costal_cat Samba Member
Posted: Wed Aug 20, 2014 7:08 am Post subject: |
aswah wrote: |
the levels are good... I check them religiously. If I start my van, run it for a couple miles, turn off the van then turn it back on the light nevers comes back on. I appreciate all the help. |
Had same issue same thing came on, turn off van, turn back on goes away, replaced the sensor totally fine now _________________ 87 Syncro Westy
TDI Overland Parts engine conversion |
morymob Samba Member
Posted: Wed Aug 20, 2014 5:09 am Post subject: |
Jumper the plug at tank, test drive & see if cond changes. |
Posted: Tue Aug 19, 2014 11:14 pm Post subject: |
greenraVR6 wrote: |
aswah wrote: |
what is best way to clean the sensors... I know that may sound stupid but I do not want to harm them. steel wool? |
or buy a new one, they're only around $8... |
2x, It isn't uncommon when trying to remove an old sensor that the sensor just cracks in two. Note that there is an early and late sensor design.
Also consider replacing the expansion tank. They get old and crack just like the sensor.
The circuitry for the light is also known to give problems. Somewhere hidden deep here on The Samba are some threads on this. |
greenraVR6 Samba Member
Joined: January 19, 2011 Posts: 306 Location: Bellingham, WA
Posted: Tue Aug 19, 2014 11:08 pm Post subject: |
aswah wrote: |
or buy a new one, they're only around $8... _________________ '88 vanagon*****'91 gti 1.8t*****'04 r32*****'11 suburban z71 |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10226 Location: Mt Lemmon, AZ
Posted: Tue Aug 19, 2014 10:48 pm Post subject: |
aswah wrote: |
Try a soak in vinegar then pick at the crud with something that will not do any damage - perhaps a toothpick or bamboo skewer (depending on how bad they are. Possibly something stronger (such as CLR) may be necessary. |
aswah Samba Member
Posted: Tue Aug 19, 2014 9:10 pm Post subject: |
what is best way to clean the sensors... I know that may sound stupid but I do not want to harm them. steel wool? _________________ WIT WA DA DA (Peace and Unity)
Aswah, Lisa, Beaumont and Loose Lucy Too!
1989 Westy
2013 Jetta Sportswagon TDI |
aswah Samba Member
Posted: Tue Aug 19, 2014 9:07 pm Post subject: |
the levels are good... I check them religiously. If I start my van, run it for a couple miles, turn off the van then turn it back on the light nevers comes back on. I appreciate all the help. _________________ WIT WA DA DA (Peace and Unity)
1989 Westy
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2717 Location: Missoula MT
Posted: Tue Aug 19, 2014 6:55 pm Post subject: |
Stupid question but did you check your coolant level? We were just on a bus caravan road trip and my buddy in his 85 kept getting the intermittent blinking light. Turns out his expansion tank was bare and his main tank was low on coolant but not to the min line. So when ever his bus bounced around the level would dip just below the sensor triggering the light. Worth checking to make sure your good there. I have no idea why my buddy never checked his coolant before we embarked on a 1000 mile roadtrip  |
Posted: Tue Aug 19, 2014 3:09 pm Post subject: |
Vinzanto wrote: |
...but I think if your low coolant light is going off that will trigger the temp gauge and almost peg it if I recall correctly... |
True on an 84, but I believe that changed later. |
Vinzanto Samba Member
Joined: March 22, 2012 Posts: 247 Location: Kansas City
Posted: Tue Aug 19, 2014 2:32 pm Post subject: |
Yeah I think the blinking coolant light means low coolant wheras your temp gauge shows the temperature, but I think if your low coolant light is going off that will trigger the temp gauge and almost peg it if I recall correctly. I second the sensor in the expansion tank. _________________ 1984 Vanagon Westfalia Wolfsberg |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17147 Location: Brookeville, MD
aswah Samba Member
Posted: Tue Aug 19, 2014 2:22 pm Post subject: a simple question (coolant warning light) |
My warning light for overheating started coming on periodically recently. The temperature seems to hold perfectly fine. Does this warning light come on for other things? I did do a search on prior posts and realize it could be an air bubble (which I had that problem several years back), etc. I am going to get it checked out soon but still need to drive for a week or two first. Thanks in advanced! _________________ WIT WA DA DA (Peace and Unity)
1989 Westy
