Distributor drive
ashman40
ashman40 is offline
PostPosted: Sat Sep 18, 2010 2:39 am    Post subject: Reply with quote
forested665 wrote:
yea you can usually make up for it with the timing.
No timing changes needed.
Incorrectly indexed distributor drive gear means location of #1 spark plug wire may not be at the expected "clock position" around the distributor cap. But once you connect the plug wires to their correct location around the cap timing is set the same way.
If you have a vacuum can there may also be clearance issues as it may now be hitting something.
AshMan40
forested665
forested665 is offline
PostPosted: Fri Sep 17, 2010 9:08 pm    Post subject: Reply with quote
View user's profile Send private message MSN Messenger Classifieds Feedback
Joey
Joey is offline
PostPosted: Fri Sep 17, 2010 7:17 am    Post subject: Reply with quote
Once you do get it out be careful not to loose the washer/shims down inside the engine or you'll be splitting your case to get them out. Personally, if the gear isn't too far off I would just leave it.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
BWD
Samba Mailman
BWD is offline
PostPosted: Fri Sep 17, 2010 6:37 am    Post subject: Reply with quote
johnnypan wrote:
just turn the crank a little while you pull it,it should pop up.If ya dont have a engine stand,"glue' the washers to the distributor drive with white lithium grease (engine assembly lube) if ya dont have any buy some at the parts store,its as handy as a pocket on a shirt...
Pockets on shirts, Dude, you should get a patent on that idea! Wink
BWD
JHC
member #2850
1966 Beetle
_____________________________
johnnypan
johnnypan is offline
PostPosted: Fri Sep 17, 2010 6:07 am    Post subject: Reply with quote
ashman40
ashman40 is offline
PostPosted: Fri Sep 17, 2010 6:03 am    Post subject: Reply with quote
Did you install the mechanical fuel pump? The pump pushrod rides the cam on the distributor drive gear. It will hold the drive gear down until you remove the whole assembly. I think you may need to remove the spacer/stand that the pump sits on.
AshMan40
runamoc Premium Member
runamoc is offline
PostPosted: Fri Sep 17, 2010 5:40 am    Post subject: Reply with quote
If you have the engine on a 'rotating' stand, position it with the dist. 'hole' pointing down. Take the puller and twist it back and forth will pulling down on the drive gear. Having the engine 'upside down' helps to keep the shims from falling into the engine case when the gear does come out. Good luck. Cool
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
Sheffmyster
Sheffmyster is offline
PostPosted: Fri Sep 17, 2010 4:24 am    Post subject: Distributor drive Reply with quote
When I installed the distributor drive gear it turned on me. I need to pull and get it installed right. Problem, I have tried to use all sorts of items to get it pulled out. I ordered the drive gear puller, tried it last night and can not get the gear out. Is there something I am not doing to get it out?
