cormac Samba Member
Posted: Tue Feb 09, 2010 11:41 am Post subject: |
Yea i have already taken off that bit of wiring and im picking up a second handlight switch and a head light flasher switch. I will check the ground wires. Cheers |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Mon Feb 08, 2010 2:56 pm Post subject: |
Sounds like a combination of a bad headlight switch and perhaps bad grounds as well. The only possible reason that I can see for tapping into the running lights to pull power for the headlights would be a bad switch (still a sketchy and ill advised hack though).
I would start by replacing the headlight switch and putting all of the wiring behind the grill running to the headlights back to stock. Inspect all of the wires and connectors closely since they have been messed around with already.
If the high beam relay clicks, but the lights don't turn on you might have a bad ground to the high beams. I would try to sort out the main beams first and then visit the high beam issue afterward when it is easier to eliminate more variables. |
cormac Samba Member
Posted: Sun Feb 07, 2010 3:56 pm Post subject: |
I have only just got his 89 1.6turbo D and have just noticed that when i turned on the lights the head lights came on straight away. I had no side lights (runnig lights) so i took off the front grille and saw that the head lights were taped into the side lights wiring so that is why they came on when i only put the switch on one click, So i disconnected that wire, so now i have no head lights. I also have no high beam. I took out the head light switch and if i put power to the head light wire the lights come on and if i put it onto the high beam wire the relay clicks in but i get no high beam! any ideas..  |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1768 Location: Portland
Posted: Sat Jan 23, 2010 7:46 pm Post subject: |
Last week I went to drive home from work and my headlights would not come on. The 5w city light was on in each headlight lens and the brights would come on if I held up the stalk. Very similar to the OP. I drove home using my fog lights with the city lights on. I replaced the headlight switch yesterday and everthing is back on. $48 for a new switch at Halsey Motors, its nice to have a good parts source in town instead of mailordering and dealing with shipping and PITA returns. _________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
jacob. Samba Member
Posted: Sat Jan 16, 2010 5:31 pm Post subject: |
TUFF wrote: |
Bulb is OK, wondering if it is the Light switch - other posts say if wipers and hetaer fan work, it must be the light switch. Thanks |
If it was the headlight switch, both low beams would be out, and the high beams would still work. Perhaps the wire to that specific light fell off or is corroded? _________________
RCB wrote: |
jacob gets razzed a lot cause he has the only GEX engine thats lasted longer than half an oil change. |
TUFF Samba Member
Posted: Sat Jan 16, 2010 5:26 pm Post subject: |
Posted: Sat Jan 16, 2010 4:41 pm Post subject: |
Bad bulb? Start with the simple stuff. |
TUFF Samba Member
Posted: Sat Jan 16, 2010 2:09 pm Post subject: Left headlight out on Low beam |
My challenge is th left low-beam does not come on. Wipers work, and heater fans work. Fuse 10 good. Any suggetsion ? |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Thu Jan 07, 2010 10:17 am Post subject: |
That's also a good way to raise or lower power windows without the ignition on too... _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
claytonic Samba Member
Joined: October 25, 2009 Posts: 32 Location: Vancouver B.C.
Posted: Thu Jan 07, 2010 8:59 am Post subject: Thanks |
Thanks for the speedy replay
I was not looking for ward to chasing gremlins! |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10379 Location: Orbiting San Diego
Posted: Thu Jan 07, 2010 8:36 am Post subject: Re: Head light and fans |
This is normal. With the key off but headlight switch all the way on, only the running lights are on. If you turn on the heater fan nothing happens. Then flash the high beams and the heater fan will spin. It has nothing to do with adding the relays.
Mark
claytonic wrote: |
I have the same thing going on after a relay install. Dam it nothing is simple!
I was wondering if this is normal
If you have
the key off
running lights on (not the head lights )
heater fan switched on
and flash the high beams
do your heater fans come on ?
Mine do, now at least don't know if this was the case before?
Thanks |
Posted: Thu Jan 07, 2010 8:09 am Post subject: Head light and fans |
If you have
the key off
Thanks |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Tue Jan 05, 2010 8:20 pm Post subject: |
Ok, the new high beam assembly and headlight switch arrived today. Didn't even need to take the headlight switch out of the package, the culprit was the high beam switch. Westapotamous finally has [brighter] lights again. Yessss! |
jacob. Samba Member
Posted: Tue Jan 05, 2010 1:06 pm Post subject: |
I installed a used headlight switch I got at a wrecking yard for 20 bucks. Headlights came right back on. Now on to the relays. _________________
RCB wrote: |
Posted: Wed Dec 30, 2009 9:57 am Post subject: |
jacob. wrote: |
Is bypassing the relays bad for the van at all? |
I was thinking that reconnecting the yellow and white wires back together would simply restore it back to the stock configuration. If nothing else, just to reestablish a baseline since I performed a lot of upgrades at the same time when the dash was out. However, I'd rather not clip out the butt splices and shorten those wires anymore than they are. For instance, could it be possible the Shoebox Electronic headlight buzzer I wired in some time ago (and has always worked) is somehow interfering with the headlight relay kit? |
jacob. Samba Member
Posted: Wed Dec 30, 2009 9:35 am Post subject: |
singler3360 wrote: |
OP indicates in a PM he has not resolved this issue yet. I just ordered new headlight AND high beam (wiper/washer assembly) switches from VC. I'll try the high beam first and will report back the results. It will be next week most likely before I report in. In the meantime, I'm tempted to wire the yellow and white wires back together, bypass the relays, to see if the problem persists. Has anyone done this already? |
Is bypassing the relays bad for the van at all? And no I haven't solved the problem. My van is being a piece of shit right now. Its draining the battery, so every morning when I go to start it, it doesn't work. With a full battery everything works fine (except the headlights of course). I ordered a new voltage regulator/brushes and hopefully that solves that. If not, I'll have my alternator rebuilt. _________________
RCB wrote: |
Posted: Wed Dec 30, 2009 7:19 am Post subject: |
kevtherev Samba Member
Joined: December 23, 2007 Posts: 897 Location: the 51st state
Posted: Wed Dec 30, 2009 4:19 am Post subject: |
I too am interested in who the culprit was |
Posted: Tue Dec 29, 2009 8:45 pm Post subject: |
Jacob, what finally resolved this for you? I currently have the same problem. Thanks. |
youremyboyblue Samba Member
Joined: December 01, 2009 Posts: 38 Location: whereever my tdi syncro will take me!
Posted: Wed Dec 16, 2009 10:32 am Post subject: |
10) take a break and come back to it > beer
11) repeat steps 1-10
12) swap bulbs > realized bulb does not work on functional side
13) kick dirt that a day was wasted over a bad bulb > unwarranted bad feelings toward vendor and self
14) put old lower power bulbs in while wating for replacement > light from both headlights on low or high
so now that i have learned a bunch and have light, i have some poltergeist business going on ...
while driving, the driver's interior light flickers on accompanied by loss of power and dimmed headlights/interior. i'm troubleshooting a bit of a hunting idle but, the interior light flickering while in the light when door open position is not only new but, mysterious. i thought that i had read something about this issue with the flickering interior in another headlight thread but, am at a loss to find it currently.
any help is appreciated! |
