germansupplyscott Samba Member
Posted: Fri Feb 03, 2012 7:23 pm Post subject: |
The hose clips in the link should fit but to be sure you can measure the OD of the hose. Those clips are stainless. The shielded type clips are the best way to clamp fuel hoses IMO. _________________ SL |
buildyourown Samba Member
Posted: Fri Feb 03, 2012 10:47 am Post subject: |
| tencentlife wrote: |
"Oetiker"
I'm the language nazi today. |
Thanks. I googled it to make sure I had it right and that's what it autofilled.
You are correct. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10153 Location: Abiquiu, NM, USA
Posted: Fri Feb 03, 2012 10:37 am Post subject: |
"Oetiker"
I'm the language nazi today. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
Posted: Thu Feb 02, 2012 11:05 pm Post subject: |
You can get those in fractional sizes. Commonly referred to as Oetinger clamps. Even good hardware stores will have them.
McMaster lists them as "pinch hose and tube clamps" and has them in SS to boot.
http://www.mcmaster.com/#standard-hose-clamps/=g2zupa |
SCM Samba Member
Joined: January 26, 2011 Posts: 3476 Location: Bozeman MT
Posted: Thu Feb 02, 2012 10:29 pm Post subject: Ordered new 5/16fuel lines, will these 7mm clamps fit? |
I just ordered a bunch of Dayco J30/R9 fuel hose, 5/16". I would like to get these Oettinger crimp-style hose clamps
http://www.germansupply.com/home/customer/home.php?cat=455
but they are spec'd for 7mm. I'm hesitant to get the clamps since 5/16" is a bit bigger (almost 1 mm bigger) than the hose that the clamps are sized for. Does anyone know if this is a non issue or should I get different screw-style clamps? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
