GoWesty printed circuit board replacement kit
bajaleo Premium Member
bajaleo is offline
PostPosted: Sun Nov 21, 2021 4:48 pm    Post subject: Reply with quote
I just finished permanently splicing my harness to the plug GoWesty provides. It's a really clean setup and I didn't really care for the pcb plug that went into the old original plug. And yes, you can simply unplug the new plug from the instrument panel. Plus it's in a better location for removing and replacing the instrument panel.
Altoona wrote:
t3 kopf wrote:
Permanantly splicing it means you cant remove it for maitenance and i dont like that idea
Can't you just unplug the harness from the circuit board?
Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered.
t3 kopf
t3 kopf is offline
PostPosted: Sat Apr 04, 2015 4:16 pm    Post subject: Reply with quote
Mmartinphd wrote:
Went just fine. Thanks for the advice on seating the LEDs. I misread and thought you meant they needed to "click" into the cluster piece, but when I figured out they needed to seat on the circuit board, all went smooth after that. Instructions are good.
Now I need to find the heart to toss my old printed circuit board. I definitely continued to destroy it when I took it off. Rolling Eyes
Toss it. Its not repairable. Good to hear you got it going.
'90 Carat w/ '95 phase 1 EJ22 OBD2 conversion
t3 kopf
t3 kopf is offline
PostPosted: Sat Apr 04, 2015 4:14 pm    Post subject: Reply with quote
GreenMachineVW wrote:
t3 kopf wrote:
Ive been trying to find the part numbers for those terminals. Wonder if anyone else has. Permanantly splicing it means you cant remove it for maitenance and i dont like that idea
I contacted one of the major suppliers, even sending a couple of terminals, and the plastic connector. I was informed that they were nowhere to be had. I also asked Kyle who does the harnesses, to no avail. If you do find them, spread the word: that would allow new harnesses in a few places that is impossible today.
If i had the part number that was on the connector, i could probably find the terminals somewhere. I have been able to get terminals and connectors that people say are no longer made in the past. Even ones that Kyle doesnt have.
Mmartinphd
Mmartinphd is offline
PostPosted: Sat Apr 04, 2015 11:06 am    Post subject: Reply with quote
1987 Westy
GreenMachineVW
GreenMachineVW is offline
PostPosted: Fri Apr 03, 2015 5:58 pm    Post subject: Reply with quote
Altoona
Altoona is offline
PostPosted: Fri Apr 03, 2015 1:02 pm    Post subject: Reply with quote
Mmartinphd
PostPosted: Fri Apr 03, 2015 12:31 pm    Post subject: Reply with quote
Thanks!
1987 Westy
t3 kopf
t3 kopf is offline
PostPosted: Fri Apr 03, 2015 12:29 pm    Post subject: Reply with quote
Altoona
Altoona is offline
PostPosted: Fri Apr 03, 2015 11:45 am    Post subject: Reply with quote
t3 kopf wrote:
Just read and follow the included directions and its easy. They really did a good job with this one. I would NOT reccommend permanantly splicing the harness into yours like the end of the directions opt however. That is one thing i dont know why they suggested. They call it "optional" but its a terrible idea... Confused
I have seen the stock plug and the connectors inside cause issues because they are old/damaged. I guess this way you can do away with that plug if it is a problem.
t3 kopf
t3 kopf is offline
PostPosted: Fri Apr 03, 2015 11:30 am    Post subject: Reply with quote
Also, when the leds are in place correctly, You will hear and feel them SNAP into place. They take a little force to snap into their sockets.
Mmartinphd
PostPosted: Fri Apr 03, 2015 6:03 am    Post subject: Reply with quote
Found this. 😀. http://www.thesamba.com/vw/forum/viewtopic.php?t=617187
Hopefully my install goes well. Would love advice.
1987 Westy
Mmartinphd
PostPosted: Fri Apr 03, 2015 5:55 am    Post subject: Reply with quote
Any updates? I just got mine and plan to install this weekend. I messed up my circuit board replacing bulbs.
1987 Westy
costal_cat
costal_cat is offline
PostPosted: Fri Nov 28, 2014 11:24 am    Post subject: Reply with quote
Ok I ordered one up
I will post the install and results if folks would like..
Did anyone order one? I did get almost 45 off with the holiday promo code...
Happy Holiday!
87 Syncro Westy
TDI Overland Parts engine conversion
tarandusVDub
tarandusVDub is offline
PostPosted: Mon Nov 24, 2014 3:50 pm    Post subject: Reply with quote
Thanks for looking into it costal.
1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD.
costal_cat
PostPosted: Mon Nov 24, 2014 3:11 pm    Post subject: Reply with quote
No group discounts right now but if your on the mailing list they will be sending out a discount this week that can be used on this product.
87 Syncro Westy
costal_cat
PostPosted: Mon Nov 24, 2014 12:11 pm    Post subject: Reply with quote
tarandusVDub wrote:
costal_cat wrote:
tarandusVDub wrote:
I'm interested in this too as mine is getting flakier by the year...
Anyone ever tried a group buy discount with GW? I wonder if we had 5 of us order if they would do something?
I'm in!
That's 2 of us. If anyone else is interested I'm willing to give them a call and see what they say...
87 Syncro Westy
tarandusVDub
PostPosted: Mon Nov 24, 2014 12:06 pm    Post subject: Reply with quote
I'm in!
costal_cat
PostPosted: Mon Nov 24, 2014 12:04 pm    Post subject: Reply with quote
87 Syncro Westy
tarandusVDub
PostPosted: Mon Nov 24, 2014 11:50 am    Post subject: Reply with quote
costal_cat
PostPosted: Mon Nov 24, 2014 11:33 am    Post subject: Reply with quote
kalispell365 wrote:
Looks nice and clean!
Right? I may make this the winter project. My high beams indicator went out so I need to do something either way
87 Syncro Westy
