jackstar Samba Member
Joined: February 15, 2008 Posts: 274 Location: Gulf Breeze, Florida
Posted: Mon Mar 28, 2011 6:12 pm Post subject: |
Westy's have a door buzzer?!?! Who'd a thunk it. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52924 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Mar 28, 2011 3:31 pm Post subject: |
Depends how it's wired, it's odd that the buzzer shuts off the radio, tried removing the buzzer from the fuse box? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
drivenachodrive Samba Member
Posted: Mon Mar 28, 2011 3:04 pm Post subject: |
I have my stereo set up to work when the key is in the ignition, but there's a small unwanted annoyance associated with it. When I open the door, the buzzer comes on and turns my stereo off. When I close the door the buzzer turns off and my stereo turns back on. Any idea how to avoid that? Can I get rid of the buzzer and still have the stereo work when the key is in? |
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Tue Mar 31, 2009 4:10 pm Post subject: |
vwwestyman wrote: |
jamesdagg wrote: |
What you are missing is the great feature that if you put a male spade connector on the yellow switched wire from your stereo and plug it into the buzzer socket #85 from the ignition switch you will have an accessory position.
You can listen to the stereo with the engine off as long as you leave the key in the ignition. As soon as you pull it out, stereo goes off.
It's pretty easy to convert the buzzer to buzz if you forget the headlights on as well.
In fact you can do both.
Note though if you have a big high amp stereo use this wire to trigger a relay as it's a low amp circuit.
jim |
I've done that trick on more than one VW.
I could be wrong, but I don't think you'd need to relay it for just a CD player. I think that they draw all their power for running, playing, etc through the same source as the memory (usually the red wire). I think the keyed wire (usually yellow) is simply a trigger to turn on with the key, sort of a relay wire in itself. |
That sounds reasonable. Just to confuse things, some stereo's seem to have the yellow wire as the switched one, others use red.
You definitely need a relay if you have an older model where the buzzer wire is a ground.
jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5843 Location: Wamego, Kansas, USA
Posted: Tue Mar 31, 2009 12:42 pm Post subject: |
jamesdagg wrote: |
jim |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Tue Mar 31, 2009 9:09 am Post subject: |
vw76westy wrote: |
since we are talking about the wiring
i put a interior dome light in the kick panel
& i want it to turn on when the door is open
but i cant figure out how without running wires all the way to the dome light
that light will turn on when the door is open
can you help me there
i tried hooking up directly to the button on the door but it did not work |
go from +12 to a fuse (or from a fuse) to the bulb to the switch on the door (It makes ground) _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
vw76westy Samba Member
Posted: Tue Mar 31, 2009 12:29 am Post subject: |
Posted: Mon Mar 30, 2009 8:01 pm Post subject: |
Posted: Mon Mar 30, 2009 7:51 pm Post subject: |
vw76westy wrote: |
ok so now we know where to find one on a jetta
but where is it, in the bay
does it it use the same sensor button on the door
that is used for the lights to work
i want to say mine worked when i first got the bus
but that was a long time ago
(haha maybe i ripped it out then & just dont remember) |
It tells you your key is in the switch so there is a circuit there and yes your dome light ground switch makes it buzz. I pulled mine, 'stgawdawful cacophony. _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
White99z Samba Member
Joined: August 17, 2008 Posts: 735 Location: Bus hunting in the USA!!!
Posted: Sun Mar 29, 2009 10:48 pm Post subject: |
Wow... theres a door buzzer?!? Glad mine doesn't have it! |
Posted: Sun Mar 29, 2009 6:46 pm Post subject: |
1979westie Samba Member
Joined: January 08, 2004 Posts: 1093 Location: Flying this P-27 bomber
Posted: Sun Mar 29, 2009 2:50 pm Post subject: |
I've got the doo-boo-bee triple note chime in my 91 GTI. I think I'll leave it there and stick with the dying cricket for the bus. I'd like to open one up to see what the mechanism inside looks like. Ratwell must have a pic somewhere... _________________ Your car may do 0-60 in under 5 seconds, but can it sleep 4 and cook a meal?
1979 Deluxe Campmobile (quickly rusting away)
33K miles when bought, now at 61K
Proud Member #2 SBS (Stock Bus Society) |
fusername Samba Member
Joined: March 15, 2006 Posts: 2899 Location: Boston MA
Posted: Sat Mar 28, 2009 8:07 pm Post subject: |
I;m sorry but have you ever heard a vanagon door buzzer?
DOO BOO BEE
DOO BOO BEE
DOO BOO BEE
you just want to stab it in teh face 3 rounds in. sooo horrible.
soo who wants to buy mine? i carry it around in my electrical bag, to test for power like a test light, only so much more annoying, and I can hear it from farther away. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Krautski Samba Member
Posted: Sat Mar 28, 2009 7:57 pm Post subject: |
Mine works. Then again, everything except the gas heater is in working order.
The previous owner took pretty good care of it, for all the electrical shit to be working.  |
type2sam Samba Member
Posted: Sat Mar 28, 2009 6:13 pm Post subject: |
Ice Cream Truck song is a good way to describe it. 3 separate ascending notes, then repeat.
It is #12 in the fuse panel. Here is a diagram from the Fox Bentley...
Here's a close-up of the relay...
And here is a pic of it installed - notice how the end has a grille and a speaker. Pretty easy to identify.
When the IAC engineer was out last year and put the key in the ignition for the test drive, the look on his face was priceless. |
VWBusrepairman Samba Member
Posted: Sat Mar 28, 2009 4:52 am Post subject: |
type2sam wrote: |
I replaced the original door buzzer in my '73 with the door chime relay from an '89 VW Fox. Plugged right in. Somewhat more pleasant than the dying cricket. |
I had an '89 Fox! The chimes sound like an icecream truck song or something.
Is the Door Buzzer located in the fuse panel? I may try to get mine working as well, so I can spend some time with VDubtech having the key in the ignition and the door open just to hear the sound. |
Ombit Samba Member
Posted: Sat Mar 28, 2009 2:59 am Post subject: |
Door Buzzer? Mine doesn't have it. What's it for - to alert you to the door being open when setting off??
Where are the mechanics of it, I'd like to have a look and see if any of it remains. _________________ Ombit
1973 VW Deluxe Bus 1700E Automatic
Ernie - The only Automatic Bay in Cyprus |
Posted: Sat Mar 28, 2009 1:43 am Post subject: |
Mike C Samba Member
Joined: September 18, 2008 Posts: 303 Location: Albuquerque
Posted: Fri Mar 27, 2009 9:20 pm Post subject: |
The buzzer on my '70 works. I think it's pretty neat. Brings back memories of the old bus my folks had in the 70s. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Fri Mar 27, 2009 9:14 pm Post subject: |
The buzzers on my '74 and '79 both work, never bothered me. I guess I just don't spend a whole lot of time with the door open and the keys in the ignition. |
