Fried points, then nothing...
littleredrooster679
littleredrooster679 is offline
PostPosted: Thu May 24, 2012 8:45 am    Post subject: Reply with quote
Folks,
Embarrassingly, it was simply a dead battery the whole time. I misread the reading on my battery charger, so thought it was good the whole time.
Thanks again for all of your input though!
"Once in while you get shown the light in the strangest of places if you look at it right"
modok
modok is offline
PostPosted: Sun May 20, 2012 3:45 pm    Post subject: Reply with quote
you can check the primary resistance with an ohm meter, should be approx 3 ohms, or put it on another car and see if it runs ok,
Or pull the distributor out a half inch, take the cap off, hook one plug wire to the coil with an old plug in it with the gap set at 3/16-1/4 inch, turn on the power and spin the dist and see if it appears to give a good spark
littleredrooster679
PostPosted: Sun May 20, 2012 3:40 pm    Post subject: - Reply with quote
How do I check the coil?
modok
modok is offline
PostPosted: Sun May 20, 2012 3:38 pm    Post subject: Reply with quote
the wire on those points is too short! but it should work
Check the resistance of the coil or try a different coil
Boolean
Boolean is offline
PostPosted: Sun May 20, 2012 1:58 pm    Post subject: Reply with quote
No clicks as in starter does not engage? If so, the problem isn't in the distributor but rather in the starter or ignition switch.
littleredrooster679
PostPosted: Sun May 20, 2012 1:15 pm    Post subject: Reply with quote
Guys,
Okay, I swapped out condensors and points, set the gap, then it turned the engine over a few times. Tried again and it wouldn't do anything, no clicks at all.
So I went back there and pulled dist cap off, touched the wire under the rotor, went back to start it and same thing... turned over a few times, then on the second attempt, it did nothing again.
Checked all fuses, they're good.. everything looks right.
I'm stumped! Anyone see anything wrong in this photo?
littleredrooster679
PostPosted: Sun May 20, 2012 1:06 pm    Post subject: oops Reply with quote
oops.
Last edited by littleredrooster679 on Sun May 20, 2012 1:24 pm; edited 1 time in total
arod
arod is offline
PostPosted: Sat May 19, 2012 1:34 pm    Post subject: Reply with quote
burned condenser?
the chupacabra is my homeboy
oarse
oarse is offline
PostPosted: Fri May 18, 2012 8:54 pm    Post subject: Reply with quote
Did you forget to put the rotor back on? I can't count how many times I've done this. Embarassed
modok
modok is offline
PostPosted: Wed May 16, 2012 5:35 pm    Post subject: Reply with quote
maybe the coil is shorted out, it would explain why the wire fried, normally that cannot happen
jfats808
jfats808 is offline
PostPosted: Wed May 16, 2012 4:32 pm    Post subject: Reply with quote
Troubleshoot. Check Fuses, coil, 12v power, etc. Your motor should still turn via the starter.
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
littleredrooster679
PostPosted: Wed May 16, 2012 4:09 pm    Post subject: Fried points, then nothing... Reply with quote
Guys/Gals;
cleaned up my motor last night w/ some engine-cleaner foam from my FLAPS.
Went to start it today, which did nothing but fry the wire in the points. I pulled them out, threw in a new one and set the gap, went to start it and NOTHING happened... no clicks, no more fried wire, no nothing.
Anybody have an idea here as to what it could be?!
