pm Post subject: |
gixxer 711 wrote: |
i know this sounds funny, but often times a 195/50-15 will look wider than a 195/65, 195/70 and such. i would go 145/65-15 or 175/55-15 front if you want to go with the 195 rear.
with those wheels and offset, i bet you will only be able to get a 195/60-15 at best on the rear, def not the taller tires.if you had a swing car and do the short axle conversion, it would be no problem, but dropped on an irs, probably gonna rub. |
so much to think about
yeah i have a 65 swinger and am doing the short axle swap before i buy the new tyres... so theoretically the rears should be no problems..
i might look a t getting some 185/55s for the front as the 175s seem to be hard to find in that profile over here and the 145s are too skinny for my liking (i have 135s atm so am looking for a much wider contact patch) |
spoon Samba Penetrator
Joined: September 08, 2005 Posts: 1458 Location: Monterey, CA
Posted: Thu Jan 08, 2009 4:36 pm Post subject: |
I'm running 195/55's rear and 50's front. I had to roll the rear a bit and the insides of the front fenders are nice and polished.
For the front, use these shocks...
"These shocks are Monroe part no. 5752. They are replacement shocks for a 1954 Volkswagen Transporter, according to my local auto parts store computer.
These shocks are 8.5" compressed and 12.7" at full length. These shocks do not come with the metal sleeves that are usually located within the shock bushing. You will need to press the metal sleeves out of your current shocks and then press them into the new shocks. Let me know if you have any questions."
_________________ Pit Bull Myths, Busted!
http://www.badrap.org/monster-myths
EverettB wrote: |
Type 3 > Type 1 |
gixxer 711 Samba Member
Joined: August 17, 2007 Posts: 589 Location: houston, tx
Posted: Thu Jan 08, 2009 2:00 pm Post subject: |
with those wheels and offset, i bet you will only be able to get a 195/60-15 at best on the rear, def not the taller tires.if you had a swing car and do the short axle conversion, it would be no problem, but dropped on an irs, probably gonna rub. _________________ Danny |
izac Samba Member
Posted: Wed Jan 07, 2009 10:57 pm Post subject: |
do you have any pictures of the 195/50s on the car?
forgot to mention im running MWS Brms (ET+25) but i think they have around the same offset as the 8 spokes so should be alright hopefully
cheers |
izac Samba Member
Posted: Wed Jan 07, 2009 10:51 pm Post subject: |
awesome!
thanks Bobnotch
I will probably go 195/50 on the front and hopefully 195/65 or 70 (if i can get them) on the rear..
cheers |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23461 Location: Kimball, Mi
Posted: Wed Jan 07, 2009 4:06 pm Post subject: |
izac wrote: |
Bobnotch, I have my car down 2 inner splines at the front and want to get wider tyres (currently running 135 nankangs) - are you saying i could run 195- 50s up front with standard beam???
sorry just making sure before i go out and buy some and might regret it... i do find it hard to believe...  |
Yeah, you can run those with the standard beam. My son is running those on his car, with polished 8 spokes. I'm running 195-60's on my 71 Notch, and I'm also down 2 splines in front. I'm also running 205 -65's in the rear, and it's down 1 1/2 splines in the rear. I used a combination of inner and outer splines to get that drop in the rear. They really fill the wheel wells up.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Jan 07, 2009 5:47 am Post subject: |
Up front (I'm two inner notches down), with a driver, passanger, and someone sitting on the front left fender, the car rubs (as is) at full lock on the fender.
My plan is to index the front to bring it down 1/3 of an inch more and put the rear down one outer. I'm starting to need struts, though
They're not the OG shocks but they look like they're from... 1995? lol Time for some fresh shocks. Anyone have any suggestions for lowering shocks? _________________ '72 OG Square
izac Samba Member
Posted: Wed Jan 07, 2009 3:21 am Post subject: |
Bobnotch wrote: |
atrujillo1991 wrote: |
Looks like I'm just gonna GO FOR IT.
Thinkin' one outer in the front and maybe... 2 in the rear? Not really sure yet, though Guess we'll see!
Suggestions on lowering shocks? I saw Empi's a while ago that were something like $34 each but I can't find 'em any more
Two splines down (from stock) is about the limit you can run with 165's and a small amount of rubbing while turning. If you do decide to drop it some more, get some practice doing 3 point turns first, and wear ear plugs so you don't hear how loud the tires are rubbing the fenders. When my son had his down 4 splines and 165's on it, it would barely turn, and it liked to rub going straight on the freeway. He's since gone to 195-50's, and it doesn't rub. He's also on oil link pin lowered shocks for that "smooth" ride. Those who attended the '08 Invasion can tell you how low the car is. I hope this helps. |
Posted: Sat Jan 03, 2009 1:39 pm Post subject: |
Thank you! GOod to hear the voice of experience. LIke I said- I'm two inner down now and I literally have zero rubbing. I'm considering returning the inners to their original position and taking the car three OUTER down instead. Then I'll drop the rear one.  _________________ '72 OG Square
Posted: Fri Jan 02, 2009 4:18 pm Post subject: |
Two splines down (from stock) is about the limit you can run with 165's and a small amount of rubbing while turning. If you do decide to drop it some more, get some practice doing 3 point turns first, and wear ear plugs so you don't hear how loud the tires are rubbing the fenders. When my son had his down 4 splines and 165's on it, it would barely turn, and it liked to rub going straight on the freeway. He's since gone to 195-50's, and it doesn't rub. He's also on oil link pin lowered shocks for that "smooth" ride. Those who attended the '08 Invasion can tell you how low the car is. I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Buttafuoco Samba Member
Posted: Fri Jan 02, 2009 1:29 pm Post subject: |
Nid wrote: |
I'm running 135s and I rub, had to pound out the inner part of the fender a bit. Still rubs but not as bad. PO lowered an unknown number of notches.
I think he lowered it 3 inner front and 3 inner rear. he said he didnt count the splines, he just measured. |
Posted: Fri Jan 02, 2009 1:07 pm Post subject: |
Nid Samba Drama Queen
Joined: August 25, 2003 Posts: 1533 Location: Mount Shasta, CA
Posted: Wed Dec 31, 2008 7:44 pm Post subject: |
_________________ My, you've been naughty. How.....Delicious.
You're such an inspiration for the ways that I'll never ever choose to be
Oh so many ways for me to show you how your savior has abandoned you
Fuck your God, Your Lord and your Christ, he did this
Took all you had and left you this way
A Perfect Circle - Judith |
Posted: Wed Dec 31, 2008 7:09 pm Post subject: |
[email protected] wrote: |
now what pissed me off is in the rear of my 66 i was two inner or a bit more and the tire rubed the top of the inner fender well. the tire were 165. |
If i remember correctly, each inner spline gives you 9 degrees of adjustment as i think the outter gives only 8. Dont quote me on this though. I also wonder if there is a difference in wheel well clearances with early and late models. Anybody know the answer? |
vwfye Samba Member
Posted: Wed Dec 31, 2008 6:35 pm Post subject: |
like this?
you cant' really see in this pic, but the blue shows again at the outside of the wheel... _________________ 64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK" |
RennyRB Samba Textbook Gangsta
Joined: August 10, 2006 Posts: 979 Location: Torrance
Posted: Wed Dec 31, 2008 6:31 pm Post subject: |
68notch wrote: |
I would like to get those trim rings too. There are plenty of them around on the internet made from stainless steel. I have just been concerned if they will fit properly given that the type 3 rims have a smaller lip since we have a different offset to beetles. Are these trim rings going to fit our rims? |
Yeah, I've got some on my Square. They look similar enough to the trim rings on my '70 Bug, so I believe they are indeed universal. Really clean up the look of 4 lug wheels. _________________ 1967 Squareback |
Posted: Wed Dec 31, 2008 6:00 pm Post subject: |
68notch Samba Member
Joined: August 16, 2007 Posts: 545 Location: Perth, Western Australia.
Posted: Wed Dec 31, 2008 4:41 pm Post subject: |
I would like to get those trim rings too. There are plenty of them around on the internet made from stainless steel. I have just been concerned if they will fit properly given that the type 3 rims have a smaller lip since we have a different offset to beetles. Are these trim rings going to fit our rims? _________________ John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227 |
Posted: Wed Dec 31, 2008 3:57 pm Post subject: |
If you go any lower you might wanna consider maybe a 135 in the front. Im dwn 3 outter front-2 outter rear, with 135's up front and 205's rear and I can turn lock to lock and no rub in the rear.  |
