74 Super Beetle antenna
rolfestim
rolfestim is offline
PostPosted: Mon Jun 17, 2024 4:04 am    Post subject: Re: 74 Super Beetle antenna Reply with quote
Dwayne1m,
Did you ever replace your antenna? My 79 has something similar and I'd like to replace it, as well.
vwoldbug
vwoldbug is offline
PostPosted: Mon Mar 27, 2017 6:57 pm    Post subject: Re: 74 Super Beetle antenna Reply with quote
I believe that is a Motorola antenna that some vw dealers used . You might try google
galancline
galancline is offline
PostPosted: Mon Mar 27, 2017 1:00 pm    Post subject: Re: 74 Super Beetle antenna Reply with quote
My 1977 Super Beetle Convertible has the same antenna. I think they changed to this style in the last couple of years they imported Beetles in to the states.
Dwayne1m
Dwayne1m is offline
PostPosted: Mon Oct 10, 2016 2:11 pm    Post subject: Re: 74 Super Beetle antenna Reply with quote
I never found a replacement that had the 3 screws. I ended up welding the holes shut and went with a manual retractable antenna.
galancline
PostPosted: Mon Oct 10, 2016 12:40 pm    Post subject: Re: 74 Super Beetle antenna Reply with quote
did you ever find a replacement for your antenna?
I have the same antenna on my 77 SB convertible
Oldchevyguy
Oldchevyguy is offline
PostPosted: Sun Oct 20, 2013 4:57 pm    Post subject: Reply with quote
Joel wrote:
Are you talking about power antennas?
Dunno how you'd go in a LHD with the fresh air box in the way but i had one in my RHD 1303 which has heaps more room and it was still a royal PITA to fit.
I had to remove the hood hinge to get it in there and with the lack of space for the motor the mast ends up at a funny angle leaning outwards
Mine is just the manual retractable. I tried the power, but as you say, there just isn't enough room.
Dwayne1m
Dwayne1m is offline
The antenna is not power operated. Have to push it down by hand. Mid America sells them for around $20.
Joel
Joel is offline
PostPosted: Sun Oct 20, 2013 2:45 pm    Post subject: Reply with quote
mountainkowboy
mountainkowboy is offline
PostPosted: Sun Oct 20, 2013 11:57 am    Post subject: Reply with quote
The retractable works on a standard and the early flat glass supers, don't remember if they work on a curved windshield...........I imagine it would.
Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater"
Dwayne1m
Dwayne1m is offline
PostPosted: Sun Oct 20, 2013 10:44 am    Post subject: Reply with quote
Thanks. I'm gonna give the retractable antenna a try.
Oldchevyguy
PostPosted: Sun Oct 20, 2013 8:20 am    Post subject: Reply with quote
Dwayne1m wrote:
Has anyone ever tried one of those retractable antennas? Do they fit w/o a problem? I'm thinking of going that route so I can use a car cover.
I have one on my '74 Super. Easy to install, looks good, and works great.
Dwayne1m
Dwayne1m is offline
PostPosted: Sun Oct 20, 2013 7:18 am    Post subject: Reply with quote
BeetL62
BeetL62 is offline
PostPosted: Sat Oct 19, 2013 8:35 pm    Post subject: Reply with quote
My '74 Super had the exact same antenna. There was a cover piece that covered the screws so they are not visible. I could not find a replacement, so I welded the screw holes and changed it out to the style that is available.
mountainkowboy
PostPosted: Sat Oct 19, 2013 4:48 pm    Post subject: Reply with quote
That's the wrong antenna........the right one is a Harada 09V
Chuck in Socal
78 Honda CB750K
Beeble1
Beeble1 is offline
PostPosted: Sat Oct 19, 2013 2:02 pm    Post subject: Reply with quote
Stock ones to dot have screw holes... There is a nut under the body.
Beeble1, 1973 Super (o\_|_/o) 1600cc w/ Dealer A/C
Beeble2, 2013 Beetle 2.5L Daily Driver
Dealership items from Bishop-Wayne Volkswagen & Turner Volkswagen in Kankakee, IL wanted
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
68IHscout
68IHscout is offline
PostPosted: Sat Oct 19, 2013 1:59 pm    Post subject: Reply with quote
On my 74 the hole is oval, my antenna base is different than yours , so id. Say youres is aftermarket.
Dwayne1m
Dwayne1m is offline
PostPosted: Sat Oct 19, 2013 1:52 pm    Post subject: 74 Super Beetle antenna Reply with quote
Here is a pic of the antenna on my 74 SB. I want to replace it but I can't find one like it. Is this a stock antenna?
