Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Sat Dec 08, 2018 5:19 pm Post subject: Re: My attempt at a 1904 |
Some oil filters drain back and this can make quite a bit of difference on a dip stick readings. I had to try several brands etc to find one that worked well.
The Hastings LF493F seemed to work well to stop it. As did the Wix-51342 These filters do have a higher bypass valve pressure of 16 PSI Whereas the usual VW Type 1 Engine and type 4's use a 6 or 7 psi bypass pressure. Perhaps this is why they solve the problem.
I have noticed that the 74mm Crank does pick up the oil and blow it out of the engine If I drive above 75 MPH for a long time. Perhaps yours was just too full of oil so it was smoking.
My engine didn't really settle in and have Zero valve adjust needed until It had about 15,000 on it and I switched from Castrol 5W30 to Mobel 1 0W40 and quit adding the ZDDP.
Took it out on the Interstate for a 100miles at 75mph or more. It was like 95' degrees out that day too. It went through a 1/2" quart of oil doing that but it broke it in. Valve adjustments are stable now and no smoke at all and it's not using any oil if it stay below 70mph.
I don't really have a proper breather setup on mine.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3600 Location: 802 The Pointless Forrest
Posted: Sat Dec 08, 2018 3:56 pm Post subject: Re: My attempt at a 1904 |
OK so is thing still running?
Still using that 010 distributor? _________________ "Albatross"! |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Thu May 23, 2013 5:17 am Post subject: |
Hey skills, are you going to have that mill dialled in by Litchfield? Looking forward to seeing it and swapping lies.
See you there.
Marshall _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Joined: January 01, 2007 Posts: 17889 Location: sticksville, ct.
Posted: Sat Mar 16, 2013 7:20 am Post subject: |
[email protected] wrote: |
this is not unusual for a fresh engine. Things should stabilize as it gets more miles on it. Just remember to periodically re-set idle mixture screws and check the timing and valve lash until things stop changing. |
for sure! i plan on doing some work with a LM-1 at some point too. i will either rent yours or see about borrowing a friends. i want to get her all dialed in the best i can _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Mar 15, 2013 7:48 pm Post subject: |
this is not unusual for a fresh engine. Things should stabilize as it gets more miles on it. Just remember to periodically re-set idle mixture screws and check the timing and valve lash until things stop changing. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
VIN Samba Member
Posted: Fri Mar 15, 2013 6:00 pm Post subject: |
VIN wrote: |
maybe i missed it.. but you had the oil level at the full mark on the dipstick with a 1 1/2 qt. sump. it was smoking. drained 1/2 qt. out and shes good to go?? |
what happend was the engine was 'new'. primed it, then filled it with break in oil. cranked it till the oil pressure gauge started to show pressure. topped it up to the 'full' mark on the stick. did break in, dumped oil and filled back up to the 'full' on the stick.
from there, ran it more on the stand then installed it in the bus. the whole time, it smoked as seen in the video's. as a sanity check (and suggested by john@aircooled) i dumped the oil again. put in exactly 2.63 quarts, let it settle and check oil level.
upon doing that, my 'full' mark was about 3/16-1/4 inch LOWER than the full mark on the stick. tried 4 different sticks, all came up the same. so, in total, with my lines and filter, it takes 3 and a spit quarts of oil total. (the spit is less than 1/4 of a quart)
if i filled it to the 'full' mark on the stick, it took 4 quarts even. so in all actuallity i overfilled it by almost 1 quart. i guess that would contribute to the smoke.
part of me feels like a toolbag for letting that happen, but it was a used case. i would have NEVER thought to check that the dipstick read correctly on a used, OE case. but like anything else, weird shit happens. perhaps the dip stick tube came loose at one point, and is just too far up...i have no clue, but i am glad that the fogger stopped and is clearing up the more i drive it _________________
Jake Raby wrote: |
Brian wrote: |
VIN Samba Member
Posted: Thu Mar 14, 2013 7:57 pm Post subject: |
maybe i missed it.. but you had the oil level at the full mark on the dipstick with a 1 1/2 qt. sump. it was smoking. drained 1/2 qt. out and shes good to go?? _________________ Co-owner, 2 Brothers Guns
[email protected]
SRP1 Samba Member
Posted: Thu Mar 14, 2013 7:37 pm Post subject: |
Awrsome! |
Posted: Thu Mar 14, 2013 7:32 pm Post subject: |
just wanted to give this a bit of an update. after dumping the oil, adding the 'correct' amount to the case and about 35 more miles of driving, it seems that the freight train has left the station
i can't repeat the smoke screen as i did in my last video. it is a bit on the rich side, but once the weather breaks, i will start on the carb tuning end of things.
as it stands now, i am getting about 18ish mpg, but that has been some spirited blasting around too. i will keep this updated as i go _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Mar 09, 2013 7:19 am Post subject: |
i am using a mann W-917
here are the specs
Principle Application:
Alfa-Romeo (86-93), Nissan Cars (67-89), Porsche (70-76), VW (71-83), Case, David Brown, Ford, New Holland Tractors, Nissan, Toyota Forklifts
Applications
Style:
Spin-On Lube Filter
Service:
Lube
Type:
Full Flow
Media:
Paper
Height:
3.79
Outer Diameter Top:
3.66
Outer Diameter Bottom:
Closed:
Thread Size:
3/4-16
By-Pass Valve Setting-PSI:
8-11
Anti-Drain Back Valve:
Yes
Beta Ratio:
2/20=6/20
Burst Pressure-PSI:
325
Max Flow Rate:
7-9 GPM
Nominal Micron Rating:
21
it had a pretty good burst pressure rating and micron rating, so i went with it. if there is a issue, please let me know _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Mar 08, 2013 10:50 pm Post subject: |
what filter are you using BTW? _________________ It's just advice, do whatever you want with it!
modok Samba Member
Joined: October 30, 2009 Posts: 27728 Location: Colorado Springs
Posted: Fri Mar 08, 2013 7:53 pm Post subject: |
Interesting timing, I just changed the oil myself. It took 2.5 quarts to get between the lines of my 40 horse dipstick, I did not change the filter. |
Posted: Fri Mar 08, 2013 7:50 pm Post subject: |
true.... you can trust nothing...not even a used case or oe dipstick. i want to thank you guys again, john, modok, srp1 and all the others that have advised me through this. i am keeping my fingers crossed that 1) the rings seated and 2) the oil level issue is all under control. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Mar 08, 2013 6:34 pm Post subject: |
It's SO frustrating sometimes, you have to check EVERYTHING anymore.
People new to the VW hobby think we are being jerks or "trying to make a point", or exaggerate, but it's just the way it is anymore.
I hope this drop in oil level solves the fogging issue. _________________ It's just advice, do whatever you want with it!
Posted: Fri Mar 08, 2013 10:14 am Post subject: |
Well then, shame on me for not making sure the dip stick was correct. According to the stick, 4 quarts registered full.
Dumping the oil, adding just 2.5 to the sump showed my oil level as low. I scribed a new mark, ran bus and topped up to the new mark. That being said, it took a total of 3 and a spit quarts to get it to my new full scribe mark.
I am thinking this may have been the issue the whole time. I will report back with my findings
This is your baby too john  _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Mar 08, 2013 9:53 am Post subject: |
I never said you didn't do what I suggested. I'm just trying to help. The rings do not suck. Either there is a problem with something, or there isn't. FOR NOW let's assume there is no problem with installation, and try to fix what we can without taking the engine apart.
1/2qt too much is "overfilled" in my experience.
skills@eurocarsplus wrote: |
Yes, h2 oil non syn.
John...dumped oil. Added 2.5 quarts. Let it settle. Check. It was NOT at the full level. Scratch new 'full' mark. Start bus, fill lines and filter. Re check oil level. It dropped. Fill back up to my 'new' full mark. Took 3 and 1/4 quarts total.
Ran bus for a bit, 10-15 minutes. Oil filter warm to touch. Smack throttle, no oil smoke, just a tad fat
Has t stat and flaps.
Why would you think I didn't do what I said? I am trying to figure out if it is my error, or the rings suck.
You say add the correct amount. I believe I did this time. 2.5 qts, run, re check and add to my new scratch mark on the stick for a total of 3.25 qts.
I had filled it to the full mark in the beginning, that was a full 4 quarts. This issue could be on me, not the rings.
So, how full is over filled? .25 quart? 1/2 quart? |
Posted: Fri Mar 08, 2013 9:30 am Post subject: |
So, how full is over filled? .25 quart? 1/2 quart? _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Mar 08, 2013 9:19 am Post subject: |
I don't think you did what you said.
Just change the oil and put the right amount in, and drive it. Does the engine have a thermostat? _________________ It's just advice, do whatever you want with it!
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Fri Mar 08, 2013 9:14 am Post subject: |
Did you use synthetic oil for breakin? That will cause the rings not to seat if so. I only see the 10-30 Gibbs in synthetic inless it is H2 oil. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends  |
