Merian Samba Member
Posted: Fri Apr 01, 2016 4:33 pm Post subject: Re: Managing your Vanagon project |
nothing compared to the ones I created for my research
back in ye Olden Times, we had to program all our data calculations - then VisiCalc came along...
But I have successfully transitioned away from an all-paper existence.... |
brodyjdavis Samba Member
Joined: December 30, 2014 Posts: 89 Location: Chicago, IL
Posted: Fri Apr 01, 2016 2:09 pm Post subject: Re: Managing your Vanagon project |
good lord, what a spreadsheet! _________________ 1984 Westy | www.brodyjdavis.com |
Merian Samba Member
Posted: Fri Apr 01, 2016 1:38 pm Post subject: Re: Managing your Vanagon project |
Maint. Intervals - by Time & by Mileage
set it up once & let the computer do the calculations
copy to new workbooks for all your vehicles, then mod. a bit |
Merian Samba Member
Posted: Fri Apr 01, 2016 1:35 pm Post subject: Re: Managing your Vanagon project |
Maintenance Log
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1683 Location: Between Here and There
Posted: Fri Apr 01, 2016 12:01 pm Post subject: Re: Managing your Vanagon project |
Lots of different ways to keep up. I like the OP's spreadsheet idea, but would probably just modify it for maintenance history and scheduling.
My note that I keep for my dash is GAS! since my gauge doesn't work all that well... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
tjet Samba Member
Posted: Fri Apr 01, 2016 10:39 am Post subject: Re: Managing your Vanagon project |
djkeev wrote: |
I am NOT a luddite, but for me, the work involved to make a spread sheet of what I should do just isn't worth it.
Computers are great things but paper and pencil are far better for something like this.
Anyway, one man's opinion.......
Carry on.
Dave |
I agree with Dave on writing it down. I have a few car projects going on, which I work on a different times. I will leave a note taped to the steering wheel, which may state "ADD OIL" or "NO BRAKES" or "HORNET NEST UNDER BUMPER"
Taped to the dash, I will also have a less important to-do list, something like:
* hook up exhaust
* modify rear trans mount (lower)
* finish electrical
* oil gauge inop
* tighten rear shocks
I also will log my to-do list in a notebook or take a photo of it. One project of mine is 3000 miles away at my dad's house. As for logging / computer apps, I will send myself a quick email if I get an idea. I keep a few different folders in my yahoo acct for the different cars.
Another tip, always put a date on your notes. |
Borg Samba Member
Joined: October 18, 2012 Posts: 130 Location: Western Washington
Posted: Fri Apr 01, 2016 9:28 am Post subject: Re: Managing your Vanagon project |
I use the whiteboard method of project management too.
Have you ever noticed that the longer a note is on the whiteboard the harder it is to erase? _________________ Steve |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2931 Location: North Carolina
Posted: Fri Apr 01, 2016 8:10 am Post subject: Re: Managing your Vanagon project |
I need my to-do list to be more manageable- too much overwhelms me.
So, what I've been doing is keeping a list with 3 "soon" small items and one "big" item. As "soon" items are marked off, they're replaced with the next item on the master list.
Here's my example from the last two weeks:
BIG: Pull the motor, partial upper end rebuild. (planned for May)
Small: Clean ISV valve (done, replaced with try the Mullendore Port)
Replace 02 sensor (done, replaced with replace nasty insulation on
engine lid)
Use homemade smoke machine to look for vacuum leaks (done,
replaced with fix broken headlight adjustor).
So, this way, I keep marking the small items off the list in between the big projects- but I don't get overwhelmed. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Halifaxwesty Samba Member
Joined: October 21, 2012 Posts: 213 Location: Halifax, Nova Scotia, Canada
Posted: Fri Apr 01, 2016 7:20 am Post subject: Re: Managing your Vanagon project |
I have a whiteboard in the garage a list of items on my phone I need to pick up for repairs. _________________ 84 Westfalia Vanagon
2.2 RMW Conversion
Work in Progress
My first car was a 1968 VW Bug |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
jimf909 Samba Member
Posted: Thu Mar 31, 2016 3:24 pm Post subject: Re: Managing your Vanagon project |
Today's random and incomplete list:
Computers
Pro: conveniently located at the office, in your pocket, on the nightstand; at the library, etc.; easy to edit; easy access to links and a endless information on the www.
Pen and paper
Con: single purpose; short-lived; often not where I am; difficult to edit frequently _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
I find that making a list of each needed repair is a great tool. It gets me thinking and acting. When I used to tackle a complete restoration, it would take a year or better, making separate lists for each system or project with an added time line to finish said project, gets the overall restoration done much quicker.
I do not find myself always at a computer ( other than my phone) and keeping a manila envelope with the list on the back, receipts in the front work best for me. |
Fracas Samba Member
Posted: Thu Mar 31, 2016 3:08 pm Post subject: Re: Managing your Vanagon project |
brodyjdavis wrote: |
I made a google spreadsheet document to help me keep everything organized. |
I've done a similar thing with Google Docs. Now if only there was an API to GoWesty and Rock Auto I could get my Account to pre populate my orders into the my Google Docs. |
Posted: Thu Mar 31, 2016 2:33 pm Post subject: Re: Managing your Vanagon project |
I made a google spreadsheet document to help me keep everything organized. I assign a number rating to indicate how vital each upgrade is, I assign a number for how difficault the job is to accomplish, and I also research the cost and put that in another column. This way I can easily reorganize the list to show me the cheap, easy, or vital jobs ordered out from top to bottom at the click of a button.
Another nice bonus is I can view the spreadsheet any mobile device with an internet connection, and I can share it with someone fairly simply too.
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Thu Mar 31, 2016 1:35 pm Post subject: Re: Managing your Vanagon project |
SCM wrote: |
Tom Powell wrote: |
I haven't done any exhaust work on a system with a catalytic converter, |
I thought I read that silicone was bad for the O2 sensor, not the cat. I could be wrong though. |
You got me to searching the internet. BOTH
http://www.easterncatalytic.com/education/tech-tip...r-failure/
"Contamination: If silicone products are used to seal any part of the exhaust system including the exhaust manifold and gaskets, O2 sensors, and exhaust tubing, you’ve got problems. At best, the highest rated silicone can only handle 700 ºF, so when exposed to exhaust temperatures of 1200 ºF, it quickly burns and outgases, leaving a silicone coating on the O2 sensor or converter wash coating. The results include engine conditions that are out of operating range and reduced efficiencies within the catalytic converter."
Aloha
tp |
SCM Samba Member
Joined: January 26, 2011 Posts: 3380 Location: Bozeman MT
Posted: Thu Mar 31, 2016 1:26 pm Post subject: Re: Managing your Vanagon project |
Tom Powell wrote: |
I thought I read that silicone was bad for the O2 sensor, not the cat. I could be wrong though. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Thu Mar 31, 2016 1:21 pm Post subject: Re: Managing your Vanagon project |
jkmcrg wrote: |
Tom Powell wrote: |
Don't use RTV ($3.66) in your exhaust system. It will ruin your catalytic converter ($131.01 plus shipping).
Aloha
tp |
Huh, for some reason I got the idea you should use Ultra Copper (high temp) on your gaskets... do you use anything on your gaskets or just clean surface? |
I haven't done any exhaust work on a system with a catalytic converter, but there are several comments on TheSamba saying that silicone should not be used. It is also not recommended for engine assembly where bits may get into and block oil galleries.
On my '69 bay window I use old Permatex #3 on exhaust gaskets and engine assembly and Hylomar on one side and grease on the other side for valve cover gaskets. I haven't done that much repair work on my Vanagons yet.
Aloha
tp |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10227 Location: Mt Lemmon, AZ
Posted: Thu Mar 31, 2016 1:12 pm Post subject: Re: Managing your Vanagon project |
Interesting tool and very neat & organized - but I'll probably stick to spiral notebooks and a pencil.
jkmcrg wrote: |
...Within two weeks of purchasing my "mechanic checked out" "good to go" vanagon, my water pump broke, and my engine developed a knock. Shortly thereafter, my automatic transmission lost 3rd gear... |
There's your problem, you took it to a mechanic. Next time, try a psychic. |
jkmcrg Samba Member
Joined: November 24, 2014 Posts: 169 Location: Austin, TX
Tom Powell wrote: |
Aloha
tp |
Huh, for some reason I got the idea you should use Ultra Copper (high temp) on your gaskets... do you use anything on your gaskets or just clean surface? _________________ 1984 Westfalia Orwell (crispy)
2.2L Digifant
Automatic transmission |
