Terry Kay Banned
Posted: Sun Jan 15, 2012 9:36 pm Post subject: |
You can do that.
Check the pistion O-Rings, & the 2nd gear brake band adjustment.
if either one of those two are outa wack--no 2-3 shifts. _________________ T.K. |
flemming grove Samba Member
Posted: Sun Jan 15, 2012 1:18 pm Post subject: |
the fluid level is right on the mark
The bus came from an estate sale so the history is unknown
I am going to check the governor next
many years ago on an Audi 4000 with a similiar problem I checked and fixed the governor
I will check that next on this one
many thanks for your reply |
Terry Kay Banned
Posted: Sat Jan 14, 2012 10:44 pm Post subject: |
2-3 brake band actuating piston seals are dried up & leaking.
No-2-3 shift, just 1 & R _________________ T.K. |
rcook52459 Samba Member
Joined: August 24, 2011 Posts: 492 Location: PORTLAND ORE
Posted: Sat Jan 14, 2012 8:54 pm Post subject: |
did trans shift before fluid change?are you sure you put enough fluid back in? _________________ 85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l |
Posted: Sat Jan 14, 2012 8:14 pm Post subject: 88 westy automatic |
Been restoring an 88 westy that has been sitting for 7-8 years. After changing the entire fuel system, the engine is purring, the automatic transmission (after changing fluid and filter) only has 1st and reverse gear. Any suggestions to diagnose this problem?
How complicated would it be to convert this to a standard transmission, have access to a complete donor 1990 vanagon with a standard transmission? |
