pop out windows
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sun May 02, 2010 5:51 pm    Post subject: Reply with quote
Bobnotch wrote:
I believe they are. Blankmange might have a set for sale soon. Wink
aye, I might...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Bobnotch
Bobnotch is offline
PostPosted: Sun May 02, 2010 5:08 pm    Post subject: Reply with quote
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
rays-64
rays-64 is offline
PostPosted: Sun May 02, 2010 4:58 pm    Post subject: Reply with quote
are the small clips on the pop out frame (2 per frame that hook into the car frame) the same for early notches and squarebacks. thanks again.
Bobnotch
Bobnotch is offline
PostPosted: Tue Apr 27, 2010 8:45 am    Post subject: Reply with quote
Pop out latches are the same for Notchbacks thru the years that used them, except the very early style which had the latch mounted to the window frame (61&62?). If you have a hole in the glass, it's the same until pop outs were discontinued in 71. Also, the latch assembly is the same as a Squareback, but they are flipped side for side, due to Squares having the handle/knob on the bottom rather than the top like a Notch needs (for seat back clearance). Also, the Fastback uses a different latch assembly, and won't work on a Square or Notch. I hope this helps.
Tram wrote:
Tram wrote:
rays-64
rays-64 is offline
PostPosted: Mon Apr 26, 2010 6:33 pm    Post subject: Reply with quote
what about the pop out window latch. Are all years the same or are they different for the early years. I have 1964 notch.
thanks
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 08, 2010 3:23 pm    Post subject: Reply with quote
Yes.
Tram wrote:
Tram wrote:
rays-64
rays-64 is offline
PostPosted: Thu Apr 08, 2010 3:20 pm    Post subject: pop out windows Reply with quote
will a 1965 notchback rear pop out window fit onto a 1964 notchback
