Type 3 Automatic to Manual conversion?
Multi69s
Multi69s is offline
PostPosted: Thu Jul 14, 2016 5:14 pm    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
Another advantage to having the kick down switch (especially with a high performance engine), is that the trans will stay in each gear to a higher RPM. That way you can take advantage of any cam change that was made. Otherwise, the trans will shift too soon, and leave a lot of power on the table. As far as the pressures, you really should have the Bentley anytime you are working on the trans. It will give you the pressures and which ports to plug into. Plus it has a good trouble shooting list for dealing with the various shift issues that you may encounter.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Jul 14, 2016 8:54 am    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
There are three inputs to the auto tranny for gear changes and sensing:
1) Engine RPM (governor)
2) Engine load (vacuum modulator)
3) Full throttle demand (kickdown switch)
There is fourth if you want to count the manual selector.
There are times when the first two cannot trigger a downshift even though you have the throttle open all the way. A kickdown switch, triggered by pressing the pedal beyond the full throttle position (more about that in a moment), can force the downshift. It is useful when passing or when maximum acceleration is needed. You can simulate the effect by manually shifting the selector down one gear. That takes more coordination and distraction that just pressing the pedal harder.
VW designed clever linkages for both carb and FI models that give you tactile feedback of where in the gas pedal travel the kickdown switch activates. They incorporated a spring between two levers. In this way, when you reach full throttle (but not yet the kickdown position), you feel the second spring pressure resisting your foot pressure. This tells you that you are at full throttle. Pressing further takes more effort, and so you know by feel that you are triggering the downshift. They look like this:
Carb:
FI:
With this feature you can exercise a great deal of control of both up and down shifts with your right foot:
- Downshifts can of course be forced by mashing the pedal.
- Upshifts can be forced by letting off the gas for a moment, then pressing it again-- but not past the kickdown position.
When the engine is running well and with the kickdown switch, even fun canyon roads can be driven with an automatic, up-and down-shifting almost as well as with a stick, all by modulating the throttle. Very satisfying!
SBD
SBD is offline
PostPosted: Thu Jul 14, 2016 8:43 am    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
My wife used to have a '71 Squareback that had been converted from FI to a stock VW dual carb setup. It didn't have a kickdown switch on it and I don't recall it really being a problem. The trans seemed to shift fine. I remember I was going to add one but that was probably more of the anal-retentive side of me thinking that it SHOULD be there. Very Happy I remember working on a bracket for a switch but I also remember I never got around to mounting a switch before we sold the car. Cool
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
baker151
baker151 is offline
PostPosted: Thu Jul 14, 2016 8:09 am    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
Multi69s wrote:
Baker,
I have always had good luck with my auto trans and dual carbs. From Solex 32s to Weber 34ICTs to Weber 40 DCNFs. I have always pulled my vacuum signal from the balance tube, and the transmission shifts perfectly. However, on the dual DCNFs (Which normally doesn't have a balance tube), I made one up that connected to all four intake runners, and it works great.
Also, since the transmissions are getting old, and the vacuum signal may be off from a OEM setup, see if you can rent/borrow/ purchase a set of transmission gauges.
This way you can make sure and or adjust the transmission fluid pressures to match your intake setup.
In that case I'm pretty close, I have all of vacuum lines ran. Intake plenums drilled, and plumbed.
For the most part it runs, but has the shifting issues at rpms or off the line(so to speak).
I'll rent a set of the gauges and check it out. Typically what kind of negative pressure and at what rpms are needed to initiate the shifts?
On the subject of a kickdown switch, I've been told it may be necessary but I'm lacking a clear explanation of the function and purpose. Can you help me out with that?
Thanks guys for your help! If i get through it once, I can pass the knowledge on! lol
69' Squareback
69' Dodge Dart Custom, 383 big block.
RIP-78' bus.
View user's profile Send private message Instagram Classifieds Feedback
Multi69s
Multi69s is offline
PostPosted: Sat Dec 12, 2015 1:15 pm    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
reay wrote:
If you change the carbs you are going to end up having to fix up some kind of kick down switch because the original one only works with the solex linkage.
That's not too hard to do, any type of momentary flap style switch will work. You just have to come up with some way of positioning it. This is how I did it.
69 road Bug 2110
My builds
Bobnotch
Bobnotch is offline
PostPosted: Thu Dec 10, 2015 11:07 am    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
baker151 wrote:
I know this thread is old but I'm in the same-ish boat. So I'll post here rather than start a new thread.
I purchased an Auto SB a few years ago and drove it for a bit but its been rather bothersome, so now it sits in my garage waiting for me to do something with it.
Its was built up to an 1835 and converted to dual carbs before I purchased it. Although I upgraded the Solex 32's to Empi Dual 40's to satisfy the 1835, I'm still not entirely impressed or satisfied with the performance. So I had a couple of questions.
Would it be possible to make the dual carb setup work well with the Auto?
Would it be possible to mount a manual transmission to the engine? I've heard the case is different and my require an adapter plate of some sort. What transaxle mods would I be looking at?
If I can keep the auto and make it run smooth I'd be fine with that. If i can convert to manual and keep the 1835 I have and get the performance I'd be fine with that too. Just want to feel it out and see what is possible. I love the Square and would love to keep it. I just need some opinions or remedies before I move forward.
Another option would be finding a MT pan, and installing it under your current body. Keep in mind that this will make the car no longer "numbers matching", but it would allow you to have the MT trans you want. Otherwise you're looking at a lot of work converting.
Or, you can do a search on using Solex carbs on a larger engine. Most go with larger venturies, and then do some jet changes. This works until you get into the 2110 engine size, where the stock oil bath air cleaner becomes the limit of intake air flow (it'll crack the air cleaner housing trying to flow more air).
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
reay
reay is offline
PostPosted: Wed Dec 09, 2015 11:33 pm    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
I have a 1835, auto and dual solex. The only thing I did was put in larger main jets and it's working pretty darn well now. Well, it's a longer story than that, but yes the 1835 is fine with stock solexs.
Tom Reay
Nothing is standard o a Standard!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop
Multi69s
Multi69s is offline
PostPosted: Wed Dec 09, 2015 2:52 pm    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
Baker,
69 road Bug 2110
My builds
raygreenwood
raygreenwood is offline
PostPosted: Wed Dec 09, 2015 1:02 pm    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
Also another point that many missed in this original thread.....is that if you want to go to manual from automatic.....why waste effort and permanently screw up the pan/tunnel installing a clutch cable and bowden tube?
You can install a simple metal hydraulic line and install a hydraulic clutch and master cylinder for a fraction of the effort without doing anthing non-reversible to the car. Ray
baker151
baker151 is offline
PostPosted: Wed Dec 09, 2015 12:22 pm    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
69' Squareback
RIP-78' bus.
V8Square
V8Square is offline
PostPosted: Sun Jun 02, 2013 7:06 am    Post subject: Re: Type 3 Automatic to Manual conversion? Reply with quote
TL Jer wrote:
Hey, all. First ever post, dear Lord don't let me f*** up. Didn't see this topic in FAQs or in existing threads, so I apologize if it's been asked to death already or if it's a "duh" on the order of "What's a front beam?"
Anyway, I haven't owned a VW in 30 years and am looking for a '66-'69 Fastback daily driver. I must have a manual trans, which means I'm passing on some promising looking cars simply because they have an automatic. Is an auto-to-manual conversion doable? Are there any differences with an Automatic's floor pan? Is adding a clutch pedal and manual shifter a bolt-on deal? Would it be worth the hassle and expense or am I better off just looking for a 4-speed car?
Thanks,
Jer
I have the pieces you need to make the conversion from automatic to standard. Email me.
burnt63
burnt63 is offline
PostPosted: Sat Jun 01, 2013 6:39 pm    Post subject: Reply with quote
i recently picked up a 70 auto notch. with in a day of owning it I was asked a good handful of times if I wanted to sell it. apparently a lot of people like the autos.
'63 bug...'67 bug... '87 cabriolet... '08 rabbit
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Mon May 27, 2013 7:37 am    Post subject: Reply with quote
I have an auto (fully automatic Not Auto Stick)
And I love it.. although it Is forsale and way less than a day drive
74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS4 "NKOGNEATO"
Geothon
Geothon is offline
PostPosted: Sun May 26, 2013 3:23 pm    Post subject: Reply with quote
I did the swap using hydraulic clutch. Vanagon master, slave and custom made nylon tube that i ran inside the tunnel.
Autos are smooth and may be even reliable but too expensive once anything goes wrong. I didn't want to replace the diff that started whining on my 73 Square. Loved how the manual changed the car.
KTPhil is offline
PostPosted: Sun May 26, 2013 3:02 pm    Post subject: Reply with quote
Don't dismiss the automatic so quickly. With a well-tuned motor and no vacuum leaks, you have a lot more shifting control than you do with most automatics; this is not the lazy slushbox of American cars.
Learning to "tap" the throttle to force a gentle downshift, or letting up a hair to force an upshift, can give you nearly the control a manual does, even on twisty roads. The torque converter smooths out any jerkiness from this right-foot behavior, so it's still a gentle ride plus shift control. That, plus the kickdown switch, and I almost never had to manually shift the automatic to get exactly the gear I wanted.
I used to have a '71 square automatic, and I still have the family 4-speed fastback, also a '71; so I had a good comparison.
If you have any stop and go driving, you will LOVE the automatic, and even driving through the canyons where I lived, the automatic was FUN! They can be driver's cars, too. Lots of lower end pep due to the torque multiplication.
TL Jer
TL Jer is offline
PostPosted: Sun May 26, 2013 9:56 am    Post subject: Reply with quote
Thanks for the great replies.
I seem to have stirred some real automatic love here, which is good. I'm searching the Samba classifieds for Fastbacks within a day's drive from So Cal and there are some nice Automatics there and I hate to pass up a nice car just because it's an Automatic. But I love manual trans cars (I've owned mostly slushbox cars, so I know what I'm missing). So I believe I'll leave the Automatics unmolested for you guys that appreciate them and keep looking for a stick.
Thanks again.
Stefan T
Stefan T is offline
PostPosted: Sun May 26, 2013 7:16 am    Post subject: Reply with quote
you must fix a pipe to the clutch wire in the pan
more things
pedals for manual
gear box
drive shafts
shifter and bottom plate to manual shifter
gear shaft and conection to the gear box
flywheel and clutch
clutch wire
i hope this all exept for some smal things
i did this in 83
but we have a complet car to take parts from
marchi
marchi is offline
PostPosted: Sun May 26, 2013 6:29 am    Post subject: Reply with quote
I have owned 11 T3's only 3 were manuals. I love the auto!
I drive my VW or I walk
'70 Squareback
'21 Tiguan (daughters)
SOLD Sad
'69 Fastback (Flamer)
Yabbadubbadoo
Yabbadubbadoo is offline
PostPosted: Sun May 26, 2013 5:34 am    Post subject: Reply with quote
Tram wrote:
Yabbadubbadoo wrote:
I think if you're patient you will find a manual shift Type 3 in the right condition.
Autos are great cars in their own right. Super cool cruisers. Id love to own one some day but my manual fastback must get finished first. Id say don't convert one just from a conservation point of view. It's not a walk in the park to convert one properly. The central chassis tube is missing the clutch tube.
Most people turn their noses up at Type 3 Automatics... until they drive a good one. Then they want one.
I totally agree. The auto suits the smooth ride of a type 3 perfectly especially once the desire to go fast subsides. It's probably a right of passage though. Must own a manual first, then think about an auto once you're done friggin' around with clutches and driving a stick shift in traffic.
Then drive a 'good one' (like you said) and then lay awake at night scanning the classifieds till 2am.
So many autos get neutered of their auto stick for no good reason that I believe an original one will be increasingly hard to find compared with manual. In fact if I were a collector..... mmmmm better keep that idea to myself.
Tram
Samba Socialist
Tram is offline
PostPosted: Sun May 26, 2013 1:21 am    Post subject: Reply with quote
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
