Cargo floor welding...
Page: 1, 2, 3  Next
Stocknazi
Stocknazi is offline
PostPosted: Wed May 22, 2013 1:17 pm    Post subject: Reply with quote
glideking wrote:
I will be doing a video of how I weld the cargo floor to the tank support shelf as soon as the floor arrives from Klassic Fab. I have the advantage of welding with the truck upside down in a rotisserie.
any progress on this video?
WANTED:
Thomas Jefferson
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Fri Mar 22, 2013 10:31 am    Post subject: Reply with quote
KOMBI NIKO wrote:
If you have a tig welder this works well and cheap!!
http://www.eastwood.com/tig-spot-weld-kit.html?src...Qgoddi0AHg
Is that cup narrow enough to fit between the ribs of a cargo floor?
aeromech wrote:
in my opinion you don't know shit
Stocknazi
PostPosted: Fri Mar 22, 2013 8:49 am    Post subject: Reply with quote
very cool,
i would be very interested in seeing the video
WANTED:
Thomas Jefferson
KOMBI NIKO
KOMBI NIKO is offline
PostPosted: Wed Mar 20, 2013 10:32 pm    Post subject: Reply with quote
glideking
glideking is offline
PostPosted: Wed Mar 20, 2013 10:19 pm    Post subject: Reply with quote
"The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639
Stocknazi
PostPosted: Wed Mar 20, 2013 9:29 am    Post subject: Reply with quote
i am still looking for opinions on how to attach the rear section of cargo floor to the tank support shelf
how have you done this?
opinions?
WANTED:
Thomas Jefferson
fredy a
fredy a is offline
PostPosted: Mon Feb 04, 2013 4:11 pm    Post subject: Reply with quote
sled wrote:
I have found that if you have a good enough MIG welder (powerful enough) you can crank the heat up with a slower wire speed...this will burn right through the cargo floor and into the tophats/I beams and the slow feed of wire will add just enough rod to make a nice little flush puddle.
PLEASE practice this on scrap metal first, it takes very fine adjustment to get this technique right...BUT it will save you hours of drilling holes. Spend a couple short evenings on your knees with a MIG torch and youre done.
thanks man I going to practice thes
sorry for the spelling
zozo
zozo is offline
PostPosted: Mon Feb 04, 2013 11:51 am    Post subject: Reply with quote
Here's a cheap alternative:
http://www.instructables.com/id/How-to-Make-a-Spot-Welder-for-Cheap/
BarryL Premium Member
BarryL is offline
PostPosted: Mon Feb 04, 2013 11:32 am    Post subject: Reply with quote
I have that one. Works good but it sure is heavy. It gets hotter than Hades. You have to keep the electrodes filed flat and adjusted for pressure and proximity but I think that applies for all spot welders.
Stocknazi
PostPosted: Mon Feb 04, 2013 9:43 am    Post subject: Reply with quote
anyone used the harbor freight 240 spot welder?
WANTED:
Thomas Jefferson
Doug914
Doug914 is offline
PostPosted: Tue Mar 10, 2009 1:23 pm    Post subject: Re: welding floors Reply with quote
mike jansen wrote:
cant you weld the floors from underneath?
Thats the way i'm going to do mine. Might not be what was original, but it sure will be neat, strong, and less work. The edges I'll probably plug weld. Have to see once i get into it..
mike jansen
mike jansen is offline
PostPosted: Mon Mar 09, 2009 9:39 pm    Post subject: welding floors Reply with quote
ekimikem
ekimikem is offline
PostPosted: Sat Jan 24, 2009 10:04 am    Post subject: Reply with quote
smokeybus wrote:
Gmiee5 wrote:
How about this
The spot weld gun attaches easily to your home arc welder
http://www.eastwoodco.com/shopping/product/detailm...=undefined
Did anyone try this?
I have one of those, but I could never get it to work worth a darn. Maybe I'm doing something wrong, but it pretty much sucks. Rolling Eyes
Anyone tried one of these? I would be tempted to try one if I owned an arc welder.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98753
zao
zao is offline
PostPosted: Fri Jan 23, 2009 7:23 pm    Post subject: Reply with quote
Cool, Thank you.
-Kevin
skidmarksgarage.com
skidmarksgarage.com is offline
PostPosted: Fri Jan 23, 2009 9:26 am    Post subject: Reply with quote
http://www.evercoat.com/productCategory.aspx?cat=41
Use as directed, I wouldn't use this on a floor but for that Batt. tray may be the ticket. I'll be using this on my bus when I put on the new Qtr. panel where it meets the outer wheel house.
Mark
zao
zao is offline
PostPosted: Fri Jan 23, 2009 9:05 am    Post subject: Reply with quote
What type of metal glue were you guys refering to? It would be a huge help for my battery tray along the outside wheel well paint side so I don't have to repaint it.
-Kevin
BarryL is offline
PostPosted: Fri Jan 23, 2009 8:28 am    Post subject: Reply with quote
Looks like you still must hold the ground electrode opposite the gun electrode. I'd think that you would need lots of pressing to do it up right.
Dynamite_Goat
Dynamite_Goat is offline
PostPosted: Thu Jan 22, 2009 2:54 pm    Post subject: Reply with quote
Gmiee5 wrote:
How about this
Gmiee5
Gmiee5 is offline
PostPosted: Thu Jan 22, 2009 2:19 pm    Post subject: Reply with quote
How about this
camerod
Volksfab
camerod is offline
PostPosted: Thu Jan 22, 2009 11:13 am    Post subject: Reply with quote
gebug wrote:
camerod wrote:
IF you have a TIG welder with a spot timer, this is the ultimate tool...
http://www.tectorch.com/tec%20spot%20gun.htm
you need a spot timer for it to work right...kinda works like a resistance (prong type) spot welder, so it uses no filler metal BUT you only need access to one side....
What can you expect to pay for one of these ?
the water cooled version is about $385 accessory kit about $50
I think the gas cooled unit is around $300?
gas cooled obviously lower duty cycle but will never be used at max capacity on sheetmetal, so you should be able to go all day!
you can get them through Indiana Oxygen online, but It is special order only.
DON'T SHIT WHERE YOU EAT!
Page: 1, 2, 3  Next
