amotomura Samba Member
Posted: Thu Nov 15, 2018 8:32 am Post subject: Re: 71 Bay fuel tank outlet nipple |
Sorry to drag up an old post. Does anyone have a solution for hooking up a steel line to the end of the steel hose on the bottom of a later Bay tank? These tanks do not have the threaded bung on the bottom.
Would I be able to do a brake line flare and use brake line fittings? I’m not sure if a flare kit would work due to the pipe not being a standard brake hose size...
Thank you,
Andrew |
Dogo Samba Member
Posted: Sat Apr 21, 2018 10:40 am Post subject: Re: 71 Bay fuel tank outlet nipple |
I have all the hardware sorted. Could anyone give me a little “complete idiot” direction on wiring this?
Can I go straight to coil? Inline fuse necessary? Cable gauge important? Any other tips are appreciated.
Thanks in advance |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17653 Location: San Diego, California
Posted: Wed Oct 26, 2016 8:17 pm Post subject: Re: 71 Bay fuel tank outlet nipple |
Seems to that the inside diameter of that brake line might be too small and restrict flow. I would have used 1/4 stainless tubing.
Edit: I see that the label says it's 1/4 inch x 20. My mistake _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Busbodger Samba Member
Joined: July 08, 2012 Posts: 117 Location: Small Town, Tennessee
Posted: Wed Oct 26, 2016 8:00 pm Post subject: Re: 71 Bay fuel tank outlet nipple |
Thank you everyone. Lots of great details for us all to work with. |
Posted: Wed Oct 26, 2016 7:57 pm Post subject: Re: Installation complete |
rneithammer wrote: |
The job is done!
Actually, I finished it a while ago, and the bus has been on a major long trip with the solenoid installation. No issues at all.
Here are some pics:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1102604
Closeup of the parts I used, including a section of brake line from the FLAPS that goes from the tank outlet connection, across the top of the tranmission, to the solenoid.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1102603
Another shot of the parts. Also from the FLAPS, I got the adapters need to go from the brake line compression fittings to the 1/4" NPT fittings.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1102602
This is the tank outlet, with the tank to AN 6 adapter, AN 6 to 1/4" NPT male elbow, 1/4' NPT female to 1/4" NPT female coupler, and 1/4" NPT to brake line adapter. I bent the brake line into a squiggle across the top of the transmission, to allow the stuff on each side of the tranmission to move indpendently if they have to.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1102601
This is the solenoid, located on the opposite side of the transmission from the tank outlet. Not the most illustrative picture, but you can see how I mounted it: Made a bracket that mounts under a conveniently located chassis bolt. Tie-wrapped the solenoid to the bracket.
Getting this thing in, connected, wired and working was an all-day-er, but worth it. And, besides the fire protection benefit, it allows me to run the carb dry for winter storage of the bus, just by disconnecting the hot lead to the solenoid (which I connected to the coil hot lead), starting the engine and running it till it quits. |
How long did the zip ties last? I never have much luck with them long term. |
Posted: Wed Oct 26, 2016 7:56 pm Post subject: |
Opossum wrote: |
Parts you need:
Bought
Valve from here: http://www.afcvalves.com/mod121.html
Center AN fitting: http://www.anplumbing.com/Adapters/Aluminum-14.html
Gas tank fitting (right piece): http://www.cbperformance.com/ProductDetails.asp?ProductCode=3288
All for less than $ 100.00
When installed:
Make sure you:
Use gas rated Teflon tape or sealant on threads.
Use the bolt on top of fuel cut off solenoid to make bracket for extra support. You don't want the valve to wiggle.
Hook up solenoid to same wire that runs fuel pump. Hopefully the fuel pump is wired correctly through a relay.
I've had this on since April of 2011 and it works great and gives piece of mind. Shuts off fuel when engine is shut off and no rubber hose to rot out between valve and tank. |
Any problem with that weight dangling off of the fittings? Seems like it would be better bolted to the frame with a steel line going to it off of the tank.
I have a small Brenderup stamped steel trailer with a spare tire mounted to the front of the trailer. The spare tire vibrates a little with road imperfections. This led to cracks from the four bolt holes.
My daily driver also had cracks around a cheap trailer hitch that bolted to the bottom of the cargo area (trunk). I replaced it and welded up the cracks. |
CrRusty Samba Member
Posted: Sat Apr 11, 2015 3:27 am Post subject: |
I like the direction of this thread but, shouldn't the first thing after the fuel tank be the fuel filter. I would imagine any junk flowing out from the fuel tank would potentially allow the solenoid valve to eventually leak, just like a leaky carb problem. Anyone yet try a setup using a metal fuel filter like Bosch used in the 80's? |
grungeant Samba Member
Joined: February 04, 2013 Posts: 158 Location: Pennsville, NJ
Posted: Tue Nov 04, 2014 6:53 pm Post subject: |
Desertbusman wrote: |
This is how I made the tank fitting. It's 1/8" female pipe thread. Mainly because of wanting to have a filter before the solenoid valve and not after.
Also had gotten a 1/4" x 24" steel brake line to bend and replace the stock steel line that goes around the left end of the fan shroud for using good 1/4" hose for the flex connection. However the original steel tube is already 1/4" diameter for the 5.5mm hose to attach to. So instead I'll either get a 5/16" steel brake line for the slipon 1/4" hose or else use the fittings on the brake line. But hadn't yet found an adapter fitting to fit the brake line fitting. The adapter fitting you have for the brake line is the male end pipe thread? |
How did you get the 1/8 pipe thread adapter on the tank nipple?
Also can I just unscrew the big nut and do all this with the tank still in the bus, or does it need to come out?
What does the nut thread onto? Is the tank threaded?
Also what is the big nut on the bottom of the tank made out of? Is it brass?
And the outlet on my tank is straight down, and not curved.
I'd like to get a curved one like in your picture. _________________ 1974 Tintop with a nice rack
"You should remember it's peace of mind you're after, and not just a fixed machine."
Robert Pirsig |
Posted: Sat Oct 25, 2014 8:49 am Post subject: |
Neat! I didn't know they made tape rated for ethanol. _________________ 1974 Tintop with a nice rack
Robert Pirsig |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Sat Oct 25, 2014 7:52 am Post subject: |
I know this is an old thread, but I am doing something similar myself using NiCopp brake lines.
When you guys were talking about sealing the threads it's not so much using something rated for fuel it's more important to use something rated for ethanol.
I am a fuel hauler and every threaded fitting at a gas station is coated with a dope called Gasoila E-seal
http://www.gasoila.com/products/pipe-thread-sealants/gasoila-e-seal-thread-sealant.html
You can get it on amazon for about $15.
I am using the 111 version of the valve
http://www.dan-marc.com/79-afc11112.html
which uses 1/8 fnpt threads going in and out, as does my facet fuel pump.
The stock fuel filter for a 1986 F-150 with a 4.9L uses a fuel filter that has female threads that will accept 5/16 brake line going in, and 1/8 mnpt threads going out that I can screw directly into my fuel pump, and the filter is 10 microns as opposed to the 74 microns on the regular Facet thread on filter that a rubber line clamps to.
Also I am using the 5pin Rabbit relay that has the pin for the tach pulse and will shut off power if the engine is not running for my fuel pump and the shut off valve.
What size is the ID of the stock fuel tap on a 74 bus?
I will need to use about 1.5"-2" of rubber to transition from the stock tap to a metal brake line. 3/16 line looks more close than 1/4.
I thought about this after I put my tank, and engine back in and attempted to plumb the fuel lines and realized I wanted to use the valve.
Also, has anyone had any issues with the fuel getting hot and vaporizing in the metal lines?
I thought about slicing open some rubber fuel line and wrapping it around the metal lines as insulation in some hotter areas.
I also got a fireproof sleeve to cover the rubber pieces where I need to go from the tank to the metal, and from the metal to my carbs.
http://www.americanfiresleeve.com/aviation-marine-...cable.html _________________ 1974 Tintop with a nice rack
Robert Pirsig |
rneithammer Samba Member
Joined: November 09, 2007 Posts: 197 Location: Media, PA, USA
Posted: Sun Aug 25, 2013 7:48 am Post subject: |
Yes, the brake line fittings I have are 1/4" NPT.
I like that fitting you made...can you give any details on the process? I also like the idea of having a filter before the solenoid valve.
Seeing this brings up a question: I thought there was supposed to be some sort of filter screen (filter sock?) at the tank outlet - like a wire screen that goes over the outlet tube that sticks into the tank. When I took the original tank fitting off, I did not see this, so I have no clue whether I have it or not, what it is supposed to look like, can I get one and install it using the tank outlet fitting I have, where would I get one, etc.?????
On the plus side, my tank is pretty clean I think...only a few particles of rust came out, even after I dumped some sacrificial gasoline in there to flush it out. |
Desertbusman Samba Member
Posted: Sat Aug 24, 2013 8:19 pm Post subject: |
Also had gotten a 1/4" x 24" steel brake line to bend and replace the stock steel line that goes around the left end of the fan shroud for using good 1/4" hose for the flex connection. However the original steel tube is already 1/4" diameter for the 5.5mm hose to attach to. So instead I'll either get a 5/16" steel brake line for the slipon 1/4" hose or else use the fittings on the brake line. But hadn't yet found an adapter fitting to fit the brake line fitting. The adapter fitting you have for the brake line is the male end pipe thread? _________________ 71 Superbug
71 Westy |
Posted: Sat Aug 24, 2013 7:37 pm Post subject: |
BINGO! Thanks. |
Posted: Sat Aug 24, 2013 7:32 pm Post subject: Re: Posting pics |
One more thing: I tried...followed the directions in an FAQ, but I'll be danged if I can figure out how to make pictures (not just links to them) appear in a post. Any advice welcome. |
Don't copy the address for the address bar at the top of your brower page, but copy the link that begins with "Img" from the Samba page just to the right and above the picture.
Posted: Sat Aug 24, 2013 7:26 pm Post subject: Posting pics |
Posted: Sat Aug 24, 2013 7:04 pm Post subject: Installation complete |
The job is done!
Here are some pics:
Posted: Sun Apr 07, 2013 10:51 am Post subject: |
Here it is:
"The one I bought is an AFC121
1/4" female N.P.T., 12V N.C. 1/4" orifice Advanced Fuel Components, Inc.
There was some serious discussion about selecting that one on the Samba. Search and you will find it. the company has it set up for a $7 discount if you use the coupon code "thesamba" |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52812 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Apr 07, 2013 10:10 am Post subject: |
Trying to find that fire sticky......what forum is it under? |
