New Transaxle Now No Gears
Pete's vdubs Premium Member
Pete's vdubs is offline
PostPosted: Sat Jul 23, 2016 3:46 pm    Post subject: Re: New Transaxle Now No Gears Reply with quote
Your coupler needs the proper tapered grub screw.The bolt may not be seating properly ,it looks like its sliding back and forth.
PostPosted: Sat Jul 23, 2016 3:42 pm    Post subject: Re: New Transaxle Now No Gears Reply with quote
mranker
mranker is offline
PostPosted: Fri Jul 15, 2016 2:56 pm    Post subject: Re: New Transaxle Now No Gears Reply with quote
I recognize those greasy fingers! 1 year update: clutch and transmission are all working well after many 1,000's of happy miles. The shifting has significantly loosened up. Throws have gone from forceful shoves to perfect slots.
'70 Bus
'02 Eurovan MV Weekender
Tcash
Tcash is offline
PostPosted: Fri Jul 15, 2016 8:54 am    Post subject: Type I 002 input shaft protrusion from face of bell housing Reply with quote
aeromech wrote:
mranker wrote:
OK engine out and the input shaft clears the mating surface of the transaxle by 9/16".
I called Eric over at Transworks this morning. He measured an input shaft and came up with the same length you have, 9/16. Looks like you are ok with the one you have.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Jun 16, 2015 6:47 pm    Post subject: Reply with quote
Interesting stuff. I've heard of so many people having odd issues like this where the clutch doesn't fully disengage, that I cross my fingers every time I have to touch that system.
I wish I had a fancy new transaxle to see what these "tight" gears feel like… Cool
www.airschooled.com
Road trip reports and tech blog:
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Jun 16, 2015 6:43 pm    Post subject: Reply with quote
mranker wrote:
it can take a while for new transaxles to "loosen up." Anyone else have experience with this?
yes
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
mranker
mranker is offline
PostPosted: Tue Jun 16, 2015 5:55 pm    Post subject: Reply with quote
PROGRESS! Sorry for the delay in responding but family responsibilities have kept me out from under the bus. So I went to see George at Import Vehicle Technicians in Pasadena. He's seen everything and he always will give advice on how to fix it yourself rather than take your money. I described my symptoms and showed my pictures and he asked a lot of the same questions you guys did. He asked what I had already tried and when I got to describing the clutch cable replacement he paused and thought. (If you don't know George he is the KING of the thoughtful pause) He went to a drawer and fished out a bag of these clutch cable arms. He must have had twenty of them and they were all different. The one on the bottom is my original and you can see where it has worn almost to the point of failure. The one on the top is the replacement I bought at a local part shop.
Here is the clevis pin I replaced due to excessive wear:
I tried to line of the horizontal where the clutch arm attaches to the pedal assembly so you can see the difference in the angle of the arms. After what seemed like 3 minutes of silent thought, George said he was pretty sure that my problem was I had the wrong arm and that the pedal was not giving me enough throw to disengage the clutch. He also said the new clutch cables have much shorter forks than the originals so he said I should file down one corner of the fork to allow more clearance for the cable. So armed with a new clutch arm and this information, I reassembled the clutch pedal assembly and put the engine back in. I really didn't think this was going to work but IT DID! I now have a functioning clutch.
Umm, looking at the pics of the shifter, it looks like it is rotating in the ball socket. Can you pull out the shifter and check to see if the pin is there on the ball at the bottom?
the pin is there. You can kind of barely see it in one of my blurry pictures
Now as far as shifting goes it is still very tight. It requires a lot of effort to select a gear. There is no grinding but it does sometimes take quite a shove on the stick to select a gear. George said it can take a while for new transaxles to "loosen up." Anyone else have experience with this?
'70 Bus
aeromech
aeromech is offline
PostPosted: Wed Jun 10, 2015 7:47 pm    Post subject: Reply with quote
Nice job picking up on that
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
1967250s
1967250s is offline
PostPosted: Wed Jun 10, 2015 7:09 pm    Post subject: Reply with quote
'72 Elm Green Deluxe
airschooled
Air-Schooled
PostPosted: Wed Jun 10, 2015 2:34 pm    Post subject: Reply with quote
Mike, with the engine out, does it shift smoother? Have you tried disconnecting the shift coupler and manually selecting gears using the shift input shaft going into the nose cone?
Wildthings wrote:
The length includes a taper of about 3/16 - 1/4" for either application so it is possible the OP needed to add more taper to his shaft to get sufficient clearance within the gland nut.
This is getting my tentative vote as well. I've mulled over it again and again, and it seems that the whining sound originally experienced in your early posts is the synchros trying to do their job, but are unable to beacause the input shaft is frozen to the engine. You have 9/16" clearance PLUS the width of your straightedge. Plus no chamfer. Definitely chamfer the edge of the shaft like an original; let us know if you need a picture or measurement.
If nothing else, the chamfer will make it easier to line up your engine for install.
I can't see through the cellphone pictures to really scrutinize the input shaft, but if I could I'd be looking for wear like a mad man.
Still meditating on this,
Robbie
www.airschooled.com
Wildthings
Wildthings is offline
PostPosted: Tue Jun 09, 2015 3:14 pm    Post subject: Reply with quote
kreemoweet wrote:
9/16?! Someone previously called out that dimension at 1 1/16 in., and I nodded my head, because that's exactly what my spare trans has. It's a rebuilt 002 of unknown source,
has a 72-74 002 clutch housing, and was taken out of a functional and pretty much stock '68 bus (it had the narrower '68 clutch housing on it at the time).
Is there really that much variation in that part?
There is a difference in protrusion of the tranny input shaft between a Type 1 (9/16") and Type 4 engine (1 1/16"). The length includes a taper of about 3/16 - 1/4" for either application so it is possible the OP needed to add more taper to his shaft to get sufficient clearance within the gland nut.
aeromech
aeromech is offline
PostPosted: Tue Jun 09, 2015 3:02 pm    Post subject: Reply with quote
He spoke like his was some kind of kodified shaft. Cant remember the term he used. The point was that 9/16 wasnt too short.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
kreemoweet
kreemoweet is offline
PostPosted: Tue Jun 09, 2015 2:44 pm    Post subject: Reply with quote
'67 bug: seized by the authorities
mranker
mranker is offline
PostPosted: Tue Jun 09, 2015 2:09 pm    Post subject: Reply with quote
aeromech wrote:
I called Eric over at Transworks this morning. He measured an input shaft and came up with the same legnth you have, 9/16. Looks like you are ok with the one you have.
Thanks for making the call. I really appreciate the effort. I still have no idea what's causing my difficulties but I'm grateful for the help.
'70 Bus
aeromech
aeromech is offline
PostPosted: Tue Jun 09, 2015 12:48 pm    Post subject: Reply with quote
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
mranker
mranker is offline
PostPosted: Tue Jun 09, 2015 12:34 pm    Post subject: Reply with quote
Nope. I took out an 002 3 rib and put in an 002 3 rib.
'70 Bus
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jun 09, 2015 12:01 pm    Post subject: Reply with quote
mranker wrote:
SGKent wrote:
are you supporting the transmission?
Yes. I have a floor jack and a jack stand under there
I do not know all the nuances of bus trans and engines as to shifter length but there are threads here discussing how different trans and years have different shift rod lengths. By chance did you change the type trans that came out of your bus - example, going from a 3 rib 002 to a 5 or 6 rib to get different gearing ratios?
George Carlin:
Skills@EuroCarsPlus:
mranker
mranker is offline
PostPosted: Tue Jun 09, 2015 11:44 am    Post subject: Reply with quote
'70 Bus
