slalombuggy Samba Member
Posted: Tue Jun 18, 2013 5:54 pm Post subject: |
Glenn wrote: |
slalombuggy wrote: |
You have a 120 cam so you are going to spin the motor.
brad |
Not sure how much spinning it will do.
one4house wrote: |
Stock heads and 34 Pict 3 carb |
Ya, guess I missed the heads and carb size. You'll be fine without them if you don't want to. You'll run out of air before rpms......
brad |
mxracer Samba Member
Posted: Tue Jun 18, 2013 3:35 pm Post subject: |
Yes, the under cylinder or "sled" tins are missing and they affect cooling.
They probably left them off because of the way the j-tubes are routed. |
one4house Samba Member
Joined: July 18, 2009 Posts: 1121 Location: Sherman Texas
Posted: Tue Jun 18, 2013 3:17 pm Post subject: |
Here is what I found when I jacked it up. There is a lot less leaking than I was expecting. It puddles a little in the garage, but I do not see anything excessive under the car.
I am guessing you only need to vent if you have a problem with leaking? _________________ My Old 64 Field Find
My Old 66 Squareback
My Old 66 Beetle
My Old 70 Squareback
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79670 Location: Sneaking up behind you
Posted: Tue Jun 18, 2013 2:46 pm Post subject: |
brad |
one4house wrote: |
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Tue Jun 18, 2013 2:36 pm Post subject: |
You have a 120 cam so you are going to spin the motor. Vent the right side cover. If the vent tubes are threaded into the valve cover, you can buy a pipe plug to fill the hole instead of the capped tube on the left side. Clean hte threads in the cover good and loc-tite the plug in
brad |
Glenn  Mr. 010
Posted: Tue Jun 18, 2013 2:30 pm Post subject: |
If you don't need them vented... leave them alone. _________________ Glenn
Member #1009
#BlueSquare
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Tue Jun 18, 2013 2:25 pm Post subject: |
vent them. |
Posted: Tue Jun 18, 2013 2:21 pm Post subject: Valve Cover Vent Blocking? Cylinder Tins? |
1915, Engle 120 Cam, Stock heads and 34 Pict 3 carb
The valve cover vents are blocked off with caps and the caps held on with hose clamps.
This does not seem right to me. What is the proper way that this should be done?
Should I have the valve covers vented or not? _________________ My Old 64 Field Find
My Old 66 Beetle
