stripped points screw
Adam91
Adam91 is offline
PostPosted: Sun Sep 22, 2013 5:58 pm    Post subject: Reply with quote
alright, i might just end up replacing the distributor then. it moves quite a bit. and ill try not to strip the next one. haha
View user's profile Send private message Facebook Twitter Instagram Gallery Classifieds Feedback
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Sep 22, 2013 5:54 pm    Post subject: Reply with quote
Yes, a larger SAE screw will work... unless you strip it also.
Up/down play indicates broken/work/missing fiber washers and/or shims.
It's like having too much endplay on the crankshaft.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Adam91
Adam91 is offline
PostPosted: Sun Sep 22, 2013 5:52 pm    Post subject: stripped points screw Reply with quote
Adjusting points and stripped the screw in an 009 distributor. is it really just as easy as getting an 8x32 screw and screwing it in? also I noticed my distributor shaft has a decent amount of up and down play. should I just replace?
