Murmsk Samba Member
Joined: February 24, 2019 Posts: 368 Location: Illinois
Posted: Sun Mar 24, 2019 8:09 pm Post subject: Re: Body advise |
| Thanks for the advise and ideas. Seems like I’m headed to HF. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4989 Location: Stuck in Ohio
Posted: Sun Mar 24, 2019 7:41 pm Post subject: Re: Body advise |
If a slide hammer is going to be used don't go popping holes in the panel and screwing the hammer in there. The stud welder kit comes with a slide hammer that grabs onto the studs it melts on there. Also, you could bolt an attachment onto the body with the fender bolts, like a linked chain. Like safety chains for a trailer let's say. The slide hammer blows could be spread across two or more fender bolts that way and pull the area as a unit.
Here is a slide hammer set with lots of fun attachments shipped to your door for 75 bucks. I bolted a chain to a brake drum of a quad runner with the wheel studs and then used the slide hammer to bang out two opposite studs to pull the drum off evenly. https://www.amazon.com/Hiltex-Hilltex-Repair-Slide...&psc=1
Maybe something like that could spread the blows across the mounting points of the fender.
Most importantly..... Have Fun!!! _________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
Joined: May 17, 2003 Posts: 4875 Location: Harmony, PA
Posted: Sun Mar 24, 2019 6:45 pm Post subject: Re: Body advise |
| It looks as if it’s pushed the fender mounting flange almost vertical/perpendicular to the ground. That’s a fairly major fender bender, not minor. You’ll have to do some serious whacking with a slide hammer, and a stud puller if you choose that route. If you’ve never done bodywork, I’d take Eric&Barb’s advice. What may take you days to get close, may take an experienced frame machine operator hours to get perfect. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26211 Location: Olympia Wash Rinse & Repeat
Posted: Sun Mar 24, 2019 3:52 pm Post subject: Re: Body advise |
Take the beetle to a frame shop and have them pull that fender area back out. _________________ In Stereo, Where Available! |
Murmsk Samba Member
Posted: Sun Mar 24, 2019 2:04 pm Post subject: Body advise |
So I’m starting to consider how to fix what needs to be fixed on my convert. Here is the only issue with the body. It looks like there was minor fender bender in the past. The body is slightly dented but it’s in an area I can’t get to from behind . Any suggestions ?
