Cusser Samba Member
Joined: October 02, 2006 Posts: 33442 Location: Hot Arizona
Posted: Tue Mar 08, 2016 9:35 am Post subject: Re: Brake spring tool |
I've used one like this for over 4 decades now
Most auto parts stores should have something similar for under $15.
I think the smaller of what you asked about would work for the shoe retaining springs/cups.
For the traditional type brake springs, I've always just grabbed on the straight part with genuine Vise-Grip pliers. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
PatsGhia Samba Member
Joined: December 20, 2015 Posts: 21 Location: Los Angeles, CA
Posted: Tue Mar 08, 2016 12:03 am Post subject: Re: Brake spring tool |
Whipped this up a number of years ago from some scrap steel. Works great - can see the pin to line it up. I use it with a pair of vice grips normally. Total width is around 9/16", cutout is around 1/4" wide by 1/8" deep.
johneliot Samba Member
Joined: August 29, 2005 Posts: 2195 Location: Chico, CA
Posted: Mon Mar 07, 2016 9:18 pm Post subject: Re: Brake spring tool |
Bruce,
The 12 points inside the socket are enough to turn the disk so the little pin will line up? _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17658 Location: Left coast, Canada
Posted: Mon Mar 07, 2016 8:25 pm Post subject: Re: Brake spring tool |
I use a 17mm socket on an extension. It's always in my tool box and I don't need to hunt for a special tool. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Mon Mar 07, 2016 7:55 pm Post subject: Brake spring tool |
Does someone know the size of the brake spring tool for a 69? I would like to pick one up so I don't have to keep using a pair of pliers. The ones I've found have one side 5/8 - 11/16 on one side and 11/16 - 7/8 on the other. Do I need metric sizes for this? _________________ John
Mark Twain
