orwell84 Samba Member
Joined: May 14, 2007 Posts: 2774 Location: Plattsburgh, New York
Posted: Fri Sep 20, 2019 7:09 am Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Squeeze Cheese wrote: |
Orwell, does your engine have a lopey idle?
I’ll be interested to hear how Jmstu does with this 107i cam. Len and I did chat about your engine. Why was the choice made to go with flat topped pistons on a 2.0 with a higher lift cam? I would think your valve to piston clearance would be really tight.
How does it sound at idle with that complete 75-78 exhaust you have? I converted to the 72-74 but it’s no quieter. Better interior heat though! |
Right now my idle is set high, like 1100 rpm, though I have had it lower without loping. I think I set it that way to overcome the bog I got using the single Weber. I am also running a Bosch 050 distributor and an early auto trans. The idle drops of course when I shift into drive. I have to shut it off in drive too as it will run on if shut off in park, probably because the timing is too advanced because of the high rpm. I am switching back to stock dual carbs and distributor but haven’t gotten to it yet. I will have to look up my notes for CR and deck height. |
Joined: January 01, 2007 Posts: 17860 Location: sticksville, ct.
Posted: Thu Sep 19, 2019 7:44 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
I would think your valve to piston clearance would be really tight. |
blueprint the engine...pretty easy to do _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Squeeze Cheese Samba Member
Joined: August 18, 2015 Posts: 274 Location: Atlanta, GA
Posted: Thu Sep 19, 2019 5:18 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
How does it sound at idle with that complete 75-78 exhaust you have? I converted to the 72-74 but it’s no quieter. Better interior heat though! _________________ 63' Ragtop Beetle
78' Dakota Beige Westy. “Skills” EJ25 engine conversion w/ zero mile factory short block, Delta 1000 cams, heater core and modified Gilmore AC. Matt Steedle 091 transaxle upgrade w/ 4.14 ring and pinion, Folts aluminum gear carrier. General Grabber AT2s on stock wheels. Solar powered aux battery w/ inverter. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23153 Location: Oklahoma City
Posted: Thu Sep 19, 2019 12:07 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
orwell84 wrote: |
I’m glad you got it mostly sorted out. When I chose the Web 73, I thought of it as a very conservative deviation from stock and at worst would not give me any noticeable performance gain. I kept my CR low thinking erring on the low side would keep temps down even if I didn’t get all the good out of the cam. I am happy with the improvements with my bus, though they are modest and it difficult to tell whether it is the cam or replacing my garbage heads with Len’s. I have since realized that my knowledge of this had some serious gaps and the fact that my engine runs decently is because I was more lucky than good. |
Yes.....the Web 73 really likes a little bit higher compression than a stock bus. I have found that it really has a difficult time achieving a good idle below 8.0:1. I believe its a velocity issue due to overlap. Ray |
Posted: Thu Sep 19, 2019 10:59 am Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Posted: Wed Sep 18, 2019 8:14 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
In conclusion...
I had Len flycut the heads to get me up to 8.0:1 CR, right in the middle of the suggested range for that 107i cam, and reassembled. Thanks for doing that, Len! It seemed to be the fix.
During the course of a few weeks of tweaking, I’ve achieved a pretty strong and good running engine. I found that it “likes” the timing at 34 BTDC max advance hoses off. There’s no pinging and it pulls better than before when it was bone stock. Decent low end, but with a noticeable power band from about 3200-5000RPMs, although I usually shift at 4500. It’s a fast bus around town, the fastest air cooled powered bay I’ve driven. I’m able to easily pass on level ground and maintain speed up hills in fourth that I was having to downshift on before. And it’s running cooler than before. I’m only at around 360-370F CHT at 65MPH in 90F ambient, even with the AC cranked.
Still, in hindsight I would've stayed with the stock cam and the reason is the idle. It’s lopey and that’s just how it is. At 900 RPMs it sounds like my dad’s old panhead. It might sound cool to some but I’ve learned that I prefer the quieter steady purr at stoplights. I’d give up a little performance for a better idle. But, I compromise by setting the idle to 1100RPMs which smooths it out a lot.
Next I have some AFM adjustments. The setting I used when it was stock is now running a bit rich. I’m only getting 14MPG mixed driving. Since I have some CHT to spare, I’ll be hooking up my LM2 and try leaning it out till I find a happy place between good MPG and cool enough CHT.
Hope that helps! _________________ 63' Ragtop Beetle
Posted: Tue Sep 17, 2019 9:11 am Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Clatter wrote: |
I'm of the opinion that you might just have something simple going on.
Even plastic timing scales can be a few degrees off.. Sometimes 4-5-6 degrees.
When you are checking for TDC by sticking something down the plug hole,
it might not be that accurate as well.
Are you -sure- you are 100% accurate in your TDC measurement?
Give the motor what it wants.
Some of the best builders might tune by 'ear'. |
I don’t have any experience with fuel injection and I get how altering the vacuum signal through having a lower CR would effect the workings of FI, but I have run across situations where the timing gun showed timing off the scale in ranges that were theoretically impossible for a running engine even after eliminating the obvious possibilities. It seemed like it didn’t take much wrong to get ridiculous advance numbers. I can’t help but think that it is something like this and that the numbers you are getting are somehow not what your actual advance is. I am also thinking of things like the differences between stock and aftermarket cam gears though I may be barking up the wrong tree. After reinstalling my rebuilt engine, my neighbor tuned it by ear. It was crazy advanced but did not ping or show high CHT’s in the short time we drove it. Setting it to correct timing it had slightly less pep but not much. My CR is pretty low but it had dual carbs. I am running a web 73 but don’t know how it compares to your cam. Good luck. |
Posted: Mon Sep 16, 2019 1:41 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
jmstu76 wrote: |
I agree, the CR is set, just wondering if my PSI will increase over time |
as things break in yes, you could grab up to 10 psi. if it doesn't happen in 2k-2500 miles I would say no, it won't get better _________________
Jake Raby wrote: |
Brian wrote: |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1280 Location: Edmond Oklahoma
Posted: Mon Sep 16, 2019 12:20 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
skills@eurocarsplus wrote: |
jmstu76 wrote: |
So I can assume the CR will rise as the rings seat and I need to be careful not to over advance the timing with higher CR.... |
no..your compression ratio is what it is....you set that. yes, the actual PSI will come up, but for all intents and purposes it won't change.
as an aside...
boston bob was famous for using the hemi cut heads. if you set the timing to spec, it was a fucking gutless wonder. you couldn't spin tires on greased ice. you needed to run a ton of timing, like 38-40* to get any action out of it. that sounds to me like where you guys are at.
only way you can check all of this at this point is run more timing and use a wideband and CHT to see what's going on. |
I agree, the CR is set, just wondering if my PSI will increase over time _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
Posted: Sun Sep 15, 2019 7:29 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
jmstu76 wrote: |
as an aside...
only way you can check all of this at this point is run more timing and use a wideband and CHT to see what's going on. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Sep 15, 2019 7:15 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
interesting that you guys are having similar results.
wonder if web cam has fucked up the final grind? guess all you can do is compare with a stock and see where they went wrong, or this cam is just a no-no for this application.
not knowing the #'s off the top of my head... .060 deck is huge imho. I usually run .040 and adjust c/r in the heads.
my 1904 (granted, it's a T1) pulls really nice in a westy. .040 deck and 8.1 compression. iirc, 64cc chambers. any time I have pulled apart an engine with huge deck, I just kind of laugh.
nothing like doing a job twice... _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Sep 15, 2019 6:52 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
SO...
I also just built an FI type IV.
stock case
Stock throw crank (71mm) counter weighted
Stock length rods (H beams) using type IV bearings
96mm KB flat top (no dish) pistons
Hoffman stock heads (not camper specials) with the coatings
Webcam 107i cam and webcam hydro lifters
bone stock FI with new geebee silicone hoses
'76 stock exhaust, F pipes, U pipes, boxes, Crossover, J pipe, cat delete, Muffler and tail pipe. (all previously ceramic coated)
When I was going to set the deck height, Len warned me of a customer running the same cam and the CR was too low, He wanted to flycut my heads. I explained that I was using flattop pistons. I was shooting for a CR of 8.5/1. This called for a .050 shim at the base of the cylinder. Since no-one makes a .050 shim, I opted for a .060 giving me a little lower CR.
I had set my Throttle body bypass screw the same as the previous engine which was bone stock everything. 2.5 screws out from all the way in.
Well guess what happened at first start up?
it fired right up after getting positive oil pressure. now I immediately went to unscrew the by pass screw to raise the rpms to break the cam in.
No change, so we rigged the gas pedal to hold the rpms for 25 minutes of cam break in.
After cam break in, I set the timing at 28 degrees btdc at 3k rpm with hose off and plugged.
it ran super smooth and quiet but had NO low end power (sound familiar...)
Then I found this thread. Len never told me who was having this problem btw.
I sure wish I would have researched that cam more. I tried to buy the very best but I feel like maybe I was mislead. I bought directly from Webcam because other online suppliers wouldn't give me a date when it would be "in stock"
So I should have the required CR to run it. I did bump my timing up to 34-36 degrees btdc. It runs good with no pinging that I can detect.
The thing is, I only have barely 200 miles on this engine. I'm sure the rings are fully seated.
I wish you luck with your remedy. I hope this combo ends up working for me.
So I have build a 2056. My friend built a 2182 with a 78 mm cam, torque special cam and dual webbers. The thing pulls like a train. So much low end.... _________________ James
Posted: Tue Jul 02, 2019 3:44 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Clatter wrote: |
Don't fly-cut type 4 heads if you can avoid it.
They need the meat/support, and the exhaust studs lurk right below the seating surfaces.
You want as many opportunities to surface the heads in the future as you can.
Remove base shims, or shorten cylinders. |
This is true.....but....if HAM can recommend that it can be done safely....and these are NEW heads with NEW AMC castings right? That makes a difference.
As colin notes....sure....you "CAN" run well at 7.3:1.....but that does not always mean you will.
Especially....with ANY of the early injection systems. There is just not enough adjustment in the systems.
Likewise.....with a bus and the same injection systems L-jet for the bus and D-jet for type 4 cars...excessive compression cannot be easily gotten around by adjustment either.
I agree with Clatter in that you need to verify everything before go do ANYTHING. No....this is not suggesting that Len Hoffmann made a mistake at all.
Just check everything. This could easily mostly be the cam profile.....or a mentioned....a toming issue.
But you should NOT have compression test pressures in the 90s...even with 7.3:1....and certainly not with 7.6:1.
The issue with cams that have odd overlap or poor lobe center....for early injection systems.. is that port velocity can be low. So if you also have say... larger than stock valves....you can have really poor velocity. This can make the metering flap movement in L-jet....spiky or sluggish....causing erratic afr
As others have noted.....the 107i.....is a Vanagon grind? Well.....that means its stock injection was either digijet or digifant. While they still use a vane type AFM.....they use diffefent tenp senaors and downstream correction. ....and have better ignition, advance and retard control. Ray |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7770 Location: Santa Cruz
Posted: Tue Jul 02, 2019 1:55 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Remove base shims, or shorten cylinders. _________________ Bus Motor Build
It does not exist! |
Posted: Tue Jul 02, 2019 1:53 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Some of the best builders might tune by 'ear'. _________________ Bus Motor Build
Posted: Tue Jul 02, 2019 8:44 am Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
raygreenwood wrote: |
If you spent the cash on HAM heads....dont cut anything...yet. Make a plate to CC with. Cc the chambers with the step.
Then CC the dish on the piston. Then bring the pistons up to TDC....all four...each one.....and check the deck height right above the piston pin area.
Post that info. |
Amskeptic wrote: |
In order for me to check your numbers, I need the combustion chamber volumes. |
Thank you all again for your input. It sucks having to fix mistakes, but valuable for the soul, so that's what I'll do.
It will take a few weeks, but I'll report back with the head measurements once I have them off.
I talked to Len Hoffman and the fly cutting the heads is totally doable, he said he can get my CR anywhere from 7.75 - 8:1.
If shaving the cylinder down is equally effective at reducing chamber volume, why not go that route?
Would you guys recommend a CR that I should target? Ray recommended "running near the TOP of the 8.25:1 spec". I imagine valve to piston clearance will be the limiting factor? _________________ 63' Ragtop Beetle
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Mon Jul 01, 2019 7:56 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Just machine the step out and re-cc the heads. Also....carefully cc the dishes. Its been my experience that they vary a lot.
Saying the step makes an instant 5cc.....is also an issue. It depends on how the step got there. If it was cast in.....the chamber opening itself...has never been "shaved". So that extra thickness from the step.....is quench area...and is essentially adding 0.060" or whatever it is....to the actual deck volume....along with a full size chamber.
However if it was a set of heads with no step...and it was machined in.....then the opening of the chamber was shaved and its volume reduced....even though you added more quench area by doing this. So you lose compressio n and gain a little in this method.
Ray |
Len stamps the CCs on the heads with the .028 step factored in. Add 15 for the deep dish pistons. I came in at exactly 7.3:1 and the engine is running fine here in Minnesota today, 2K miles in so far.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
Posted: Mon Jul 01, 2019 7:52 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
This is my Dakota Beige 78' Westy that you helped me tune last year here in Marietta.
Should've listened to my gut and stayed stock. Damn.
I had a reputable aircooled machinist calculate my CR based on the deck height I measured, maybe you can check the math?
Cheesecrackers September 24, 2017. Time flies when you are having this much fun.
Posted: Mon Jul 01, 2019 4:32 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Ray |
They're HAM heads, so new castings with the step cast in. |
Post that info.
Its very possible that the BEST anx simplest way to fix this is by pulling the cylinders.....just leave the pistons carefully hanging.....and take the cylinders into a shop and have them lathe trimmed to reduce deck.
Seeing now.....since they are HAM heads.....lotta cash and a great build....with coatings .....I would not cut them.
If you have something like a 0.060"cast in step......AND a .018" deck.....thats .078". Thats too much.
Not only is that lower compression like you have.....its putting a lot more of the combustion in a space/gap....outside of the actual chamber. It can cause excessive heat.
Yes.....it would be easier to just cut 0.038" out of the heads...leaving an 0.40 deck.....which I would bet you will see about 7.8:1 or slightly better.
Ray |
Posted: Mon Jul 01, 2019 2:33 pm Post subject: Re: Puzzling combination of Type IV issues - it runs this advanced? |
Vanagon=different animal....
77 bus...carbs or FI? you'll never know the build specs. I feel for you steve, really. sucky situation for sure. but as you see by my photos, a well cared for but used 2.0 had almost (almost) twice the compression you have....
compression isn't a dirty word when done right. iirc I am running a tight (.040) deck on my 1904....different animal for sure...
bring it up. I have 2 swaps going on now, what's another
no joke...dumpy busses owners just got back from TN. it hasn't had an oil change since I built it in '16....that is the God's honest truth. I talk to the owners all the time....I haven't been under the bus since the build _________________
Jake Raby wrote: |
Brian wrote: |
