1vw4x4 Banned
Posted: Mon Sep 01, 2014 12:25 pm Post subject: |
I do typically add a little bit of grease, but have always been concerned
about getting the grease on the rubber of the vacuum actuator.
Do you have a suggestion as to the type of grease to use?
I also have the small hose piece in place. These will keep the heavy wash downs away, but do not seem to be fully water tight on mine.
| gears wrote: |
| These are normally covered in grease, which is held in place by a short piece of 5/8" or 3/4" ID rubber breather hose. If this is omitted, the shafts will freeze up. I'm far from my syncro, or I'd take photos/measurements for you. |
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Mon Sep 01, 2014 9:49 am Post subject: |
These are normally covered in grease, which is held in place by a short piece of 5/8" or 3/4" ID rubber breather hose. If this is omitted, the shafts will freeze up. I'm far from my syncro, or I'd take photos/measurements for you. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
1vw4x4 Banned
Posted: Sun Aug 31, 2014 7:47 pm Post subject: Syncro De-coupler and axle lock shaft frozen! |
This Syncro has seen its share of bad weather. As I removed the
transaxle yesterday I was amazed of the crap jammed in every orifice.
What the customer complain is, that both the de-coupler and axle lock don't
work. Basically both are frozen. Obviously the poor environment
this syncro was subject to did this. An easy fix could have been no seal
on the steel shaft. This would allow gear oil to seep into the shaft further
and prevent corrosion. I can't come up with any better way to continually add
lube to this area, preventing this again. Any ideas? |
