fusername Samba Member
Joined: March 15, 2006 Posts: 2899 Location: Boston MA
Posted: Wed Oct 20, 2010 5:33 am Post subject: |
probably cause people have abit more respect for his threads knowing who he is.
and yes, the most important function of the screen is to stop junk from going thru the oil pump and putting all kidns of score marks in it and lowring your oil pressure. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
| obnoxiousblue wrote: |
| Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Batan Samba Member
Joined: March 10, 2003 Posts: 1637 Location: Vancouver, BC
Posted: Tue Oct 19, 2010 10:58 pm Post subject: Re: My 3rd stupid question this week |
| aeromech wrote: |
I told you guys it wouldn't take me long to come up with another stupid question so here goes...
Your "stupid" questions turn out to make very interesting and informative threads though! _________________ '69 Riviera Bay
'03 20th Anniversary GTI
'74 Super Beetle
Badzak Creative – Still and Motion Pictures |
Hoody Samba Member
Posted: Tue Oct 19, 2010 10:49 pm Post subject: |
| The only stupid question is the one that isn't asked. |
BusterBrown Samba Member
Joined: December 15, 2009 Posts: 1397 Location: Arizona
Posted: Tue Oct 19, 2010 10:08 pm Post subject: |
aeromech;
You only asked what many of us have wondered about. I changed my oil, filter, and cleaned the sump screen just this past weekend, and wondered that very thing.
I too anticipate your next silly question. And it's OK for you to ask them, 'cause you're not a noobie! _________________ 1978 Sage Green Westfalia (Happy Trails, SOLD)
1977 Transporter
Life is short. Can I have some of yours? |
Posted: Tue Oct 19, 2010 10:06 pm Post subject: |
| Hoody wrote: |
| The best reason to keep it? Old German engineers decided it should be their. |
Old German engineers also didn't bother to use a filter on an engine sold well into the 1970's. Inexcusable oversight if you ask me. |
Hoody Samba Member
Posted: Tue Oct 19, 2010 10:05 pm Post subject: |
Just put a coffee filter in there and you will be good
Hoody Samba Member
Posted: Tue Oct 19, 2010 10:00 pm Post subject: |
Desertbusman Samba Member
Posted: Tue Oct 19, 2010 8:46 pm Post subject: |
Next question?  _________________ 71 Superbug
71 Westy |
atom Samba Member
Joined: March 02, 2005 Posts: 131 Location: Austin, TX
Posted: Tue Oct 19, 2010 7:41 pm Post subject: |
Just want to reiterate the point made here, with some pictures of modern oil pick-up tubes. Seems like a good plan to keep the screen with filter, since that engineering is still used. I clean these when replacing oil pans, so with a filter, they don't need regular cleaning, but also not forgotten.
| VDubTech wrote: |
| aeromech wrote: |
| VDubTech wrote: |
| aeromech wrote: |
| Randy in Maine wrote: |
| Keep it in there. |
Any particular reason? |
I can't in 1000 years imagine why you would want LESS protection in filtering the oil. Why would you want to remove the screen? |
It seems redundant. What's the screen going to catch that the filter misses? |
You never know. It's also redundant in the T4 which came from the factory with a screen and a filter, and the screen still catches stuff and should be cleaned with every oil change. With oil filtration, I'll take as much redundancy as I can get. |
Posted: Tue Oct 19, 2010 7:08 pm Post subject: |
Even I would leave the screen in place, who knows what lurks in the depths on your engine. Pulled one engine I had previously assembled apart to find a fir code in the sump thanks to some squirrel looking for a place to store his winter feast. I have certainly found a bunch of other weird crap hiding in pans and sumps over the years.
I have heard of people leaving the screens off to increase oil flow, but I have never heard of anyone actually having a starvation problem with them in place.
I would leave it there and then just not clean it more than once every 50K or so after the initial break in period. |
78Kombi Samba Member
Joined: October 05, 2006 Posts: 1043 Location: Western Mass
Posted: Tue Oct 19, 2010 5:38 pm Post subject: |
aeromech I understand where yer coming from, if anything is so big that a screen that size needs to catch it, well yer fukked anyway.. _________________ 78 hightop 2.0 FI
| Wildthings wrote: |
no engine that I know of will run off of hype.
aeromech Samba Member
Joined: January 24, 2006 Posts: 17776 Location: San Diego, California
Posted: Tue Oct 19, 2010 5:33 pm Post subject: |
| Desertbusman wrote: |
| Quote: |
You're on a roll Gary
If nuts, bolts, bearings, or anything else falls to the bottom of the case it will prevent them from going thru the pump. And if you don't have it you'll probably never pull the drain plate to inspect for any particles, sludge or whatever. Also the sump plate studs then might be too long and the acorn nuts bottom out instead of sealing. |
Much better points and all well taken. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Oct 19, 2010 5:12 pm Post subject: |
| Quote: |
If nuts, bolts, bearings, or anything else falls to the bottom of the case it will prevent them from going thru the pump. And if you don't have it you'll probably never pull the drain plate to inspect for any particles, sludge or whatever. Also the sump plate studs then might be too long and the acorn nuts bottom out instead of sealing. _________________ 71 Superbug
71 Westy |
El_Güero Samba Member
Posted: Tue Oct 19, 2010 4:51 pm Post subject: |
| aeromech wrote: |
| VDubTech wrote: |
| aeromech wrote: |
| Keep it in there. |
Now your onto your fourth "stupid question".... are you trying to set a record here??? |
Posted: Tue Oct 19, 2010 2:12 pm Post subject: |
| VDubTech wrote: |
| aeromech wrote: |
| VDubTech wrote: |
| aeromech wrote: |
| Keep it in there. |
That's a good point _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9157 Location: Syracuse, NY
Posted: Tue Oct 19, 2010 2:11 pm Post subject: |
| aeromech wrote: |
| VDubTech wrote: |
| aeromech wrote: |
| Keep it in there. |
You never know. It's also redundant in the T4 which came from the factory with a screen and a filter, and the screen still catches stuff and should be cleaned with every oil change. With oil filtration, I'll take as much redundancy as I can get. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
| borninabus wrote: |
| a measurement of your rod would be extremely useful. |
| notchboy wrote: |
| my dad wasnt a belittling cock when he tought me how to wrench on cars. |
| EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Tue Oct 19, 2010 2:09 pm Post subject: |
| VDubTech wrote: |
| aeromech wrote: |
| Keep it in there. |
It seems redundant. What's the screen going to catch that the filter misses? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Oct 19, 2010 1:53 pm Post subject: |
| aeromech wrote: |
| Keep it in there. |
I can't in 1000 years imagine why you would want LESS protection in filtering the oil. Why would you want to remove the screen? _________________ First Trip in the RustyBus:
| borninabus wrote: |
| notchboy wrote: |
| EverettB wrote: |
Posted: Tue Oct 19, 2010 1:01 pm Post subject: |
| Keep it in there. |
Any particular reason? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
babysnakes Samba Member
| My 1600 is full flowed with external oil filter and I'm keeping the strainer. |
