lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sun Mar 27, 2011 9:52 am Post subject: |
Properly setup Webers will give you better performance throughout the entire powerband, better fuel economy and be just as dependable as a new Edelbrock carb. Not to mention they look SOOOO SWEET! _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Sat Mar 26, 2011 12:17 pm Post subject: |
1966Corsa wrote: |
You will be much happier with a more stock four carb set up on the 140. The 4bbl set up eliminates carb sync but is starved for warm air. Rough running till they REALLY get warmed up.
Corvair fan belts should stay on just fine with proper belt |
Do you have the the secondary carbs with added idle circuits or the stock design. |
1966Corsa Samba Member
Posted: Sat Mar 26, 2011 10:26 am Post subject: |
DasVolksRodder wrote: |
i'm putting a edelbrock 4bbl equipped 140 series in my girl's 70 cabriolet and it is cammed for reverse rotation. even had the pulley and backwards stamped fan on the alternator to correct airflow and keep from tossing belts. came out of a rail buggy. IECO 4bbl kit and finned aluminum valve covers look nice, gonna freshen it up and hope to find more go-fast goodies under all the layers of paint and dirt. one thing someone forgot to do, was sell a crank with the timing marks on the other side of TDC for us VW guys!!!  |
Corvair fan belts should stay on just fine with proper belt and tension. Corvair fan belt throwing is fault of owners over tightening the belt. I have owned both stock and hopped up SCCA vairs. I have a built 140 with a hot cam and four primary carbs that revs up to 6,000 daily. Belt stays on. Trick is adjust it loose, should be able to turn alternator pulley with one finger when cold. USE a proper belt too! Clarks Corvair parts has em. |
Posted: Sat Mar 26, 2011 10:21 am Post subject: |
manxbuggy wrote: |
The Weber version might fit, I think the 4BRL setup would require some fiberglass cutouts.
Here is my Corvair powered Manx with stock carbs and low profile filters:
The stock Corvair fan belt changes direction (around the alternater and an idler pulley) to rotate the top mounted fan from the rear pulley. I think the Porsche style fan would solve the problem some Corvair engines have with fan belts not staying on their pulleys as intended. Plus it looks great!
I'll take the triple weber version please.
Rob |
Soviet1942 Samba Member
Joined: October 04, 2009 Posts: 397 Location: Miami, FL
Posted: Thu Mar 10, 2011 11:45 am Post subject: |
BL3Manx wrote: |
That's correct, the link to the ebay auction I posted has Starr Cooke's contact details. He is the individual who has the Porsche 911 shrouds for the Corvair engine as well as a lot of other Corvair performance stuff. Again, Starr Cooke in El Cajon, California has the shrouds. Its near San Diego. |
Ahh okay thanks. I saw pistons and was like
edit: found it. Thanks so much. _________________ 1970 Adventurewagen Hightop "Penelope"
-Soon to have Focke Wulf 190 theme- |
Posted: Thu Mar 10, 2011 8:42 am Post subject: |
Posted: Thu Mar 10, 2011 2:48 am Post subject: |
For a second I thought those were links to the Porsche fan for the corvair motor _________________ 1970 Adventurewagen Hightop "Penelope"
kustoms Samba Member
Posted: Sat Feb 19, 2011 2:07 pm Post subject: |
Where can you find those Porsche fan shrouds for the corvair? _________________ 1970 Adventurewagen Hightop "Penelope"
DasVolksRodder Samba Member
Joined: March 30, 2009 Posts: 46 Location: West Virginia
Posted: Thu Aug 27, 2009 8:33 pm Post subject: |
i'm putting a edelbrock 4bbl equipped 140 series in my girl's 70 cabriolet and it is cammed for reverse rotation. even had the pulley and backwards stamped fan on the alternator to correct airflow and keep from tossing belts. came out of a rail buggy. IECO 4bbl kit and finned aluminum valve covers look nice, gonna freshen it up and hope to find more go-fast goodies under all the layers of paint and dirt. one thing someone forgot to do, was sell a crank with the timing marks on the other side of TDC for us VW guys!!!  _________________ 1970 VW Bug cabriolet w/Corvair power
1980 Mazda Rx7 10th anniversary edition
1983 Maxda Rx7 GSL
19xx unknown vw fiberglass roadster |
Posted: Sat Jun 13, 2009 7:49 am Post subject: |
bim55 wrote: |
I'm not sure but the GS guy probably has the right idea for a reliable 250hp that can drive all day long. |
When Subaru makes an air cooled boxer engine , I'll be first in line to put it in my swb Manx. |
bim55 Samba Member
Joined: February 11, 2005 Posts: 438 Location: Dennis Port, MA
Posted: Sat Jun 13, 2009 6:20 am Post subject: |
SteveManx2, , I have the same combination of short stroke with 140 heads and altenator and Holley 4bl. Not the largest displacement Corvair, but a smooth and cooler running engine, or so I've been told.
I'm not sure but the GS guy probably has the right idea for a reliable 250hp that can drive all day long. _________________ Boston Bob E.
www.bimelliott.com www.deserterownersgroup.org |
Posted: Fri Jun 12, 2009 6:27 pm Post subject: |
GS guy wrote: |
When I found what it was going to take to make a reliable 200+hp N/A Corvair, I quickly switched gears to a modern "boxer" 4-cylinder engine, factory turbocharged easily able to crank out 250hp - stock. It does come with its own fitment issues though!
Jeff |
How about take a stock 180hp, then reverse rotation, use a modern turbo with a set of Keith Black forged pistons and a set of the Chinese nikasil cylinders to keep it cool? I think that would give you 200hp+ with better reliability than the stock engine and probably not be all that much more expensive than a 150hp Type 1. |
GS guy Samba Member
Joined: December 03, 2007 Posts: 988 Location: Maryland
Posted: Fri Jun 12, 2009 5:26 pm Post subject: |
It's a real shame either GM didn't continue development on the Corvair engine to a 3rd generation, or someone hasn't worked on tooling up their own version. An air cooled push-rod 6 is just plain cool!
Unfortunately, by the time you have one outfitted like the pic at the beginning of this post, you'll likely have as much $$$ into it as a real Porsche engine! Factor in the 94mm cylinders, full rebuild, cut heads for the Weber manifolds and revised valvetrain, the Webers or PMO's, Porsche shroud and fan/alt., roller reverse cam.... That all turns into a BiG TICKET motor, likely only pushing about 250 HP or so.. maaaaaybe 300? Then it becomes too hard to keep it cooled while making that kind of power.
A modern engineered and machined bottom end would be the real ticket, with the same modern engineering head design to go with it! Just dreaming though... only mass production would ever make such an engine even remotely affordable.
Still, I think that pushrod 6 Porsche look-alike is downright cool!
Jeff |
Posted: Fri Jun 12, 2009 10:06 am Post subject: |
The fan with the straight blades is 64-69. |
SteveManx2 Samba Member
Joined: January 15, 2009 Posts: 43 Location: Michigan
Posted: Fri Jun 12, 2009 9:49 am Post subject: |
Yes, the rear hubs have been drilled....EM Corvairs had 4 on 4.5, these are now 5 on 4.5". The front VW hubs have adapters. The brakes date it to 1962-1963. The motor is a bit of a mystery...the code on the block (T0820YN) indicates 1960-1963 145cid....but it does have 1965 140 heads. The upper shroud is an EM with no provision for PCV but has been modified to fit the 140HP heads. It has a draft tube rather then PCV and yes has an alt. The flywheel, differential, and transmission are all 1962-1963. So, I'm not 100% positive what all is here The instrument panel and gauges are from 1962-1964 Spyder. The fins on the fan are straight...does that indicate LM?
Steve |
