rosevillain Samba Member
Joined: December 28, 2005 Posts: 1338 Location: roseville, ca
Posted: Mon May 09, 2011 9:10 am Post subject: |
Two phenolic spacers for under the intake runners at the head |
MikeBehrens Samba Member
Posted: Mon May 09, 2011 8:22 am Post subject: |
thanks a lot guys.  |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23385 Location: Kimball, Mi
Posted: Sun May 08, 2011 10:25 pm Post subject: |
Only thing I can think of is the fuel pump mounting brackets, and their rubber bumpers (2 with a stud on each end). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun May 08, 2011 9:04 pm Post subject: |
fuel pump, snubber, fuel pressure regulator, two fuel 'T's (actually they are 4-way adapters, one with a threaded plug), four injectors, wiring harness, ECU, MAP sensor, throttle body, intake air temperature sensor, 4 wire TPS (I'm guessing at the four wire), head temperature sensor, two intake runners, two bakelite injector bases with two spacers each, grounding porcupine, distributor, trigger plate, AAR (mounts where the fuel pump goes on a carbed car, main injection relay (under back seat), fuel pump relay (under dash), fuel tank. Does it come with the cold start injection system?
How's that? What did I miss? |
supaninja Samba Member
Posted: Sun May 08, 2011 6:31 pm Post subject: 1970 squareback fuel injection parts list |
im getting rid of my fuel injection and i just wanna know the full list of parts that go along with it so i can sell someone a complete system. thanks in advance |
