aftermarket rods for my combo....
nsracing
nsracing is offline
PostPosted: Sat Nov 21, 2009 8:47 pm    Post subject: Reply with quote
No such thing as overkill on rods. YOu buy what you can afford if you are going to upgrade.
And if you are not going to upgrade, then I suggest take it easy abusing the engine.
Also, rods can be balanced on any tolerance. Just make sure which balance tolerance you are getting. Just because it says "balanced" does not mean much if you do not know what tolerance was put into it.
Balanced to 5 grams? Laughing Or balanced to 1/10th grams?
millerje78
Samba Amishman
millerje78 is offline
PostPosted: Sat Nov 21, 2009 5:23 pm    Post subject: Reply with quote
jakeddy wrote:
Does a set of the Eagle H beams need to be balanced?
check every part you buy, even if its from a performance shop like Berg Ent. you never know what can slip past in the shuffle.
always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry
DarthWeber
DarthWeber is offline
PostPosted: Fri Nov 20, 2009 6:25 pm    Post subject: Reply with quote
Yes.
jakeddy
jakeddy is offline
PostPosted: Fri Nov 20, 2009 6:10 pm    Post subject: Reply with quote
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Sun Apr 19, 2009 4:51 pm    Post subject: Reply with quote
In a 130 hp 1904? ARP 2000's would be overkill.... for that matter, so would 8740's. If you're only looking to make 130 hp, you have no use for the low reciprocating weight H-beams offer since you won't be spinning the engine very fast to get there. Rebuilt stock rods are all you should need, or at the most, the Unitech rods CB sells.
I have the Unitech's in my turbo 1915, trust me they can take just about anything you can throw at them. Great rods. Cool
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
DarthWeber
PostPosted: Sun Apr 19, 2009 4:30 pm    Post subject: Reply with quote
c.ruber wrote:
What about bolts? Is there and upgrade for the stock rod bolts?? I happen to have a set of GB190 rods, but they are not clearanced. maybe GB will take them on exchange, or modify as requierd?
Call Berg and see what they say. They always boast about supporting customers who buy their products. Maybe they'll rebuild them for you to GB191 specs. As for rod bolts, most consider the ARP 2000 to be the best out there.
c.ruber
c.ruber is offline
PostPosted: Sun Apr 19, 2009 3:46 pm    Post subject: Reply with quote
...and progress is not intelligently planned...
stoneloco808
stoneloco808 is offline
PostPosted: Sun Apr 19, 2009 3:36 pm    Post subject: Reply with quote
I am in the process of collecting parts for a similar combo. My first choice would have been the H-beam style rods. But I settled for a set of Berg stroker clearanced stock rods. For me I look at what the engine's primary use will be as far as choices for engine components. IMO if its going to be a daily driver with the occasional trip down the local drag strip then the stock rods should do just fine.
DarthWeber
PostPosted: Sun Apr 19, 2009 3:33 pm    Post subject: Reply with quote
c.ruber wrote:
Whose H-beams?? Eagle Scat CB ????
I'd suggest you buy from an engine builder like DRD, ACE, Brothers, etc. Reason is, the (chinese) rods will need to be checked to make sure they are within specs BEFORE you bolt them on the crank.
c.ruber
c.ruber is offline
PostPosted: Sun Apr 19, 2009 3:27 pm    Post subject: Reply with quote
DarthWeber
PostPosted: Sun Apr 19, 2009 3:14 pm    Post subject: Reply with quote
c.ruber wrote:
What if I wanted a lighter rod to keep the reciprocating mass weight down??
H beams.
DarthWeber
stealth67vw wrote:
Nothing wrong with using a stock rod in this application. A stock rod is good for 175hp and 7,500rpm.
X2. Stock rods will serve you well. Sounds like you are building a nice street motor so you don't really need the high rpm capabilities of an H beam rod. I'd go with a good set of rebuilts like from Berg or Rimco etc. Of course a new set of chinese I beams "may" cost less but I'd sure have them checked out to make sure they are within specs.
c.ruber
c.ruber is offline
PostPosted: Sun Apr 19, 2009 3:13 pm    Post subject: Reply with quote
stealth67vw
stealth67vw is offline
PostPosted: Sun Apr 19, 2009 2:17 pm    Post subject: Reply with quote
John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/
c.ruber
c.ruber is offline
PostPosted: Sun Apr 19, 2009 2:09 pm    Post subject: aftermarket rods for my combo.... Reply with quote
Which after market rod would best suit my combo?? I want to build a 1904cc, but want to use something other than the stock rod. Looking at about 130hp. H-beam,or I-beam and why? Thanks DS
