Oil Pump filter Mount ?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Oct 10, 2013 2:27 pm    Post subject: Reply with quote
Mr.Duncan wrote:
Glenn wrote:
Get a 26mm pump and not a oversized 30mm pump.
The stock pump is 26mm.
I thought stock was 21mm?
For a older engine it is.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Cusser
Cusser is offline
PostPosted: Thu Oct 10, 2013 2:23 pm    Post subject: Reply with quote
My CB Maxi2 pump (described above) has 26mm gears. I know because when I changed to a dished camshaft, I bought a 26mm "typical" oil pump and used its gear with the shaft in my Maxi2.
Mr.Duncan
Mr.Duncan is offline
PostPosted: Thu Oct 10, 2013 12:53 pm    Post subject: Reply with quote
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
Cusser
Cusser is offline
PostPosted: Thu Oct 10, 2013 12:37 pm    Post subject: Re: Oil Pump and cooler ? Reply with quote
Bunky67 wrote:
After doing some research on changing the oil pump to a filter type. I was told that if the new pump, pumps too much pressure the oil will not go through the cooler, Is this true and how can I tell if it's bypassing the oil cooler ?
I'm likely wrong, as usual - but don't all the VWs have high pressure relief valves (2 on the later models) that regulate oil to bypass the oil cooler if the oil pressure is too high, like when cold and before the oil has warmed up (when the viscosity becomes less) ? In other words, to the VW engineers, too much pressure meant that the engine/oil temperature was too cold.
I've been running a CB Maxi2 oil pump/filter combination for over 30 years on my 1835cc engine; so old it says Claude's Buggies !!!
Mr. 010
Glenn is offline
PostPosted: Thu Oct 10, 2013 12:37 pm    Post subject: Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bunky67
Bunky67 is offline
PostPosted: Thu Oct 10, 2013 12:32 pm    Post subject: Oil Pump and cooler ? Reply with quote
Mr. 010
Glenn is offline
PostPosted: Fri Sep 27, 2013 2:40 pm    Post subject: Reply with quote
No... the oil pumps are different between stock and one with a filter.
There's dished and flat cams so you need the right pump to match.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bunky67
Bunky67 is offline
PostPosted: Fri Sep 27, 2013 2:35 pm    Post subject: Oil Pump filter Mount ? Reply with quote
I would like to put an oil filter on my Dune buggy with a 1600 Single port, from what I have read there is a Early model and a Late Model, and the Cam gears are different,
My Brother has a New pump with the oil filter mount, if I tear my engine down and find that the pumps are different, is it possible to just change the filter mount and use my original pump ?
