Windshield Washers reversed?
datsnice
datsnice is offline
PostPosted: Wed May 05, 2010 12:48 pm    Post subject: Reply with quote
If Vanagons do have it, where would I look for the anti-drain valve, and what would be the issue exactly? Thanks!
1989 Vanagon 2WD Full Camper
EJ22 Subaru Conversion
"Greyboy"
randywebb
randywebb is offline
PostPosted: Wed May 05, 2010 11:40 am    Post subject: Reply with quote
does the Vanagon have an anti-drain back valve like some German cars do?
if so, that might be part of your issue
1986 2.1L Westy 2wd Auto Trans.
datsnice
datsnice is offline
PostPosted: Wed May 05, 2010 9:00 am    Post subject: Reply with quote
great thanks, i do know where the tank is, didn't know the pump was down there too. i'll take a look and see whats up
If anyone has done this replacement I'd like to see some pics or info on where to pick up a new pump.
Appreciate the info!
"Greyboy"
ajdenette
ajdenette is offline
PostPosted: Wed May 05, 2010 7:38 am    Post subject: Reply with quote
When sitting in the drivers seat the pump and tank are under your left foot you can see the tank from underneath another posibility is an inability to find that tank so a jury rig may have been their answer Shocked
1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work
datsnice
datsnice is offline
PostPosted: Wed May 05, 2010 7:15 am    Post subject: Reply with quote
good thought. i dont think the front pumps to the rear. that could be the answer to why its set up like that. But I'd still like to fix it. Where is the pump to replace in front? Is it a PITA to fix?
"Greyboy"
ajdenette
PostPosted: Wed May 05, 2010 5:46 am    Post subject: Reply with quote
if you hear the rear pump pump all the way to the front does the front pump pump all theway to the rear it may have been a po's answer to fiking the windshild washer for cheap Rolling Eyes
datsnice
datsnice is offline
PostPosted: Tue May 04, 2010 10:47 pm    Post subject: Reply with quote
Without diggin around at all, that was my assumption too. Do you know where I would get to those connections?
"Greyboy"
Terry Kay
Banned
Terry Kay is offline
PostPosted: Tue May 04, 2010 10:12 pm    Post subject: Reply with quote
Sounds to me as if the wiring connections are backwards.
T.K.
datsnice
datsnice is offline
PostPosted: Tue May 04, 2010 10:06 pm    Post subject: Windshield Washers reversed? Reply with quote
I'm pretty sure my windshield washers are reversed, but how to correct? When I PULL the washer stalk on the steering column, the rear washer works. When I PUSH it, the front washer works, but it takes 5 seconds or so for the pump in back to pump washer fluid through. Meanwhile the wipers are smearing dirt all over the windshield before fluid gets there, further impeding visibility. It even appears by the pictures on the actual stalk that things are backwards. Am I missing something? How can I reverse these? Thanks for the help!
"Greyboy"
