dhaavers Samba Member
Joined: March 19, 2010 Posts: 8487 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Mar 09, 2013 6:01 am Post subject: |
^^^ Clutch slave - yeah.
The front bolt is easy from underneath. For the back one I'd always managed from the engine bay
by jamming a big cold chisel to stop the nut spinning, then 2 wobble extensions stacked on my ratchet.
Then I joined Samba and learned to weld that nut in place. SWEET! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Sat Mar 09, 2013 12:37 am Post subject: |
Be sure you put some PB Blaster or other proper penetrating oil (NO wd40 or mere lube) on the clutch slave bolts. Getting that thing out is an exercise in frustration. I posted a technique to get it out. Have a gear wrench for it. Still a pain. Have fun. That hard plastic line on mine failed, so consider replacing it with the one from Bus Depot http://www.busdepot.com/251721477d while you are in there disconnecting it to replace the slave. Also, you can weld the nut on the slave bracket that will give you hell while removing it to make install easy and future service easy. JB Weld would be sufficient.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
AKAvant Samba Member
Posted: Fri Mar 08, 2013 11:14 pm Post subject: |
All good ideas, I'll try the puller first. Biking up to napa first thing in the morning. Need a bleeder too, changing clutch master and slave, and swapping in SS brake lines. Full day......gotta love 32 year old vdubs. _________________ 1981 Westy 2.0 P22 Weekender (Sold 9/2/13)
1982 Westy 1.6 diesel (Sold 10/1/14)
1999 Caravelle 2.5TDI Syncro
2003 California 2.5TDI Syncro |
Posted: Fri Mar 08, 2013 10:32 pm Post subject: |
Without a vice, how about drill a hole in a 2x4 slightly larger than the axle shaft, prop it
across a couple buckets or garbage cans & tap it out of the CV inner race as described...???
(Put a stack of towels on the floor to catch the axle when it drops out)
Yeah...I think like a cheap guy... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12396 Location: Santa Cruz, CA
Posted: Fri Mar 08, 2013 10:27 pm Post subject: |
I use a 3 jaw puller and it comes off nicely.
Timwhy Samba Member
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 2014 Location: Pittsburgh PA (ish)
Posted: Fri Mar 08, 2013 9:43 pm Post subject: CV Inner ball hub removal from drive-shaft tricks? |
So I'm replacing my cv boots and I have the axles off the car and the cv's disassembled but I do not have a table or a vice to work with. The inner ball hub does not want to slide off the shaft (circlip is removed) easily. I've started tapping on it lightly with a hammer and wooden dowel but with no success. Any one have some tricks?
Thanks! _________________ 1981 Westy 2.0 P22 Weekender (Sold 9/2/13)
