16CVs Samba Member
Joined: February 22, 2004 Posts: 4281 Location: Redwood City, California
Posted: Wed Jun 13, 2018 12:28 am Post subject: Re: No reverse lights #15 fuse keeps blowing |
I always forget which side it's on. I think the right side. It's on a a raised boss so you can't miss it. It's a small 2 pole switch , as I recall some have a plstic Molex on it and some just have 2 wires.
Just climb under and look up high on the side, it's not hard to see.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
datsnice Samba Member
Posted: Tue Jun 12, 2018 9:26 am Post subject: Re: No reverse lights #15 fuse keeps blowing |
| 16CVs wrote: |
Remove both taillights and replace the fuse. If it does not blow then replace them one at a time. Could be a corroded or shorted bulb.
Could also be the output wire at the switch is off and shorting to ground. I would start with the tail lights and work my way towards the switch.
Stacy |
Can you tell me where the switch is? FYI I have a Subaru 2.2conversion if that makes a difference. Thanks! _________________ 1989 Vanagon 2WD Full Camper
EJ22 Subaru Conversion
"Greyboy" |
16CVs Samba Member
Posted: Mon Jun 11, 2018 10:53 pm Post subject: Re: No reverse lights #15 fuse keeps blowing |
Posted: Mon Jun 11, 2018 1:16 pm Post subject: No reverse lights #15 fuse keeps blowing |
I have no reverse lights, so I first checked the number #15 Fuse and it was blown. Replaced it with another 10amp fuse, turned ignitionOn, shifted into reverse, but still no reverse lights. Checked the fuse again and it blew the new one. Any idea What is causing this? I have to get this fixed by tomorrow! Thanks for any help!
89 Vanagon camper
Auto transmission _________________ 1989 Vanagon 2WD Full Camper
"Greyboy" |
