My 67 Burro off road overland bug
69builder
69builder is offline
PostPosted: Mon Nov 11, 2019 2:54 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
What type of kerosene heat setup did you use @ 20valve?
20valve
20valve is offline
PostPosted: Fri Dec 28, 2018 10:11 am    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Triple Driver wrote:
Could you please describe the gauge layout. How does your speedo operate? With a cable? What kind of shocks are you running?
I’m using a GPS speedometer.
Here's my set up, just for bang'n around desert roads and trails.
20valve
20valve is offline
PostPosted: Fri Dec 28, 2018 10:10 am    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Bugginout2019 wrote:
How do you seal the body to the cage? Example, where the cage penetrates the front firewall. Do you weld the fire wall to the cage? Is there a rubber grommet used to seal it off to disallow dust and other debris from entering the cockpit
The cage tubes run through 1.5” holes that are bored through the body lift then welded to it. After that it’s seam sealed using brush able body seam sealer.
20valve wrote:
Here’s a few pictures during the build.
Bugginout2019
Bugginout2019 is offline
PostPosted: Wed Dec 26, 2018 1:02 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
How do you seal the body to the cage? Example, where the cage penetrates the front firewall. Do you weld the fire wall to the cage? Is there a rubber grommet used to seal it off to disallow dust and other debris from entering the cockpit?
tookor
tookor is offline
PostPosted: Mon Oct 15, 2018 7:09 am    Post subject: Re: My 67 Burro off road overland bug Reply with quote
That Burro is badass!! Awesome build that is seriously impressive. I've been wanting to get another bug and build something just like that, but I don't quite have that ability I think. Obviously a lot of hard work, great job!
nate3923
nate3923 is offline
PostPosted: Wed Oct 03, 2018 5:37 am    Post subject: Re: My 67 Burro off road overland bug Reply with quote
great looking bug man!
dustymojave
dustymojave is offline
PostPosted: Sun Sep 30, 2018 12:41 am    Post subject: Re: My 67 Burro off road overland bug Reply with quote
There are pop rivets available that seal.
Richard
SoCalBajas Member
20valve
20valve is offline
PostPosted: Wed Sep 19, 2018 3:13 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
poeticlydead wrote:
This bug turned out great, I love the use of the rivets as a styling cue to highlight the body lines. Did you do that with standard steel or aluminum pop rivets?
I used aluminum rivets seam sealed on the back side. Thanks for the compliments.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Mon Sep 17, 2018 9:11 am    Post subject: Re: My 67 Burro off road overland bug Reply with quote
GhiaBateman wrote:
Awesome Build!!
This is what I have been planing to do with a Ghia, the one I had needed to leave me 'sad' but I'm searching for another one that is not worthy of restoration... because it will look much like your bug... Love It!!
DO IT!!! Here’s mine.
https://www.thesamba.com/vw/forum/viewtopic.php?t=691306
Triple Driver
Triple Driver is offline
PostPosted: Sat Sep 15, 2018 7:34 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
poeticlydead
poeticlydead is offline
PostPosted: Sun Aug 12, 2018 11:19 am    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Not all who wander are lost.
GhiaBateman
GhiaBateman is offline
PostPosted: Thu Jun 07, 2018 4:44 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Awesome Build!!
(o=|=o) Life before play... Damn! it's gonna be awhile.
joemama
joemama is offline
PostPosted: Wed May 30, 2018 2:07 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Awesome! I have a set of rgb's and trans I would love to use like you did.
veeweeman
veeweeman is offline
PostPosted: Tue May 29, 2018 4:07 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Thanks for sharing. ..that burro is exciting! Twisted Evil
Never be a follower...Do your own thing, make it your own!
20valve
20valve is offline
PostPosted: Tue May 29, 2018 1:09 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
heywebonya
heywebonya is offline
PostPosted: Tue May 29, 2018 5:23 am    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Sweet build, any pictures of the process?
Super layout and love the color combination.
If I knew what I was doing; I wouldn't be building a buggy!
Zevro
Zevro is offline
PostPosted: Mon May 28, 2018 9:25 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Wife and I love your Bug. We are starting on our 72 overland bug and would like to bend your ear Emailme at [email protected]
Metal Twister
Metal Twister is offline
PostPosted: Mon May 28, 2018 9:24 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Love everything youve done with it. That bad boy will go just about any where you need to go. The bug on my avatar was my pride and joy some 40 years ago! Still have great memories of that ride! Enjoy and thanks for the smile you put on my face!
Change is Opportunity!
Instagram=metaltwister
20valve
20valve is offline
PostPosted: Mon May 28, 2018 7:27 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
veeweeman wrote:
Nice, very nice buggy indeed. ...why not just go with a TDI diesel engine? ...would've been twice the torque and twice the milage. ..I can't remember where I saw it but I did a Google search and the TDI fit in the same space with a slight deck lid mod...not to mention the 500,000+ miles you can get from a diesel engine. ..just saying. ...I'm jealous cuz your car is finished and mine is still under construction Laughing
I thought about putting a Subaru engine in it, but it just wasn’t right. I want to keep it an air cooled bug. I love the simplicity of them. It still has tons of power, I know I’ll lose some a higher elevation, even after I rejet the carburetor while I’m there. But that’s the fun of it! Very Happy
weasel_ugs
weasel_ugs is offline
PostPosted: Mon May 28, 2018 4:30 pm    Post subject: Re: My 67 Burro off road overland bug Reply with quote
Very nice bug!
Sorry I cant speak of the trail though,wanted to take my Jeep to Colo but sold it before I could.
