pedro sainz Samba Member
Posted: Fri Jul 03, 2009 10:56 pm Post subject: |
| Russ Wolfe wrote: |
| pedro sainz wrote: |
| Russ Wolfe wrote: |
Will it work with the Fuel Injected cars, since they have the fuel pump mounted to the backside of the beam to one side??
Nice work.... |
since I have NOT seen one where is mounted
i need to ask are they mounted left or right
upper beam or lower beam
the bracket is 3 inches wide and is mount lower beam
at the far end of the TWO sides |
If you mount in the 2 openings at the far end of the beam, then it will not work for FI cars. The fuel pump and filter are mounted to a plate on the right side opening. |
YES I search a 72 type 3 beam there's a plate welded on the right side
I already change the name of the topic _________________ 68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Jul 03, 2009 10:13 pm Post subject: |
| Russ Wolfe wrote: |
Nice work.... |
If you mount in the 2 openings at the far end of the beam, then it will not work for FI cars. The fuel pump and filter are mounted to a plate on the right side opening. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Fri Jul 03, 2009 9:46 pm Post subject: |
| gixxer 711 wrote: |
| the one thing i wonder about is the pivoting action. a bug beam is round tubing where the bar mounts, however the type 3 beam is not. i wonder over the long term of going in and out of driveways and elevation changes, will it tear of the tow bar or the beam. |
Before I hook it to my truck I raised the towbar
just to see how high can I lift
before HITS the Bottom of the Notch
I was
Good question
type 3 Beam is 3X3 square
NOT including top and bottom lip
ONLY where the towbar pivots
that's why the TWO plates are 3 1/4 space in between
the is a 1/4 spacing to allow that
NOW this is ME
I just wanted to hook it up and hit the FREEWAY
get to the VW SHOW and park on the street remove the towbar and drive the Notch IN
you should have ALL pack with food and gas
READY to GO
there's NO need to go to the wal-mart store or 7-11 etc.
JUST HOOK AND GO
again this is ME
AVOID driveways as many you can
Gizbob will TEST my towbar SOON
he already came to pick it up
I will know his opinion
. _________________ 68 T34 1600 Automatic
N.O.N.A member #3
gixxer 711 Samba Member
Joined: August 17, 2007 Posts: 589 Location: houston, tx
Posted: Fri Jul 03, 2009 11:18 am Post subject: |
the one thing i wonder about is the pivoting action. a bug beam is round tubing where the bar mounts, however the type 3 beam is not. i wonder over the long term of going in and out of driveways and elevation changes, will it tear of the tow bar or the beam. _________________ Danny |
redbug74 Samba Member
Joined: June 15, 2004 Posts: 292 Location: Far West Texas
Posted: Thu Jun 25, 2009 2:19 pm Post subject: |
X3 _________________ Different Strokes for Different Volks
74 Standard Type 1
69 Squareback Type 3
55 Oval Type 1 |
chrisvuc Samba Member
Joined: May 04, 2006 Posts: 233 Location: henderson, nv
Posted: Wed Jun 24, 2009 8:39 pm Post subject: |
| peaceful warrior wrote: |
Pedro, are you going to begin making these on a one time basis? If so, I want one and I will send you a bug tow bar to start with. I don't have your welding skills.
LMK! |
x2 |
Posted: Wed Jun 24, 2009 5:43 pm Post subject: |
| Notchback65 wrote: |
| Looks Great,I may have to build one of those.. |
Real Easy
Go for it
I got ALL the numbers for you
any questions just ASK _________________ 68 T34 1600 Automatic
N.O.N.A member #3
Posted: Wed Jun 24, 2009 5:40 pm Post subject: |
| Russ Wolfe wrote: |
Nice work.... |
at the far end of the TWO sides _________________ 68 T34 1600 Automatic
N.O.N.A member #3
Posted: Wed Jun 24, 2009 5:33 pm Post subject: |
| Critter1 wrote: |
Very nice Pedro! What are the small round bar pieces for that are sticking out (3-4") on each side from the square tubing?
I went a different route for my tow bar set up. I did a super beetle style set up with tabs welded to the beam.
I really like what you've done here. You're a hell of a fabricator!! |
you have a GOOD EYE
since is NOT DONE yet
those two tubing sticking out from the sides
I going to slide TWO rubber wheels 2 1/2 big so
I can roll it under the Notch  _________________ 68 T34 1600 Automatic
N.O.N.A member #3
Posted: Wed Jun 24, 2009 5:28 pm Post subject: |
LMK! |
Fabricate this by ORDER maybe
I'm sure there's someone near you can weld to SAVE
all the shipping cost if NOT
Yes i can built yours but NOT NOW
I'm a little behind with others projects
if you can wait
let me finish mine first completly
because I need TESTED I little more
and change the bolts for Quick Release Set Up
adding wheels and more
thanks for your patience _________________ 68 T34 1600 Automatic
N.O.N.A member #3
Notchback65 Samba Member
Joined: March 23, 2006 Posts: 251 Location: Houston, Texas
Posted: Wed Jun 24, 2009 8:48 am Post subject: |
Posted: Wed Jun 24, 2009 7:29 am Post subject: |
Nice work.... _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1579 Location: Sacramento
Posted: Wed Jun 24, 2009 7:17 am Post subject: |
I really like what you've done here. You're a hell of a fabricator!! _________________ Justin |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5275 Location: Taoswest, USA
Posted: Wed Jun 24, 2009 6:49 am Post subject: |
LMK! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
Posted: Tue Jun 23, 2009 11:11 pm Post subject: Perfect Tow Bar for Early Type 3 and Dimentions |
I had to built my own tow bar a month before the Classic 09
to pack my truck with roof racks and also tow my Notch
i only had the time to powder coated one half
this is what I came up
6' feet long
2 piece tow bar for easy storage inside of my truck
I bought a bug tow bar for $10
bugs tow bars are 30 inches wide
Type 3 only needs 24 inches wide so I cut
ALL the welding area
and made it 24 inches wide and weld it again
and you can see I ADD the other half 2X2 square for easy slide
in the round tubing
needs to be exact 5 1/2 inches tall brackets support
smaller or longer would NOT WORK
and 3 1/4 apart inside dimentions
from San Diego to Irvine Ca. 65 to 70 mph
Ibjack on the T34 just checking few times on the freeway
ALL GOOD
We meet Rob Kings half way he saw it and like it too
90 degress turn on the gas station with the tail gate down and
a 9 feet 5 inches in my 6 foot bed bus roof rack hanging out and was far to touch the Notch
Jason saw me at the arrived at the Crown Plaza Hotel
No problems at ALL on or way back Jack make me buy a thick chain
and a bolt at Home Depot _________________ 68 T34 1600 Automatic
N.O.N.A member #3
