oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Sat Nov 07, 2015 4:28 pm Post subject: |
Thanks for the great photos and advice...but, I broke the needle anyway.
Superglue, deftly applied seems to be holding. I knurled the shaft with small wire snips and the little brown gear will be as hard to work itself off as the speedo needle was to get back on...without breaking again.
Now, for the road test..
_________________ Currently:1980 Westy Westfalia Poptop (a total stock-look rebuild with all my favorite camping mods)
1967 stock Sunroof Beetle
Formerly:
1978 Westy Campmobile, the"EM50 Urban Assault Vehicle" code named "The Pickle"
1973 Squareback (sold on a lark)
1973 Super Beetle (crashed..walked away without a scratch)
1972 Standard Beetle (lost in a relationship..)
1966 Beetle (the Black Beauty, my Dad's)
1964 Beetle (the Beige Bug, my beginning beater, also my Dad's) Thanks, Dad. |
rcook52459 Samba Member
Joined: August 24, 2011 Posts: 492 Location: PORTLAND ORE
Posted: Mon Nov 02, 2015 2:53 pm Post subject: |
my odometer started slowly down then stopped working about a month ago.thanks to this thread I took it apart and seen those gears were just jammed together and I fixed them(I did push it while moving).when I took it apart on the back of the speedo plate was 159,235 dec. 2001(now 238,943),so was fixed before.just thought it was interesting.thanks for the info from everybody _________________ 85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10504 Location: Sunshine Coast B.C.
Posted: Mon Nov 02, 2015 2:10 pm Post subject: |
moreover, I'd suggest that the gears are moving relatively slowly.
I'd venture a guess that if a gear is ready to fail, resetting the trip odo will hasten its' demise and cause the odo or trip odo to fail.
relevant pics of speedo I repaired
_________________ 1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10101 Location: Where?
Posted: Mon Nov 02, 2015 1:29 pm Post subject: |
This thread inspired me to pull out a spare speedometer I had. I removed the tripmeter section. On the end near the 1/10ths is a black gear on the outside which is spun by the odometer portion of the gauge. I can spin that easily by hand and there is not any change to the resistance at any point during the depression or release of the button. The button unmeshes the gears prior to resetting the numbers. If you spin the black gear quickly while pushing the button very, very slowly, you can feel when the gears start skipping at a slightly meshed position, but there isn't any added resistance during that time. I am convinced that there is not any relationship between the odometer failing and pressing the button while moving. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10733 Location: Western WA
Posted: Mon Nov 02, 2015 10:39 am Post subject: |
Andrew A. Libby wrote: |
the reset mechanism moves the main tripmeter gear away from the drive gear while still allowing the driven gear to rotate. It is not until the drive and driven gears are unmeshed that it resets the numbers. My memory could be faulty though. YMMV. |
I am recalling the same now that you mention it but could be a matter of grey matter going gray. _________________
....KTMs, GasGas, SPOT mtb |
kennyw Samba Member
Joined: September 03, 2012 Posts: 58 Location: Salt Lake City
Posted: Mon Nov 02, 2015 10:37 am Post subject: |
That advise sounds like an old BS reason for not covering a warranty issue.
When I worked in a bike shop, I would hear bike companies say similar things to get out of honoring a warranty. _________________ '15 Tiguan - Victor
'88 Westy - Maggy |
Posted: Mon Nov 02, 2015 10:35 am Post subject: |
I don't believe the hype. A few years back I studied the workings of the odometer and tripmeter and came to the conclusion that it was purely a myth that pushing the button when moving increased the odds of breaking the odo. I don't have one apart right now and don't recall the details the specific details but I believe that the gist was that the reset mechanism moves the main tripmeter gear away from the drive gear while still allowing the driven gear to rotate. It is not until the drive and driven gears are unmeshed that it resets the numbers. My memory could be faulty though. YMMV. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
BlueGrasser Samba Member
Joined: August 27, 2014 Posts: 562 Location: Sacramento
Posted: Mon Nov 02, 2015 10:29 am Post subject: |
I push it in motion all the time and haven't had a problem (yet). _________________ Going to where the grass is bluer...
1985 Vanagon Westfalia Camper with 1.8T |
Sodo Samba Member
Posted: Mon Nov 02, 2015 10:25 am Post subject: |
If you're moving, there are gears trying to advance the odometer number wheels. I would expect, that the mechanism that zeroes the number wheels has to disengage them from the drive gears to do so. Otherwise how can it spin them?
Perhaps as it gets older, there could be a gray area in the mechanism, where it's trying to advance while your finger is holding them at 000. I don't recall mine resisting, but I don't hold it down. If some odometers "resist" it seems prudent that if you are moving, do your reset with a quick button push; at lower speeds. _________________
dobryan Samba Member
Joined: March 24, 2006 Posts: 17245 Location: Brookeville, MD
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5937 Location: Tsawwassen, BC
Posted: Mon Nov 02, 2015 9:22 am Post subject: |
Weird, eh? I've been pushing Vanagon trip meter reset buttons while moving for 20 years and over 225,000 miles with no issues, usually while driving away from gas stations.
Touching wood now. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10431 Location: Orbiting San Diego
Posted: Sun Nov 01, 2015 5:22 pm Post subject: |
Unless you have a Syncro you can't use the speedo from a VW car because the 2wd Vanagon speedo cable turns way too slow.
Mark
oldhuldy67 wrote: |
Do you think anyone has replaced the speedo with a lookalike or close enough
From a Jetta..Audi? |
Sodo Samba Member
Posted: Sun Nov 01, 2015 5:04 pm Post subject: |
Never heard this one before. I've reset the tripmeter while driving many times. Does it cause problems once they get old? _________________
Posted: Sun Nov 01, 2015 3:46 pm Post subject: |
I've heard the advice but have also heard that it might be an old wives tail.
Having taken apart and repaired two speedos
now, looking at the lever operation, wheels
etc. I don't think that resetting the trip odo
while driving harms the speedo wheels, gears etc.
here's an album of pics and comments on
one I repaired. I'd take the comments with
a grain of salt; some could be considered conjecture. I ain't no expert!
https://picasaweb.google.com/musomuso/1985VanagonTransporterSpeedometerGuts
(VW Gas I4)
VE7TBN |
Posted: Sun Nov 01, 2015 3:13 pm Post subject: |
Thanks Awahanee...fairly detailed info. Given all the difficulties,
From a Jetta..Audi? _________________ Currently:1980 Westy Westfalia Poptop (a total stock-look rebuild with all my favorite camping mods)
Formerly:
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3654 Location: Dartmouth, Mass.
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10281 Location: Mt Lemmon, AZ
Posted: Sun Nov 01, 2015 10:29 am Post subject: Re: Trip meter mistake...yep, I did it..I pushed it |
oldhuldy67 wrote: |
...Anyone have the post? Thanks! |
This thread wanders a bit but may have some useful posts:
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=20
Alas, the link to the page with the fix described is dead -- did not try Wayback or such to revive it. |
Posted: Sun Nov 01, 2015 8:56 am Post subject: Trip meter mistake...yep, I did it..I pushed it |
Who has not heard the advice to only reset the trip meter when stopped? Who knows what to do if you...well...pushed it like I did rolling away from the gas station? I searched the forum, found lots of speedo repair posts but didn't locate how to repair the trip meter.
Anyone have the post? Thanks! _________________ Currently:1980 Westy Westfalia Poptop (a total stock-look rebuild with all my favorite camping mods)
Formerly:
