Sliding door problem
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Tue Dec 22, 2009 10:46 am    Post subject: Reply with quote
I just noticed you have an '82. I agree with last poster that taking the door cover off (careful with the brittle plugs and soft door panel material) and adjust the bowdoin cable that connects front handle with rear latch. Adjustment may not be needed, but good to know that you can...
The locking knob problem may be due to a broken internal spring. This spring is unrepairable. It may be broken and interfering with knob action. See if that is so and fish out broken bits. To mimic the action of the spring, ie keep the knob up when up, slip a small section of rubber hose over the knob boss so that it provides friction to keep the knob up when up, and down when down Smile
That worked for me for years.
alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
surfinwesty
surfinwesty is offline
PostPosted: Tue Dec 22, 2009 9:56 am    Post subject: Reply with quote
Try this: If you have an 82 pop-off the inside door panel. Take a look at the latch. First spray with WD40 than spray with chain saw lubricant. You might be able to also adjust the cable to get it to catch or you can play with the latch mechanism and might be able to free it up.
Current Love:
"Adobe" 1984 VW Westy w/Subi
Retired:
"Swell Chaser #1" 1980 Westy (in VW Heaven)
"Swell Chaser #2" 1981 Westy (sold to loving family on TheSamba forum)
vintagemotion
vintagemotion is offline
PostPosted: Tue Dec 22, 2009 9:10 am    Post subject: Reply with quote
just manual
82 orange Diesel Westy
AHU conversion (mechanical with stock JX pump)
5 Speed ASS
CLK Wheels 215/70/16
sbclayton
Location: A place where owning a VW and enjoying life are synonymous
sbclayton is offline
PostPosted: Sun Dec 20, 2009 8:53 pm    Post subject: Reply with quote
Question: do you have the power door locks? My sliding door latch jammed in a similar fashion when the passenger side power lock mechanism switch failed in the locked position. If you have PDL's, it could also be a failed sliding door power lock.
Steve - Tampa Bay Area
Original Owner (12/1990) of
NavDog, a 91 Carat
Enlightenment came when I realized that any time in my life I was having fun, it was somehow connected with owning a Volkswagen.
View user's profile Send private message Facebook Classifieds Feedback
Timwhy
Timwhy is offline
PostPosted: Sun Dec 20, 2009 5:04 pm    Post subject: Reply with quote
upper is unlocked
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
vintagemotion
PostPosted: Sun Dec 20, 2009 4:59 pm    Post subject: Sliding door problem Reply with quote
My Vanagon sliding door does not unlock from the in or outside. It seems that the un-lock knob on the inside cannot be moved far enough to unlock the door. It is kind of in the middle?
Any suggestions?
When is the door unlocked - with the knob in upper or lower position?
Question
5 Speed ASS
