ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7230 Location: Honolulu,Hawaii and France
Posted: Sun Aug 02, 2020 6:52 pm Post subject: Re: radiator flow rate and autopsy |
Aloha all!
you might be interested in these pictures of my radiator autopsy
For our European friend, apparently you guys have the Mahle/Behr/Hella radiator too butmade in China.
I spoke to my friend in France who imports and buys NOS parts from all over and makes a few underground repros like the 094 5 speed 2WD shifter.
He can`t find the RSA made radiators, pictures also look a bit different than what we have from RSA here in the USA.
He`s had quite a few bad ones straight out of the box, so that inspired me to open a particularly bad radiator I had on hand.
The engine would run a tad hot under 50MPH but after driving fast it would never come down and temps kept climbing....
I wonder if the production is starting to shift from RSA to China for these, that would suck....
For info the part number for this radiator is 068121253E and it was made by Behr too I believe, and in Germany.
The letter D was made by AKG also in Germany, they`re easily recognizable as their fins are copper and the bottom is steel, the clamp flat bars are stainless.
The E letter radiator appeared when vw must have switched suppliers in 1985/1986. They are identical in dimensions and specs.
Left tank ( driver side) 025121573
You will notice that the inner parts have their own VW part numbers, and you won`t find them anywhere. My guess is they wera made by separate suppliers and assembled by the last manufacturer, so maybe they were only used internally for stosk management purposes?
Not the first time I run into secret VW part numbers, the tunnel Ac evaporator housing has the black plastic parts numbered like this too for the fans, same with the side cover square spacers. All glued and not serviceable, so they were never meant to be replaced.
Strange eh?
The part numbers are in 068, makes sense as the diesel type 2`s were the first watercooled Vanagons.
The right side tank ( passenger side) 068121572, logically.
They must have introduced some modifications at some point as the left tank is 025121573., 025 is WBX. There used to be a special radiator for hot climates, 025121253A So they probably made one that had all features with the last revision model 068121253E
Notice the border to divide the right tank. As you may know, the radiator flows supply and return from the same ide, passenger side.
It enters hot the vertical connection, goes up to the bleeding screw, goes left, goes down , goes right and exists from the angle connection cold to the engine.
The tank gasket is 068121539A. The 2 little bridges can break loose sometimes. I had found pieces stick next to the thermoswitch hole once, not knowing what they were....
The silicone cemetery who the heavy handed silicone plasterers out there
The top and bottom bars are the same, stamped with the radiator part number 068121253E
And this, ladies and gentlemen, is called quality inspection: 1 corner out of 4 got a quick brazing fix for probably a good reason.
Other corners don`t have it:
I hope you like it!
Keep it cool  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10407 Location: Orbiting San Diego
Posted: Mon Sep 19, 2011 4:30 pm Post subject: Re: coolant flow rate |
Don't cut the metal, just the plastic close to the folded over metal that holds the plastic to the core. If you cut the metal core it is so soft that the cutting process tends to bend up the fins so you can't see the passages very well.
Mark
| fixedgear wrote: |
Thanks Mark, I'll chop as you suggest and try and get the pics on this site. |
fixedgear Samba Member
Joined: November 09, 2006 Posts: 300 Location: Clear Lake, Manitoba, Canada
Posted: Mon Sep 19, 2011 4:21 pm Post subject: Re: coolant flow rate |
[quote="crazyvwvanman"]The A/C condensers are attached to the radiator in most cases, but not all.
Use a sawsall and slice the plastic end tanks off. Then you can see the core pretty well from both ends. I have done this a couple times and the crap in there was kinda shocking. This also allows you to see how the tanks are arranged to make the coolant flow side to side through the bottom half and then back the other way in the top half. The inside partition in the hose end tank is sometimes known to split open and allow coolant to go in and back out of the rad without passing through the core.
Mark
Thanks Mark, I'll chop as you suggest and try and get the pics on this site. _________________ 1986 Wolfsburg Weekender |
Posted: Mon Sep 19, 2011 3:59 pm Post subject: Re: coolant flow rate |
Mark
| fixedgear wrote: |
I did a series of pictures on replacing the rad. in a van with air conditioning. I found the description of the procedure confusing in Haynes and in other sources. For instance, Haynes comments that the rad. can be disconneced from the condenser after dropping the rad., when in fact there is no connection, and the condenser poses no additional difficulty.
I have the old rad. against the building, and am thinking that it might be worthwhile to do an autopsy on it. I have an angle grinder with zip disk, if anyone is interested in how much of the area of the rad. is blocked let me know ( as well as the best way to slice it up). |
pushkick Samba Member
Posted: Mon Sep 19, 2011 3:20 pm Post subject: radiator flow |
that would be interesting to see the areas of buildup and what the rad looks like after that many years. that is a big weight difference. _________________ i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper |
Posted: Mon Sep 19, 2011 3:11 pm Post subject: Re: coolant flow rate |
The stock radiator has way more capacity than needed by the stock engines. A new one is under $200 delivered to your door. There are still quite a few vans with the original installed. That shows that there was surplus capacity as even degraded 20-25 years down the road they still often work sufficiently well most of the time. When in doubt, get a new one.
I recently went the route of a rad. repacement on a '86 with AC. I had
wondered about the sediment buildup on an original rad., and how the efficiency may be affected. Prior to replacement the needle pegged always at top third of led after warming up. No experience of overheating as determined by guage or rad. coming on during highway driving. In the city, driving in 80* weather, the rad. would come on to deal with the heat buildup after shut off only, and only for about one minute.
After replacement, the needle pegged at exactly the same spot as before. I was curious about this as well, since another poster commented that the change seemed to free up the system and allowed for alot more movement in the temperature reads.
The only noticeable change was that in city driving, after shut off, the rad fan would not be triggered. The fan has not come on yet. I came to the conclusion that in mid-summer stop-and-go, a clear rad. would have a real benefit and would be a nice benefit to an aging vehicle.
I weighed the new rad. and got a weight of 11 lbs.
The removed rad., drained for 2 hours, and in every orientation was 25.4 lbs.
Cannot comment on whether the stock rad. materials were of a heavier guage or not.
I have the old rad. against the building, and am thinking that it might be worthwhile to do an autopsy on it. I have an angle grinder with zip disk, if anyone is interested in how much of the area of the rad. is blocked let me know ( as well as the best way to slice it up). _________________ 1986 Wolfsburg Weekender |
GMByers Samba Member
Joined: December 07, 2008 Posts: 642 Location: Retired in NW PA
Posted: Mon Sep 19, 2011 2:32 pm Post subject: Re: radiator flow rate |
| pushkick wrote: |
| ....really wanted to see if this would be a good test to see if my radiator of 20 years was still good and not clogged up. |
If you really wanted to know if your radiator is good, why not simply drop it off at a radiator repair shop to be tested?
Sounds like you already have a new radiator on hand anyways. _________________ And then there were two...downsized to 83 Doka &
74 Thing. |
Posted: Mon Sep 19, 2011 2:30 pm Post subject: Re: radiator flow rate |
| pushkick wrote: |
there were several reasons i asked this question first was to see what would happen when i tested my radiator so i could compare the results against a new one. second was to see how it works with a subaru engine with double the horsepower or a upgraded wbx, but really wanted to see if this would be a good test to see if my radiator of 20 years was still good and not clogged up. i found this website with some technical info it may help people in the future with some radiator problems
http://www.arrowheadradiator.com/14_rules_for_impr...obiles.htm |
i also found this article about pumps
http://www.engineeringtoolbox.com/centrifugal-pumps-d_54.html
after reading this article i think a measure of coolant pressure at the right place would give a good indication of the radiators being clogged or having restricted flow. _________________ i see said the blind man to his deaf dog
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5931 Location: Tsawwassen, BC
Posted: Mon Sep 19, 2011 12:38 pm Post subject: |
| kevtherev wrote: |
| I would have thought how large the exchange area is, is the key here. |
And you would be correct!
The Vanagon rad is plenty big enough to handle the cooling needs of 2.5, 3.0 and 3.3 litre Subaru engines but not if they're full of 25 years of deposits! I replaced mine when I installed my 2.5 and was amazed to find the old one weighed almost twice as much as the new OEM version.
I have hardly heard the fan come on since the swap. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
kevtherev Samba Member
Joined: December 23, 2007 Posts: 897 Location: the 51st state
Posted: Mon Sep 19, 2011 11:58 am Post subject: |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17187 Location: Brookeville, MD
Posted: Mon Sep 19, 2011 9:48 am Post subject: radiator flow rate |
http://www.arrowheadradiator.com/14_rules_for_impr...obiles.htm _________________ i see said the blind man to his deaf dog
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Mon Sep 19, 2011 9:20 am Post subject: Re: radiator flow rate |
| pushkick wrote: |
| anyone know the flow rate of a stock radiator or where the info can be found? couldnt find any info in the stickies |
I'm curious about why this information is needed? What will it be used to determine?
The maximum flow rate on any coil depends on the amount of pressure drop you can tolerate through the coil. The higher the flow, the higher the pressure drop. The higher the input pressure, the higher the flow. You need to be able to measure a know point of flow and pressure to know the performance. There are many variables. _________________ 89 Westy 2.1 Auto
Posted: Mon Sep 19, 2011 8:44 am Post subject: Re: coolant flow rate |
If it is really important to know, just hook a garden hose and pressure gauge to the input side and measure how much water comes out the other end, at the pressures that interest you.
Mark
| pushkick wrote: |
i am sure their is a curve for rpm vs. coolant flow and the slower the engine the less flow. but i think i am asking for the max flow rate of the radiator.
i think the pressure has something to do with the max flow rate. if you had 0 pressure at the exit of the radiator then how much gpm could you put through it at a given pressure? there has to be some engineering data on this somewhere. |
Posted: Mon Sep 19, 2011 8:35 am Post subject: coolant flow rate |
i think the pressure has something to do with the max flow rate. if you had 0 pressure at the exit of the radiator then how much gpm could you put through it at a given pressure? there has to be some engineering data on this somewhere. _________________ i see said the blind man to his deaf dog
Californio Samba Member
Posted: Mon Sep 19, 2011 7:45 am Post subject: |
| Wouldn't the real-time flow rate be determined by engine RPM? |
Posted: Mon Sep 19, 2011 7:07 am Post subject: flow rate |
i have a 1990 vw camper with a 2.1 l engine but from my understanding all the water colded are the same. they even have the same water pump. _________________ i see said the blind man to his deaf dog
insyncro Banned
Posted: Mon Sep 19, 2011 6:57 am Post subject: |
| Without any real idea of what vehicle, engine and so on you are talking about......no straight answer can be given. |
Posted: Mon Sep 19, 2011 6:50 am Post subject: |
| Quote: |
| The flow rate of the rad is dictated by the waterpump and size/length of line between the two. |
ok what is the flow rate of the water pump? there is still a flow rate for the radiator it will handle so many gallons/min (gpm). _________________ i see said the blind man to his deaf dog
insyncro Banned
Posted: Mon Sep 19, 2011 6:28 am Post subject: |
